Marque : Studio Connections (Abbey Road)
Modèle et options : Studio Connections Carbon Power - longueur:1m50
Quantité disponible: 4 3
Prix de vente : 130 € l'unité / 340 € le lot de 3 câbles, 450 € le lot de 4 câbles
Département où la marchandise est visible : 26
Montant des frais d'expédition : Inclus
État de la marchandise : " Etat Neuf"
Première main : Oui
Prix neuf: 230 € l'unité
Facture disponible : Oui
Date et lieu d'achat : Mars 2012 chez Câble Hifi
Site web du constructeur : http://www.studioconnections.co.uk/Power.htm
Célèbres câbles fait sur cahier des charges (par Moving Air) pour équiper les studio Londoniens Abbey Road !!
Utilisant des technologies militaire pour le blindage utilisé.
TUDIO CONNECTIONS ‘Carbon Screen Power Cord’ is a radical new cable that can significantly improve your listening experience, and sets a new reference standard for power cables.
Using an advanced military stealth polymer, ‘Carbon Screen Power Cord’ absorbs mains and airborne interference and converts it into heat (instead of diverting the noise energy somewhere else in the cabling). This drives the noise floor down and immediately stabilises image with a very perceptible enhancement to its realism.
This revolutionary power cord was first shown at the High End show in Munich. Dealers and audiophiles auditioned the cables on Harberth L4 Renaissance system. Bernd Hömke of German Harberth Distributor 'Input Audio' said “ The Carbon Screen Power Cords were a big advantage to our system. It sounded wonderful ”
Nominal Technical Specifications:
Conductors: 2.5mm cross sectional area, 47 x 0.22 strands high purity copper.
Insulation : Brown, Blue, Green/Yellow
Insulation diameter: 3mm over dielectric
Bedding and Primary screen : 100% coverage, Carbon loaded semi-conductor
Drain element: 0.46mm cross sectional area, 3 x 9 x 0.147 strands tinned copper wire
Resistance: Each core: 6.98 ohms/km
Capacitance: Core to core: 100pF/m
Inductance: Each Core: 26mH/km
Rated voltage: 500Vac
Overall diameter; 9.75mm
