patjero a écrit:Beautifull Johnny !!!
Thanks
Digital printing of fronts:
Johnny
Modérateurs: Modération Forum DIY, Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: lyric et 95 invités
franckc2 a écrit:Bonjour à tous,
Quelqu'un aurait il une modélisation de la façade de l'UGS dans un format dxf ou dwx, que je puisse l'importer dans google sketchup et la retravailler.
cdt
Franck
emyeuoi a écrit:Hello Alex,
Merci beaucoup for you reply.
Regarding the FW I uploaded the _v2.3. It's not the latest one?
About the PSU actually I power up the preampli board and the 3 LDOs in the analog side are working. Then I stop and ask you...
I think that with the LDOs on boards a simple 7824/7924 is enough... you agreed?
Thanks again,
Enrico
patroussea a écrit:on y travaille Alex, et ça avance, je vais mettre qq photos bientôt.
je pense que 2 UGS Muse vont bientôt chanter.
Alex_twn a écrit:
Hi Enrico,
The latest FW is the 2.5.
Then if I understand well what you are doing on the PSU side, you must not input 39V to the LDO. They accept MAX 36V if I remember well. On the long term it will stress the devices a lot. Plus the UGS won't like +/-39V.
7824 can work as the regulation stage between 39V and the analog power connectors of the preamp boards but there are better choices considering that you will power the UGS and buffer with this and better regulation stage will help here.
Alex_twn a écrit:Hi Enrico,
It is now on the first page.
I don't remember exactly the consumption on the 24V rails but yes below 50mA.
