Enfin annoncé!
Nakamichi AV1 Pre-Pro Owners' Thread
IOTAVX™ 7.1 4K / HDR HOME THEATER PROCESSOR SPECIFICATIONS
- Six HDMI inputs, three of which are full 4K UHD HDR Video
- Optimized analog and surround sound audio circuitry
- Support for all current 5.1 channel and 7.1 channel surround sound formats, including Dolby
Digital, Dolby TrueHD, Dolby Pro Logic IIx/z, DTS, DTS-HD Master Audio, DTS Neo:6, S/PDIF and multi-channel PCM digital audio.
- High-quality headphone amp
- Full function infrared remote control, front panel navigation buttons
- Advanced automatic multi-channel room correction and loudspeaker setup with a calibrated
microphone with internal buffer amplifier included
- Last video memory, which allows you to view one source while listening to another
- Video-on-standby, which can be configured to send audio and video to the display even when
the AVX1 is in standby mode
- Flexible quadruple bass management, with 12dB or 24 dB per octave crossover filters,
configurable in precise 5 Hz steps below 80 Hz (and 10 Hz steps above 80 Hz), helps you get
the best bass performance from virtually any room and subwoofer.
- Eleven user-programmable fully parametric equalizers per channel.
- Optional Bluetooth 4.0 module with Apt-X™ Support
- Balanced and unbalanced outputs provide additional options for long cable runs
- High-efficiency, low noise, universal voltage switch mode power supply
- Firmware updates are carried out using a USB stick
- Full IOTAVX two year warranty, 30-day return policy.
700 £ - 800 €
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: boddhidarma, Fre.Mo et 73 invités
IOTA VX, Préampli HD 7.1 4K (ex Nakamichi)
Bon ça reste Tonewinner comme d'hab :
http://www.futureland.fr/ampli-pre-ampli-hc/36567-nuprime-hd-avp.html
Mais en nettement moins cher.
A voir donc si c'est du HDMI 1.4 ou 2.0 (le Nuprime n'est que 1.4)
[EDIT] J'ai pas bien regardé la photo, 3 prises sont labélisées HDCP 2.2, elles sont donc en HDMI 2.0
Dommage il y a moins de connections, pas d'input 7.1 on dirait, moins d" entrées coax opt.
Atmos absent (pas important pour moi mais c'est plus vendeur).
Pas de date annoncée ?
- hounddog
- Inscription Forum: 24 Oct 2000 2:00
Pas de date encore, je pense que c'est le premier proto...
Salut domin et merci pour l'info.
Pour moi il propose un produit taillé pour tenir dans le temps au niveau des spécifications. Reste juste à savoir s'il supportera le HDMI 2.1 via mise à jour ou non. Mais c'est un détail.
Pour le reste je le trouve complet excepté le seule prise trigger out où il aurait été bien d'en avoir au moins deux (pour l'ampli et le caisson).
C'est une évolution de l'AV1 avec support de l'HDMI 2.0 / HDCP 2.2 et 2 sorties HDMI.
S'ils pouvaient le sortir à un tarif aussi bas que l'AV1 à ses débuts ce serait super et très tentant.
Perso, l'absence du Dolby ATMOS n'est pas un problème bien au contraire ça évite de faire grimper la facture pour rien.
A+.
A+.
- Syrius
- Inscription Forum: 20 Mai 2008 17:34
Pas de grande révolution ...
- kbil69
Tu attendais des choses en particuliers ?
Je trouve que ça semble être une bonne évolution de l'AV1. Ils restent dans la même optique, un processeur audio 7.1 qui va à l'essentiel et qui le fait bien (sous reserve que celui ci soit au moins aussi bon que l'AV1).
- Syrius
Pas forcement, à voir avant de juger
- kbil69
Tout à fait, on ne peut juger du résultat qu'une fois testé.
Sur le papier et donc les spécifications il est bien. Reste à transformer l'essai.
- Syrius
Moi ca me plait , 6 hdmi IN, 2 Out , dommage pour l'augmentation du tarif ...
Sait on les composants utilisé ?
- stephblues57
- Inscription Forum: 25 Nov 2011 17:01
Je pense que pour ceux qui ont le AV1 le gap n'est pas intéressant, à moins de vouloir absolument le HDMI 2.0 / HDCP 2.2
- kbil69
géniale enfin annoncée
- gabi65
- Inscription Forum: 01 Mai 2013 18:45
Une excellente nouvelle...
J'attends un premier test...avant de jouer au "early bird"...
- seb8
- Inscription Forum: 05 Oct 2003 2:43
Pas de révolution c'est juste l'implémentation du 4k
- patjero
- Inscription Forum: 17 Sep 2003 2:34
£700 ça fait à peu près 800€ en ce moment.
A ce prix on peut trouver un Marantz SR6011 qui a des sorties préampli en plus de son amplification, propose du 9.2, du HDMI 2.0a, des possibilités d'ATMOS et de l'Audyssey XT32
Du Coup, quel intérêt vous voyez à ce IOTAVX ?
- Fyper
- Inscription Forum: 13 Juil 2005 18:05
