The IDT Vida processor also features 14-bit internal processing.
Features
Advanced noise reduction
The powerful HQV noise reduction algorithms use advanced adaptive motion, power and spatial estimation techniques to selectively reduce image artifacts. The following noise reduction algorithms are available:
• Temporal noise reduction (TNR)
> Film grain, random noise and sensor noise
• Block artifact reduction (BAR)
> Block Artifacts caused by over compression
• Mosquito noise reduction (MNR)
> Noise around the edges of objects due to compression losses
Motion adaptive video processing
• Four-field, motion adaptive, de-interlacing
• Multi cadence support
• Adaptive motion processing for trick-mode play and poor quality video
Scaler and resolution enhancement
• Edge-adaptive up-scaling
• Per-pixel resolution enhancement
• Support for wide, zoom and non-linear panoramic scaling
Adaptive contrast enhancement
• Optimizes image dynamic range
• Improves black and white level detail
Advanced color support
• 12-bit color space conversion on input and output
• 12-bit color Gamma conversion
• xvYCC/custom display color gamut mapping
• Full 6-axis hue and saturation control
• Hue, saturation, brightness and contrast (HSBC) adjustment
High bandwidth input and output
• 36-bits/pixel deep color input and output
• Input and output resolutions up to a maximum of 1920 x 1080p at 60 Hz (video) and
1920 x 1200 at 60 Hz with reduced blanking (graphics)
System support
• No external DRAM memory or Flash required
• Integrated micro-controller
Packaging
• Compact 128 pin TQFP package
Part number
• IDT VHD1900EVG
Applications support kit
• Vida video processor evaluation board
• PC based configuration software
• Complete user’s guide
• Reference schematics
Fiche produit : http://www.idt.com/products/getDoc.cfm?docID=18698618
Annonce produit 22 juillet 2009 : http://files.shareholder.com/downloads/ ... eneral.pdf
+ d'info http://translate.google.fr/translate?u= ... =&ie=UTF-8 (traduction japonais---->anglais)
14 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: hdseraf et 19 invités
HQV® Vida™ Advanced Video Processor
- Fichiers joints
- HQV-Vida.jpg (32.71 Kio) Vu 4247 fois
- Idematoa
- Inscription Forum: 10 Déc 2006 13:59
Ce serait plus une remplaçante du Reon VX ? Quand on regarde le prix : 25$ par 1000 Comme quoi le soft ça coute cher !
- deuch
- Inscription Forum: 08 Mai 2000 2:00
deuch a écrit:Ce serait plus une remplaçante du Reon VX ? Quand on regarde le prix : 25$ par 1000 Comme quoi le soft ça coute cher !
C'est l'intelligence associée qui coûte chère en heure de développement...
- Idematoa
On verra qui l'exploitera et comment !
HQV - Matchbox
Info: (Prototype) : http://blog.ultimateavmag.com/ces2010/idt_hqv_matchbox/
- Fichiers joints
- HQV-Matchbox.jpg (15.27 Kio) Vu 3977 fois
- Idematoa
A 100 usd, intéréssant de tester
- BA
- Inscription Forum: 10 Mar 2000 2:00
Ouaip !
- Idematoa
On a une idée de la dispo d'un tel joujou ? Ca paraît presque trop beau pour être vrai ? Quel serait l'intérêt d'acheter des sources avec des puces hqv ou autres plutôt qu'un lecteur bas de gamme avec ça derrière ? Etrange comme positionnement... Mais nickel pour les consommateurs.
Ciao
Fred
Ciao
Fred
- frederikk
- Inscription Forum: 05 Avr 2001 2:00
Demonstration Vida
Lien : http://translate.google.com.br/translat ... =&ie=UTF-8 (Japanese > English)
- Idematoa
IDT : des chipsets pour conversion 120 et 240 Hz
- Fichiers joints
- 10257-4.jpg (19.45 Kio) Vu 2805 fois
- Idematoa
Une application dans l'ampli 7.2 RX-V2067 de Yamaha... http://www.audiovideohd.fr/actualites/6 ... V2067.html
- Idematoa
Je préférerais une application dans un scaler
Des nouvelles pour la dispo du boitier ?
- Frenshprince
- Inscription Forum: 19 Mar 2008 12:30
14 messages
Retourner vers Processeurs Vidéo |
