hé hé
MP1 Specifications:
FREQUENCY RESPONSE: Line: +0-1dB, 0.1Hz to 40kHz at rated output. -3dB points below 0.06Hz and above 70kHz.
DISTORTION: .01% at 2V RMS Balanced output.
GAIN: Main Output: 15dB Balanced, 9dB SE. Tape Output: 0dB. Processor Output: 0dB Balanced.
INPUT IMPEDANCE: 150K ohms Balanced, 75K ohms SE, Inputs (7): MC1 (SE), MC2 (SE), MC3 (SE), CD, STEREO 1, 2, 3 (BAL, SE).
OUTPUT IMPEDANCE: 400 ohms Balanced; 200 ohms SE Main, 10K ohms minimum load and 5000pF maximum capacitance. Outputs(3): 6 Main Bal, 6 Main SE, 1 Recrod SE.
OUTPUT POLARITY: Non inverting.
MAXIMUM INPUT:14V RMS maximum Balanced. (7V RMS SE).
RATED OUTPUTS: 2V RMS (iV RMS SE) into 200K ohm Balanced load (maximum Balanced output capability is 12V RMS at 1% THD at 1kHZ).
CONTROLS: Volume (104 stesp), Power, Mute, Proc, Mult 1, Mult 2, Mult3, CD, Stereo 1, Stereo 2, Stereo 3. All function on Remote Control.
POWER SUPPLIES: Electronically regulated low and high voltage supplies. Automatic 45-sec. warmup mute. Automatic brown-out mute.
NOISE: 35uV RMS residual IHF-A weighted Balanced noise output with gian control at minimum. (95dB below 2V RMS output).
POWER REQUIREMENTS:100-135VAC 60Hz (200-270VAC 50/60Hz) 90 watts maximum.
DIMENSIONS: 19" (48 cm) W x 6.97" (7.6 cm) H x 15"(37.9 cm) D. Handles extend 1.50" (3.8 cm) forward of the front panel
WEIGHT: 20.4 lbs. (9.2 kg) Net; 33.6 lbs. (15.2 kg) Shipping.
4 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: antiloop64, CCOPERE, Claramide, Gaël, invictus, Kuragari, patator_57, Rookie57, sankas13, Sarah Connor, Sibara, stephn666 et 219 invités
Audio Research MP1 Multichannel Preamplifier
- Camocim
- Inscription Forum: 21 Déc 2001 2:00
Une petite idéee sur l'ordre de grandeur du prix ???
- FRED 75
- Inscription Forum: 28 Juin 2002 13:59
Déplacé sur hi-fi à la demande de l'auteur.
- ajds
- Inscription Forum: 02 Fév 2000 2:00
Quelqu'un aurait acheté et testé , écouté ce preampli multicanal ? Je trouve qu'avec des machines comme le Pioneer LX91 à sortie analogique, il peut prendre tout son sens. Merci de vos avis
Vends : des cables XLR et des cables HP : Synergistic Research, Tellurium, JPS Labs, Sine
- Abascal
- Inscription Forum: 09 Avr 2005 9:30
4 messages
