Type : Câble HP
Marque : TANNOY - Van den Hul
Modèle et options : Reference speakers cable made by Van Den Hul ( Van Den Hul Inspiration ), 2x2,5m nus.
Prix de vente : 250 --> 215 euros ! --> 180 euros FDPIN !
Département où la marchandise est visible : 38
Montant des frais d'expédition : Inclus dans le prix
État de la marchandise : trés bon état voir photos
Première main : Non
Prix neuf : 120 euros/m soit 600e pour cette paire.
-The stranded signal lines are made of our new developed highly advanced FUSION conductor material and are furthermore embedded in a conductive layer containing our Linear Structured Carbon ®.
-The sonic result is a very detailed signal transmission with a superb spacious character.
-There is no sign of any sonic harshness or lack of definition.
-The jacket and insulation throughout the cable are made of HULLIFLEX ® 4, a very rugged insulation material which provides outstanding protection.
-In The INSPIRATION HYBRID four star quad configured signal lines surround a central ground lead.
-The signal lines are intended to be pairwise combined to form a twin lead loudspeaker cable with a total cross-section area of 2 x 3.94 mm² and a resistance of 2 x 1.4 Ohm/100 m.
-The central ground lead is intended to serve as an optional ground connection between any amplifier and loudspeaker’s ground terminals.
-Next to the signal lines’ star quad configuration and separate ground lead, additional protection against R.F. interference is provided by the cable’s heavy braided screen, which should be grounded at the amplifier side and be left disconnected at the loudspeaker end.
12 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: cliors3 et 4 invités
Baisse à 215e !
- citikab
- Inscription Forum: 20 Fév 2002 2:00
Baisse à 180 euros !!
- citikab
echange possible
- citikab
12 messages
