Si ça peut en aider d'autres : malgré la mise en jour rien ne change.
J'ai donc essayé en local au lieu du wifi car je streamais de mon PC.
Avec une clef USB tous les formats HD passent nickel, le souci vient donc du wifi.
Peut-être pas assez de débit par ce biais pour avoir du 1080p fluide plus du son HD?
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: christian.vuil, DAVEYBROTHERS, kingmalik, malicorne, nico7212, papounay, Polosport, titour66 et 133 invités
Zidoo X8/X9S/X10 RTD1295 (4K60/HDR/BD menu/Control4)
- Meep
- Inscription Forum: 13 Oct 2005 14:17
Mumakil a écrit:Re
Nouveau firmware 1.4.6 dispo ici: http://www.mediafire.com/file/n873p7c2atbrvfy/ZIDOO_X9S_OTA_V1.4.6_20170623.zip
]v1.4.6 for ZIDOO X9S
Updatelist:
System:
1,Fix the issue that flv streaming is not playable.
2,Adjust the accuracy of IR receiver.
3,Fix the error of playback in APE music.
4,Fix the issue that stream get stuck in some streaming apk.
5,Optimize the transmission of USB 3.0.
6,Fix the issue that the sata hard-disk can't be read after the wake-up of box.
7,Fix the unexpected displaying of loading infomation when stream Iqiyi videos.
8,Fix the issue that the box can't be wake up when USB 3.0 is connected with a usb stick.
9,Fix CEC failure after wake up the box.
10,Fix display failure when HDMI IN comes with 1080i video source.
11,Optimize the system stability.
12,Fix the problem in the simultaneity of audio and video in a certain App
13,Improve the compatibility of rtsp and rtmp streaming
14,Fix the black screen problem occasionally happens to a certain App
15,Fix the error happens to continuous switching channels in a certain App
16,Fix the failure to get audio tracks from online videos by system video player
17,Fix the black screen occuring to some receivers when the Deep Color is set to Auto , Color Space is YCbCr444 and resolution is 4K@23.976 in the meantime.
18,Fix the problem unexpected reboot during standby mode
19,Nuplayer support Dolby and DTS passrough(Online stream)
App:
VideoPlayer:
1,Improve the experience of operating progress bar.
2,Fix the reading issue of BDMV titles.
3,Optimize the shortcut keys for switch audio tracks and subtitles.
4,Fix the issue that some subtitle can't be download.
5,Fix the issue that some subtitle can't be displayed properly.
6,Fix the issue some mkv files display two subtitles at the same time.
7,Fix the malfunction of bookmark.
8,Improve the playback of UHD bluray movie.
Musicplayer:
1,Fix the listing information of some APE and FLAC can't be read out.
2,Fix the failure to fetch the singer information for some songs.
3,Display the CUE list playing
4,Save the song played last time and it’s process.
5,Add CUE support for WAV and DTS.
QuickSettings:
1,Add a Auto23.976/24 for 4K switch
2, Add a switch between Nuplayer and Dvdplayer for online videos playback
File manager
1,Improve some translation
2,Fix the malfunction of classification.
Blu-Ray:
1,Fix the movie don't pause when press the OK key for the first time in the playback.
Shortcut key
1,Add delete key and multitasks function
Theater
1,Fix the problem the videos won’t be played if you add a root path of NFS.
Openwrt:
1,Support more languages.
Est il compatible avec le X10 ?
- darnak
- Inscription Forum: 24 Fév 2002 2:00
@darnak: non, surtout pas, pour le X10, il te faut cette version là:
v1.4.6 for ZIDOO X10: http://www.mediafire.com/file/1oyr26k1etmow24/X10-v1.4.6-20170624_ota.zip
- ymlik
- Inscription Forum: 16 Mai 2008 13:42
Meep a écrit:Si ça peut en aider d'autres : malgré la mise en jour rien ne change.
Le wifi en streaming hd et uhd, c'est possible à condition d'avoir un routeur avec un très bon débit. Il existe plusieurs norme en WiFi. Vérifie ton débit. Sinon passe par un câble ethernet.
- Zippo77
- Inscription Forum: 03 Aoû 2004 16:54
ymlik a écrit:@darnak: non, surtout pas, pour le X10, il te faut cette version là:
Super merci beaucoup
- darnak
roromimi ton lien Kodi apk ne fonctionne pas.
Merci ymlik.
Merci ymlik.
- ryback64
- Inscription Forum: 31 Jan 2010 9:53
ryback64 a écrit:roromimi ton lien Kodi apk ne fonctionne pas.
Merci ymlik.
http://ota-cloudfront.zidoo.tv/X9S/ZDMC ... 3_siga.apk.
Mille excuses
- roromimi
- Inscription Forum: 06 Juin 2008 19:23
Tout fonctionne nettement mieux avec le dernier firmware et ZDMC 17.1 . Merci.
Quel est le scraper recommandé pour les séries svp ?
- ryback64
J'ai trouvé pourquoi j'avais 95 film sur 330 de trouvé, les autorisations ont disparu, certaine vidéos celles trouvé sont en état partagé, Comment avez vous réglé le fichier où ce trouvent vos films pour que ZDMC le trouve avez vous été obligé de mettre vos fichier en autorisation tout le monde? Merci je galère :/
- Bastien50
- Inscription Forum: 01 Mar 2017 11:04
Zippo77 a écrit:Meep a écrit:Si ça peut en aider d'autres : malgré la mise en jour rien ne change.
Merci pour ces infos.
J'ai la livebox noire d'orange...
- Meep
des feeds de ce nouveau firmware ?Mumakil a écrit:Re
Avec un peu de chance une nouvelle version de ZDMC va suivre...
- SpaceFire
- Inscription Forum: 27 Fév 2007 22:05
SpaceFire a écrit:des feeds de ce nouveau firmware ?Mumakil a écrit:Re
Bah écoute, je te dirais rien de spécial.
Si ce n'est le switch de changement de fréquences plus rapide. C'est "presque" (je dis bien presque) aussitôt le lancement du film.
Avant le film se lançait et le switch se faisait après. Mais tout ça reste reste très subjectif.
Sinon ils ont résolu le bug avec les ports USB 3. Les disques n'étaient pas forcément bien reconnu....
Je n'ai pas pu tester les sous-titres SRT et leurs problèmes de balises. Mais à ce que j'ai lu sur le forum Zidoo, le problème est toujours là.
Pour le reste, appli/HDMI iN/....je ne m'en sers pas donc....
Pour ZDMC 17, c'est toujours la version bêta et je n'ai pas vu de news pour l'instant. Mais ils ne devraient pas tarder à sortir une nouvelle version (enfin j'espère )
- Mumakil
- Inscription Forum: 20 Juil 2014 18:07
Pourquoi les nouvelle version pour la box ne sont pas en ligne? Quand je fais mise a jour en ligne je suis a jour en 1.2??
- Bastien50
Bonjour peuple du continent zidoo
Je rencontre un petit problème , en effet j'ai l’impression que le zidoo x9s ne lit pas les fichier complete uhd 4k car il me met un message d'erreur : cannot read this file.
ou bien le zidoo x9s ne peut lire que les rip de fichier 4k.
Merci de votre réponse si il y en a une qui existe.
- akongalsen01
- Inscription Forum: 27 Aoû 2016 14:32
l'autoframerate n'est plus fonctionnel chez moi avec les films 1080p/720p avec le firmware 1.4.6 , tu m'étonnes que le film se lance plus rapidement...
Vous avez fait le mème constat ?
- SpaceFire
