Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: _Tiptoe_, Polopretress et 48 invités
Le TOPIC de MadVR (v0.92.17)
Ou la la ... J'suis fatigué moi ... J'avais pas fermé le manager 0.90.21 avant de copier la 0.90.22 ...
- LePousson
- Inscription Forum: 04 Fév 2007 19:53
LePousson a écrit:Ou la la ... J'suis fatigué moi ... J'avais pas fermé le manager 0.90.21 avant de copier la 0.90.22 ...
- Goldfinger67
- Inscription Forum: 18 Nov 2008 15:34
http://madshi.net/madVR.zip
madVR v0.90.23
* updated AdaptiveSharpen to version 2016-07-10
* custom output levels can now be adjusted in 0.25 steps
* HDR: added option to define how to handle too bright & saturated pixels
* fixed: HDR luminance measurements + chroma SuperRes produced green screen
* fixed: #420: chroma was doubled despite being below scaling factor threshold
madVR v0.90.23
- Goldfinger67
madVR v0.90.24
* HDR: improved tone mapping algorithm
* HDR: added gamut mapping compression (instead of clipping)
* HDR: slightly improved luminance vs saturation reduction formula
* HDR: added options to use an external HDR tone mapping 3dlut
* HDR: added option to do HDR processing, but still output PQ
* fixed: measuring HDR luminance + NNEDI3 chroma upscaling sometimes crashed
* compiled OpenCL kernels are now stored separately for 32bit and 64bit
* when using the "ShowRenderSteps" tweak, a smaller OSD font is used now
madVR v0.90.24
- Goldfinger67
Salut, j'ai changé de projecteur, le nouveau est calibré 709. Pouvez-vous me dire ce que ça change de préciser dans madVR que mon diffuseur est calibré 709 ?
- dafunky
- Inscription Forum: 10 Jan 2007 11:39
madVR v0.91.0
* added new NGU (Next Generation Upscaling) algorithm
* added "soften edges" + "add grain" upscaling refinements (atm only for NGU)
* display properties can now also be profiled
Salon: Jvc NZ7, Xtrem 1.1gen2, Lg 77g3, chambre samy 65s95b, Lg 55cs chambre enfant/ source: pana ub9000 +pchc+chinoppo+z1000pro/ 3 Arendal monitor 1723S, 4 Divatech diva18 sur et back, 6 Svs prime elevation atmos/ Denon Avc-a1h/ 2sub arendal 1723 1S
- david555
- Superviseur Forum Univers TV & Contributeur HCFR
- Inscription Forum: 02 Oct 2005 18:13
madVR v0.91.1
* added NGU "low" quality algorithm
* "soften edges" and "add grain" now allow smaller adjustment steps
* fixed: install batch didn't work
* fixed: on some PCs NGU didn't activate
* fixed: on some PCs keyboard shortcuts didn't work
* fixed: NGU grain was static
* "ShowRenderSteps" hack no longer slows down NGU as much as before
* "ShowRenderSteps" hack only slows down stuff as long as the OSD is visible
- david555
Ya moyen de voir un screenshot de ce "NGU"? Histoire que je situe mieux où il se trouve.
- dafunky
dafunky a écrit:Ya moyen de voir un screenshot de ce "NGU"? Histoire que je situe mieux où il se trouve.
Dans les onglets image doubling et chroma upsampling.
- khaos974
- Inscription Forum: 20 Mar 2006 20:46
Vous avez remarqué une différence avec ce nouvel algo?
- JEANBAPT53
- Inscription Forum: 17 Nov 2012 20:53
madVR v0.91.3
* fixed: NNEDI3 doubling could crash in certain situations
* fixed: NGU chroma upscaling didn't allow "veryHigh"
* fixed: SuperRes strength controls were disabled for chroma upscaling
- david555
Je suis surpris de ne pas lire plus de retours sur le dernier madvr (91.3). Il est absolument monstrueux. Une densité d'image et epaisseur que je n'avais pas constaté avant. Le NGU surpasse le needi 3 de loin je trouve.
Ceux qui ne l'ont pas encore installé, je vous encourage a le tester.
- david555
Ca va pas foutre la pagaille avec la confg7 de kaz ?
- kbil69
kbil69 a écrit:Ca va pas foutre la pagaille avec la confg7 de kaz ?
si tu l'installe dans le répertoire madvr/kaz normalment non.
- david555
@david555 Tu l'utilises sur projecteur ou sur ton oled ?
Quelle carte graphique pour le faire tourner ?
- jcben
- Inscription Forum: 03 Avr 2005 16:24
