bobim a écrit:comment fait t'on pour avoir cette librairie ?
http://wiki.jriver.com/index.php/Blu-ray
HD Audio
Media Center is capable decoding the full range of audio codecs used on commercial Blu-ray Discs itself, while preserving their full bitrate and audio depth. This includes HD codecs such as Dolby TrueHD and DTS-HD Master Audio.
We recommend that you use Media Center to decode HD audio because this gives you access to the full power of MC's audio engine, including VideoClock and the DSP. MC will automatically decode TrueHD soundtracks with no other configuration required. Unfortunately, no open decoder currently exists for DTS-HD. However, Media Center has been designed to properly use the decoder included with Arcsoft's TotalMedia Theatre. To decode DTS-HD you need to copy the file:
dtsdecoderdll.dll
From an installation of Arcsoft TMT into:
%APPDATA%\J River\Media Center <VERSION>\Plugins\lav\
(Be sure to replace the text <VERSION> above with the major version number of your copy of Media Center.)
If you prefer, you can also use use one of the following system directories
Windows 32-bit: %WINDIR%\System32\
Windows 64-bit: %WINDIR%\SysWOW64\
En résumer il faut récupérer la dernière version de dtsdecoderdll.dll du soft Arcsoft's TotalMedia Theatre (qui n'existe plus) et la coller dans le répertoire qui va bien.
