Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: AxleM, bab1c, Bello78, BoBJeJ, DAVEYBROTHERS, ean27, Francois10, gamerone2008, Gaël, Gia59, jcre17, Knives86, Kristo13, Laurent91, Lobito94, mediacloud, Miky10, minifrix, misichavichus, nico7212, noyel, oliver60, PlaTiNe-38, Roby28, Scream, Solitaire555, sylvain-best, thieb_p, Tommyknockerz99, tony51, vddan, videoman, Viny0169 et 250 invités
Beelink GT1 Ultimate DDR4 3G 32G Amlogic S912 + clavier rii
Bonjour a tous,
Un fil de discussion pour vous présenter le boitier android box Beelink GT1 Ultimate DDR4 3G eMMC 32G fonctionnant sous Amlogic S912 Octa Core CPU Android 7.1
http://www.bee-link.com/Beelink-MiniPC-TV-BOX-61-1.html
Specification
General
Brand: Beelink
Model: GT1 Ultimate
Type: TV Box
GPU: ARM Mali-T820MP3
System: Android 7.1
CPU: Amlogic S912
Core: 2.0GHz,Octa Core
RAM: 3G RAM
RAM Type: DDR4
ROM: 32G ROM
Max. Extended Capacity: 64G
Media Supported
Decoder Format: H.263,H.264,H.265,HD MPEG4
Video format: 3D,4K,AVI,DAT,H.265,ISO,MKV,MP4,MPEG,MPEG-1,MPEG2,MPEG4,RM,WMV
Audio format: AAC,DTS,FLAC,MP3,OGG,RM,WMA
Photo Format: GIF,JPEG,JPG,PNG
Support 5.1 Surround Sound Output: Yes
Product Details
5G WiFi: Yes
Bluetooth: Bluetooth4.0
Power Supply: Charge Adapter
Interface: DC 5V,HDMI,LAN,Micro SD Card Slot,SPDIF,USB2.0
Language: Multi-language
HDMI Version: 2.0
Other Functions: DLNA,ISO Files,Miracast
Firmware Information
System Bit: 32Bit
Power Requirement
Power Type: External Power Adapter Mode
Battery Information
Remote Controller Battery: 2 x AAA Battery ( not included )
Dimension and Weight
Product weight: 0.1930 kg
Package weight: 0.4430 kg
Product size (L x W x H): 9.60 x 9.60 x 1.60 cm / 3.78 x 3.78 x 0.63 inches
Package size (L x W x H): 17.30 x 13.90 x 5.40 cm / 6.81 x 5.47 x 2.13 inches
Package Contents
Package Contents: 1 x Beelink GT1 Ultimate TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual
caractéristique complet ici
ce boitier accepte tous les formats sans pb avec kodi
la qualité vidéo est aussi très bonne,
pour info, j'avais avant un boitier popcorn A400 avec traitement vidéo VXP( une référence) et un Vidéoprojecteur, et je n'ai pas vu de différence concernant la qualité vidéo quand je suis passé avec la GT1
les produits de ce fabriquant on l'air d'être suivi, les mise à jours ce font via internet automatiquement en plus
configuration de la box sous android si vous la faites tourner sous android ce que je ne recommande pas, voir plus bas
pour avoir des vidéos fluides avec kodi, il faut activer l'autoframe, vous aurez besoin d'ajouter l’extension "script.video.fswitch-2.0.6.zip" à kodi, surtout n'activé rien d'autre concernant l'autoframe dans kodi et dans android
https://github.com/jeff2900/Kodi.AmLogi ... r/releases
pour l'activer, il faut
allez dans les extensions de kodi
installer depuis un fichier zip
installer depuis un dépot
allez dans mes extensions
démarrer le service
pour éviter les pb de pause dans kodi pendant une lecture, il faut configurer le buffer, avec l’extension "plugin.program.advancedsettings"
c'est aussi très facile,, il suffit de suivre ce tuto par exemple
http://atlasweb.net/comment-augmenter-l ... -sur-kodi/
et vous voilà avec un boitier qui peux rivaliser avec les meilleurs pour la vidéo (zidoo, nvidia shield,zappiti, véro,....) pour la modique somme de 65 euros environ, car il est possible de trouver des réductions sur le net
https://www.gearbest.com/tv-box/pp_6075 ... 8mEALw_wcB
sinon j'utilise un clavier rii mini i8 + azerty acheté 17 euros (après quelque mois d'utilisation de cette box, je n'utilise plus se clavier, je trouve qu'il ne sert à rien, la gestion de la box avec la télécommande d'origine quand la box fonctionne sous librelec ou coreelec est tellement bien faites)
https://fr.aliexpress.com/item/2-4Ghz-R ... 0.0.NTtc0d
il fonctionne impeccable, très agréable au toucher car il est entièrement recouvert d'une matière "gomme",
il réagit au doigt et à l'oeil
même le tactile est bien conçu, car d'un coup on peut faire toutes les distance de la tv(55"), car il gère l'accélération
pour la distance, c'est limite quand le capteur est caché derrière la box, mais quand il est branché sur le coté on dépasse les 5 mêtres
caractéristique complètes ici:
http://www.riitek.eu/FR/Produits/RT-MWK08RF_FR.html
voici un 2 tuto pour passer ce boitier sous linux avec l'appli kodi, le saint Graal si vous voulez avoir une box stable, qui n'a rien à enviez au box premium!!!
1°tuto pour mettre libreelec sur une carte SD(1 giga suffit), il est plus facile à mettre en place pour les débutants
ce tuto est valable pour énormément de boitier, il suffira juste de changer les fichiers de configurations
https://forum.libreelec.tv/board/38-amlogic/
du coup au démarrage, on arrive directement sous kodi
il y a une meilleur réactivités du boitier
et l'autoframme est activé par défaut
et les vidéos sont plus fluide
le principe c'est mettre un iso de linux avec l'application kodi sur un micro carte sd x10 d'1 giga mini(si votre système saccade ou est lent, c'est que votre carte SD, n'est pas assez rapide ou compatible avec ce boitier)
le boitier démarre sur cette carte par défaut
si vous souhaitez revenir à android:
-sois vous retirez la carte et redémarrer le boitier
-sois vous redémarrez le boitier en choisissant mémoire interne
on commence
télécharger le logiciel LibreELEC.USB-SD.Creator d'installation ici
https://libreelec.tv/downloads/
télécharger l'image linux avec kodi ici
https://github.com/wrxtasy/LibreELEC.tv/releases/download/8.2.4.1/LibreELEC-S912.arm-8.2.4.1.force.444.10bit.img.gz
télécharger le fichier de configuration mémoire et connexion réseau ici
ATTENTION: normalement, il faut utiliser ce fichier(3 giga de ram)
https://kszaq.libreelec.tv/s912/8.2/dev ... 200_3g.dtb
mais dès fois c'est des 2 giga(fake ram), utiliser celui ci
https://kszaq.libreelec.tv/s912/8.2/dev ... 200_2g.dtb
si jamais la box ne démarre pas ou si vous avez un autre type de box
voici un lien pour avoir tous les fichiers de configurations
https://kszaq.libreelec.tv/s912/8.2/device_trees/
insérer la carte sd dans votre ordi
démarrer le logiciel LibreELEC.USB-SD.Creator
cliquer sur choisir le fichier
et sélectionner le fichier LibreELEC-S912.arm-8.2.4.1.force.444.10bit.img.gz
et cliquez sur écrire
il ne vous reste plus qu'à renommer le fichier de configuration gxm_q200_3g.dtb en dtb.img et de le mettre sur la carte sd, il remplacera un fichier
voilà la manipulation est fini
mettez la carte sd dans la box
appuyez à l'aide d'une aiguille sur le micro switch qui se trouve sous la box et brancher la en même temps
et c'est partie
si jamais la box ne veut pas démarrer sur la carte sd ou si vous n'avez pas le micro switch ce qui est le cas sur certaine marque de box
le programme "Reboot to LibreELEC" sous android peux démarrer la box automatiquement sur la carte sd
https://play.google.com/store/apps/details?id=me.thomastv.rebootupdate&hl=fr
2°tuto pour mettre coreelec sur une carte SD(1 giga suffit, si votre système saccade ou est lent, c'est que votre carte SD, n'est pas assez rapide ou compatible avec ce boitier), réservé pour les experts, c'est le nec plus ultra, les mises à jours sont automatiques et régulières
sites officiel ici
https://coreelec.org/
1- Télécharger le fichier "-s912.img.gz" d'installation de Coreelec ici : https://github.com/CoreELEC/CoreELEC/releases/
2- Télécharger le fichier de la télécommande GT1 Ultimate d'origine ici: https://forum.libreelec.tv/core/attachm ... k-gt1-zip/
pour d'autre fichier de télécommandes c'est ici que ça se passe
https://www.dropbox.com/sh/w60gx2c66rpm ... EGcVa?dl=0
3- télécharger rufus qui formatera votre carte sd, et installera correelec
https://rufus.ie/
4- mettre la carte sd dans un lecteur de votre ordinateur
ouvrir le programme rufus,
cliquer sur sélectionner
aller chercher le fichier "xxxxxxxxxx-s912.img.gz" d'installation de Coreelec
cliquer sur démarrer
5- fichiez configuration(mémoire, carte réseau,...)
ouvrez la carte sd sur votre ordinateur
allez dans le dossier "device_trees"
prenez le fichier de notre box "gxm_q200_3g.dtb"
mettez le à la racine de la carte sd
supprimez le fichier "dtb.img"
et renommez le fichier "gxm_q200_3g.dtb" en "dtb.img"
si jamais votre box ne fonctionne pas correctement (pas de réseau, pas de démarrage,....), il faudra prendre un autre fichier de configuration
voici la correspondance des fichiers avec les autres box
https://discourse.coreelec.org/t/which-dtb-do-i-use/389
si la box démarre correctement mais vous vous retrouver avec une fenêtre de CoreElec ouverte sur la page d'accueil de Kodi, et impossible de la virer!!
refaire l'installation et valider la langue "English"
6 mettez la carte sd dans la box
et c'est partie
7- à ce stade votre box à du démarrer sur kodi correelec, sauf que votre télécommande d'origine ne fonctionne pas, c'est normal
il faut insérer le fichier de télécommande dans la box
pour ce faire, la box ayant démarrer
retourner sur votre ordinateur
ouvrer l'explorateur de fichier
et dans l'adresse du haut saisissiez l'adresse IP de la box :
\\xxx.xxx.x.xx
vous avez accès à tous les fichiers linux de la carte sd de correlec
mettez le fichier "beelink_gt1" dans \\xxx.xxx.x.xx\Configfiles\rc_keymaps
mettez le fichier"_maps.cfg" dans \\xxx.xxx.x.xx\Configfiles
8- après un redémarrage elle sera fonctionnelle
Specification
General
Brand: Beelink
Model: GT1 Ultimate
Type: TV Box
System: Android 7.1
CPU: Amlogic S912
RAM: 3G RAM
RAM Type: DDR4
ROM: 32G ROM
Media Supported
Product Details
5G WiFi: Yes
HDMI Version: 2.0
System Bit: 32Bit
Power Requirement
Battery Information
Package Contents
démarrer le service
on commence
et c'est partie
sites officiel ici
https://rufus.ie/
et c'est partie
\\xxx.xxx.x.xx
- monfiston
- Inscription Forum: 11 Nov 2002 19:35
J'ai lu que seule les puces s912-H pouvaient décoder l'audio HD.
Est ce que la GT1 Ultimate décode l'audio HD, DTS-HD et TrueHD Atmos ?
- benhur_C6
- Inscription Forum: 04 Juil 2010 8:32
Qu'en est-il de la compatibilité Netflix et Molotov TV ?
- ryback64
- Inscription Forum: 31 Jan 2010 9:53
C'est Android donc à priori compatible, au pire avec installation d'apkryback64 a écrit:Qu'en est-il de la compatibilité Netflix et Molotov TV ?
Envoyé de mon SM-N910F en utilisant Tapatalk
Enceintes : JBL Pro (3677*3/8330*2/8320*4/3635*2) ; Ampli AV : Denon 6700, Yamaha P3500S, 12*UCD400
Lecteurs : DVL909 - OPPO 103EU - Xbox One X - PCHC-madVR - Projecteur : EPSON 9400 - Stockage : Netgear RN316 23To
.... Le tout piloté par Jeedom :-)
- Patou100
- Inscription Forum: 16 Juin 2001 2:00
[quote="benhur_C6"
Est ce que la GT1 Ultimate décode l'audio HD, DTS-HD et TrueHD Atmos ?[/quote]
oui, car j'ai bien DTS-HD et TrueHD Atmos achiché sur mon ampli home cinéma avec mes films, via la connexion hdmi ou (optique)
- monfiston
ces appli fonctionnent, je n'ai pas testé molotov TV, mais pour Netflix, ça sera juste la version tablette, pas la version HD ni 4K
- monfiston
Pas de problème d'image sombre? Ca me fait ça avec une K12 Pro (Androïd 6.0.1 et non Androïd TV, S912) sur Netflix, Motov et autres.
jazzliberator - Membre HCFR
- Inscription Forum: 10 Mai 2008 21:24
Non, mais je n'utilise pas ces application
- monfiston
Dommage.
monfiston a écrit:[quote="benhur_C6"
oui, car j'ai bien DTS-HD et TrueHD Atmos achiché sur mon ampli home cinéma avec mes films, via la connexion hdmi ou (optique)[/quote]
à non pas de son hd sur l optique chère monsieur
- oolivier
- Inscription Forum: 18 Fév 2006 17:43
yes, j'avais zappé la subtilité
mais je confirme que via hdmi j'ai bien du DTS-HD et TrueHD Atmos
- monfiston
Qu'en est-il du clavier (si tu en utilises) ? Réaction, distance ...
- 974eric
- Inscription Forum: 08 Mai 2007 16:00
Je reçois mon clavier rii azérti la semaine prochaine
Mais, j'ai réalisé toute la configuration de la box avec la télécommande d'origine
- monfiston
Pour avoir eu le modèle précédent, Beelink MXIII, je n'utilise pas Netflix mais Kodi fonctionne très bien. Par contre avec Molotov TV il y aura des contraintes.
Explications: la version de Molotov dispo sur le play store est la version android pour mobiles, pilotable en tactile. Et donc certaines actions ne seront pas accessibles avec la télécommande. Il faudra ajouter un clavier avec touchpad pour profiter entièrement de Molotov.
Le mien était celui-là: https://www.amazon.fr/Geartist-G3-Wirel ... ox+android
Une autre option sans avoir besoin d'un clavier, est de récuperer l'apk Android TV (qui est un android conçu pour la télévision, c-a-d pilotable entièrement avec une télécommande). Lien dispo dans cet article: http://www.frandroid.com/android/androi ... android-tv
Comme je suis passé par les deux versions, je préfère de loin la dernière.
- Elric17
- Inscription Forum: 08 Juin 2015 16:49
Hello,
Ca fonctionne Bein sport connect sur votre Beelink, sur ma Leelbox M8S Pro ça marche pas.
Penser à la fonction"Rechercher"
search.php
Bernard
bgb - Modérateur Haute-Fidélité
- Inscription Forum: 22 Fév 2005 21:57
