Modérateurs: Modération Forum Home-Cinéma, Modération Forum Installations, Modération Forum Univers TV, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 10 invités
FIRST 3D CALIBRATION DISC "Spears & Munsil HD 2nd Edition"
Message » 03 Déc 2012 16:30
Spears & Munsil HD Benchmark Blu-Ray 2nd Edition
Enfin des mires 3D natives pour calibrer la 3D :D
ConnecTEDDD sur AVS Forum a écrit:Artwork from the upcoming HD Benchmark Disk by Stacey Spears & Don Munsil.
It will came out (propably) at the end of next month
stay tuned...
realzven
Inscription Forum: 13 Mar 2010 15:19
Message » 04 Déc 2012 18:04
Ahhhh ? Intéressant ça pour ma prochaine TV ! ;)
Merci pour l'info !
mlg33
Inscription Forum: 05 Déc 2010 20:36
Message » 04 Déc 2012 18:33
:wink:
realzven
Message » 07 Fév 2013 19:16
Hot News au 07/02/2013 : http://www.avsforum.com/t/1442511/spear ... t_22935205
Here is the booklet that will be included with the new disc. http://www.spearsandmunsil.com/sspears70/v2insert.zip
There is a lot of content on the disc, which is why it has taken so long to author. I should have a new build of the disc to test today. Hopefully its almost done and will hit the market no later than April. In the end, it will be done when it is done.
1. All of the patterns except the SD, interlaced, and 30p, are available in 2D or 3D. In 3D most of them are flat 3D. We do have a special 3D section that lets you visually measure crosstalk, if you know the gamma of your display, a way to measure with a meter, and some 3D evaluation patterns for things like the sync between the left and right eye.
2. The disc has 5.1 and 7.1 pink noise for audio level adjustment as well as phase. Our pink noise closely matches THX, so you calibrate for 75 dB. The audio is available in TrueHD and DTS-HD MA. We also have some 24p and 2-3 lip sync patterns.
3. We have RGB and YCbCr ramps in horizontal, vertical, and double horizontal. The YCbCr ramps are RGB legal.
4. We have some new motion patterns to measure motion resolution. We also have some motion patterns in 24p, 30p, and 60i. This will show inherent blur in the display itself.
5. For the grayscale and gamut patterns, we decided to only include equal energy patterns. Similar in concept to the AVS709 Constant APL patterns.
If you liked the first disc, we hope you love the 2nd disc. If you did not like the first disc, you probably will not like the 2nd. There are a lot more advanced patterns and many require some sort of instrumentation.
Not sure what you mean by color band pattern.
I will post an update on Monday on how our testing goes.
realzven
Message » 24 Avr 2013 19:23
realzven
Message » 03 Mai 2013 19:04
Est-ce qu'il fonctionne sur un appareil zone 2 ou il faut un codefree?
lavocat
Inscription Forum: 08 Mar 2012 19:11
Message » 03 Mai 2013 19:16
Il est région free
realzven
Message » 03 Mai 2013 22:17
Thanks !
lavocat
Message » 04 Mai 2013 16:18
Dispo sur amazon et oppo
realzven
Message » 23 Mai 2013 20:49
Commande sur amazone.com, réception fin de semaine ou lundi prochain. :D
Le tarif sur oppodigital.com est identique, pas de surprises !
http://www.oppodigital.com/blu-ray-benchmark/
Meilleures salutations
Pascal+
Inscription Forum: 30 Oct 2009 17:10
Message » 24 Mai 2013 8:57
Pascal+ a écrit:Bonjour à tous,
salut recu semaine derniere tres complet
babar710
Pro-Commercant
Pro-Commercant
Inscription Forum: 11 Aoû 2008 10:43
Message » 24 Mai 2013 11:16
Your Amazon.com order of "Spears & Munsil HD..." has shipped!
Envoyé de mon iPhone à l'aide de Tapatalk
lavocat
Message » 24 Mai 2013 12:56
tu avais le 1er ? moi je vais essayer de le récupérer la semaine prochaine :D
realzven
Message » 25 Mai 2013 9:35
salut oui effectivement j'ai egalement le 1er
babar710
Pro-Commercant
Pro-Commercant
Message » 26 Mai 2013 9:45
Oui, effectivement, le premier volet a permis de régler correctement le 55C8700 datant de 11/2010 à l'aide des nombreuses mires, des deux teintes bleu X1 et X2 et du livret explicatif très complet.
Depuis, les réglages sont restés inchangés, le TV est vraiment agréable à regarder. :D
Même ceux qui n'ont pas ce Blu-ray peuvent à l'aide des mires du TV intégrées au menu, régler leur image dans d'excellentes conditions, ils faut juste avoir cette fameuse paire de lunette teintée en bleu.
Disponibles ou pas sur les modèles ultérieurs ?
Ce deuxième volet, de par ces options complémentaires, va permettre de peaufiner le rendu 3D qui manquait. :wink:
Fin 2015, le TV du moment ira le remplacer par un modèle encore plus performant.
Pascal+
Retourner vers Les logiciels de calibration
