27 messages • Accèder à une page • 1, 2
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: albator91, alexins, ceili-29, cmika78, cyril.edge, daaadou, Davsevelyninmel, delennsheridan, Doudou, Goby92, gwendal55, Hubu, jmkdeb, Jonathan91530, Kevin26, LeBarr, Lobito94, marty_mc_fly, nico7212, NoBiluS, Patbon21500, patriceonkyo, polo2121, seishun, tagadaj, thivame, tony51, VANLUC, vauclair83, vincent59270, wariojp et 169 invités
Dune HD TV-102
Dune HD TV-102 is an ultra compact IPTV/VOD/OTT solution with extended media player functionality offering attractive design, competitive price and high performance, the Dune HD TV-102 is a versatile device for Operators needing large quantities as well as those seeking smaller minimum order requirements. The Dune HD TV-102 is built on the newest and powerful Sigma Designs SMP8674/75 platform and comes equipped with an internal digital tuner for cable and terrestrial TV (T & T2 modifications only).
Key Features
3D Video Format Support: Decodes popular 3D Video formats such as SBS, Top/Bottom.
HDD Player: Plays content from any source (NAS or USB).
Network Player: Connect Dune HD player to a local network and play content directly from PC or NAS via UPnP, SMB, or NFS.
MKV Player: Playback HD and SD video in MKV containers and other modern video file formats, including top quality HD video with very high bit-rates > 50Mbp/s.
USB Ports: Conveniently connect HDDs, USB flash drives, USB card readers and other USB storage devices without a USB hub.
HDMI 1.4: Ensures broad compatibility to the very latest 3D TV’s, displays and projectors.
Full Range of A/V Connectors: Coaxial S/PDIF Audio output, Analog Stereo Audio output, HDMI output, Composite Video output.
High-Quality Music Playback: Plays very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey’s Audio APE, WAV/PCM, etc).
Playlist Support: Build playlists from folders, use your own play lists with repeat and shuffle functions.
Video Output Flexibility: Output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSC).
Video Up-Scaling: High quality up-scaling of DVD and any other SD video content to Full HD (1080p) or other HD resolutions.
File Browser: Convenient file browser with powerful file management (copy, move, delete, rename, organize, sort).
Extra Functions
External NAS Support: Access files on any external storage devices (HDD, optical drive, etc) attached to the player from the local network (using SMB or FTP).
Customizable User Interface: Work with media collections using cover art and icon browsing (supports Full HD graphics).
Flash Applications: Extend player functionality with FlashLite applications.
Internet Radio: Playback and record various Internet radio stations.
IPTV: Playback and record IPTV streams.
Internet Browsing: View Internet web sites on your TV using the built-in web browser.
Specification
Processor: Sigma Designs SMP8674/75
RAM: 512 MB
Flash memory: 256 MB
Media sources: external HDD (USB), external optical drive (USB), USB devices (USB flash drive, USB card reader, etc), PC and NAS in local network (SMB, NFS, UPnP, HTTP), other Internet and local network media sources (HTTP, multicast UDP/RTP), premium streaming video services are fully supported
A/V interfaces: HDMI 1.4 output; analogue A/V output and coaxial SPDIF via mini jack connector (cable adapter required)
IR Extender: depends on modification
Web Browser: Opera, WebKit
DLNA: DLNA (1.5 or 2.0) client support
Adobe Flash: 3.1 (Lite, standalone)
DRM options: PlayReady, Verimatrix, Secure Media. Additional DRM’s available by request
Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264; support for very high bitrate video (up to 50 MBit/s and higher)
Video file formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, DVD-ISO, VIDEO_TS
3D Video Support: Side-by-side, Top/Bottom
Video output modes: wide range of supported output resolutions (up to 1080p) and framerates (including 23.976p, 24p, PAL, NTSC)
Video output framerate: automatic (according to the played content) and manual
Audio codecs: AC3 (Dolby Digital), MPEG, AAC, LPCM, WMA, WMAPro, FLAC, multichannel FLAC, Ogg/Vorbis; support for very high quality audio (up to 192 kHz / 24-bit)
Audio file formats: MP3, MPA, M4A, WMA, FLAC, APE (Monkey’s Audio), WV Pack, Ogg/Vorbis, WAV, AC3, AAC
Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, external SUB/IDX), PGS (TS, MKV)
Picture file formats: JPEG, PNG, BMP, GIF
Playlist file formats: M3U, PLS
Photo viewer functions: slideshow, transition effects, picture rotation, zoom, browse playlist, repeat, shuffle
Audio playback functions: browse playlist, repeat, shuffle, ID3 tags
Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3 (read-write), NTFS (read-write)
Network: 10/100 Mb/s
Wi-Fi: Internal Wi-Fi (b/g/n) module (depending on modification)
DVB: internal cable/terrestrial DVB tuner (depending on modification)
Dune Network Playback Accelerator: special optimizations ensuring best-in-class network playback performance for the Sigma Designs 864x/865x/867x platform and enabling smooth playback of any supported kind of media content via any network protocol (including NFS and SMB) even in 100 Mbit/s Ethernet networks.
http://dune-hd.com/eng/products/full_hd ... players/37
- Christophe CHEREL
- Pro-Fabricant
- Inscription Forum: 06 Juil 2001 2:00
Communiqué de presse :
Following successful launches of new hybrid DVB+IP boxes at ANGA Cable and IFA Berlin, Dune HD will be showcasing end-to-end solutions with middleware partners for OTT, VOD and IPTV operators. Thanks to extensive system integration with established providers, Dune HD will be able to demonstrate flexible and scalable content distribution.
An exciting new range of products for content delivery will include:
TV-102: compact and elegant without feature compromise
TV-203D: hybrid DVB+ IP box with 3D capability
Dune HD Connect: world's smallest Full HD set-top box in the format of HDMI dongle with built-in Wi-Fi and Bluetooth, DVB-C tuner and Z-Wave options.
With rich feature sets including 3D video support and OpenGL hardware acceleration, Dune HD players offer the richest user experience and hence maximise service monetization opportunities.
- Christophe CHEREL
- Pro-Fabricant
j'ai de plus en plus de mal à suivre les nouveautés HDI
Ce sont des produits pour les particuleirs ou finalement ce sont des STB pour des providers ?
- Mr Eric
- Inscription Forum: 19 Mai 2004 10:33
Vu que je ne comprend pas le english je n'ai pas ce problème moi
- JFK
- Inscription Forum: 26 Déc 2001 2:00
Et si on ajoute ça http://www.opera.com/press/releases/2012/08/28/
Même en parlant anglais je comprends plus rien
- Mr Eric
Mr Eric a écrit:Et si on ajoute ça http://www.opera.com/press/releases/2012/08/28/
Le Dune HD TV-102 est un modèle dédié aux opérateurs du câble, de la TNT, du satellite et de télévision par ADSL. On ne sait pas encore si ce modèle sera commercialisé pour le grand public.
- Christophe CHEREL
- Pro-Fabricant
Mise à jour des spec !
- costaud
- Contributeur HCFR 2019
- Inscription Forum: 05 Oct 2004 20:51
Aucune mention d'un eventuel support du DTS, DTS-HD ...
serait ce pour eviter le meme flop qu'avec les Dune HD-101 ?
- benhur_C6
- Inscription Forum: 04 Juil 2010 8:32
cette fois ci c'est clair dès le départ : pas de DTS HD du tout...
- Mr Eric
Toujours aucune nouvelle pour la disponibilité de ce modèle? Je pars en voyage le mois prochain, idéal pour voir mes films sur place. Est-ce que la Tv 101 propose aussi la sortie Spdif? Si c'est le cas j'attends plus!
- Indieke
- Pro-Fabricant
- Inscription Forum: 13 Aoû 2000 2:00
non pour la 101
- costaud
C'est ce que j'avais compris. C'est pour cela que j'aimerais que la 102 sorte par ce qu'elle peut alors aussi être utilisé come jukebox audio avec un bon dac externe!
- Indieke
- Pro-Fabricant
- wool
- Inscription Forum: 13 Oct 2006 21:15
plus je lis les specs moins je comprends ce produit Au final la version HDland n'a même pas le module TNT. Et les specs indiquent HDMI 1.4, mais seulement 3D en SBS/TB pas de MVC. pas de son HD non plus et même pas de DTS simple. C'est quoi l'intéret d'un tel produit par rapport à un mede8er 600 qui n'est que 10€ plus cher, fait la 3D et le son HD ?
- Mr Eric
27 messages
