Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Andréiko, Auric, DOLBY ONE, e.big, Gyves, JeanLuc974, methodman, moglo, vinsize, zeh et 222 invités
changement ampli avec enceinte cabasse.
Message » 04 Mai 2005 17:07
Si tu veux évoluer attend la nouvelle bête de course d'arcam AVP700 + P1000.
C'est un Preamp/Proc + ampli séparé dans la gamme diva qui doit sortir cet été normalement.
Là c'est une bonne raison pour changer un AVR300.
Sinon, ton AVR est-il à jour ?
il parait que le nouveau logiciel corrige pas mal de bugs !
AVP700 Home Cinema Processor - Technical Specifications
Analogue Audio
• Audiophile quality components for best sound quality, including 1% metal film resistors, polypropylene film capacitors, OSCON electrolytic capacitors & double sided, through-plated fibreglass circuit boards
• Balanced & Unbalanced pre amp outputs for all 7 channels and subwoofer
• Multi-channel 7.1 analogue input for DVD-A or SACD sources
• Stereo direct switch bypasses and disables all digital processing for 2 channel analogue sources
• 7 stereo analogue inputs (plus tuner); 3 tape outputs (one a tape loop)
• Zone 2 stereo audio, from stereo analogue inputs or internal tuner. Source and volume control independent from main outputs
• Built in FM/AM RDS stereo tuner with 30 FM and 16 AM presets
Digital Audio
• State of the art Crystal Semiconductors CS49400 DSP, with 24-bit fixed point double precision Dolby Digital and DTS decoding and 32-bit fixed point double precision bass management. 4 layer PCBs
• Wolfson Microelectronics 24-bit 192kHz DACs, stereo ADC and precision electronic volume controls
• Decodes Dolby Digital EX, Dolby Pro Logic IIx (including full music mode support), DTS 96/24, DTS-ES Discrete and Matrix 6.1, DTS Neo 6
• 6 Arcam-optimised surround effects modes for 2 channel sources
• Adjustable crossover switching from 40 – 130 Hz in 10 Hz steps
• Separate sub woofer level settings for film and stereo listening
• Bass and treble equalizers, both global and for each of 7 main channels
• 6 fully assignable digital inputs, 3 co-axial, 3 optical; 1 coaxial & 1 optical output
• Assignable global audio delay, adjustable from 0 – 220 milliseconds, to compensate for video processing delays in digital displays or DVD players
Video
• 2-way HDMI switching, HDCP compatible
• 5 composite and 5 S-video inputs; 3 fully buffered outputs of each type
• 3x HDTV compatible component video inputs and 1 monitor output (these may alternatively be configured to support RGB, with sync on composite video, for use in European TV systems
• Video up conversion – composite to S-video and vice versa via the monitor outputs; composite and S-video to interlaced component video
• Video up conversion to RGB with sync on composite (SCART compatible) for European TV displays. 12V triggers support S-video, RGB and widescreen switching for SCART equipped TVs.
• Composite and S-video inputs assignable to “non video” audio inputs
• High quality (component / RGB) inputs each assignable to any audio input
• Zone 2 composite video output, from composite video inputs
Custom Install features
• Independent Zone 2 (audio + video), with fixed/variable volume & parental access control to sources
• Duplex RS-232 control; also suitable for system software updates
• RC-5 remote input jacks for both zones
• IR pass through for source components
• Full suite of discrete IR RC-5 codes, including separate on / off etc
• 12 Volt triggers, on/off for zones 1 and 2 and either SCART control (video in RGB mode) or on / off and video signal sensing (component video mode)
General
• Supplied with back-lit CR80 learning remote control with support for up to 7 other components
• Large, clear 12 character dimmable VFD front panel display
• Ground lift switch ; User switchable between 120 and 230 Volt mains supplies
• Size – 430mm wide, 433mm deep, 145mm high
Arcam P1000
• 7-channel 135wpc power amp
• high current high efficiency design
• massive toroidal transformer based power supply
• balanced & unbalanced inputs
• 12V trigger input
• multistage protection system
• audiophile sound quality for movies and music
chimoult
Inscription Forum: 25 Sep 2000 2:00
Message » 06 Mai 2005 10:46
Merci pour ces infos.
Je pense que mon AVR300 est à jour, mais je vais jeter un oeil quand même.
NFC
Inscription Forum: 30 Mai 2004 13:38
cron
