Toujours à le recherche de mon ampli idéal je suis tombé sur cette note:
http://www.ubergizmo.com/fr/archives/20 ... _ipods.php
date prévue de sortie: Avril 2007
tarif:
AVR 347 999$
AVR 247 549$
Qu'en pensez vous, avez vous d'autres informations??
VIVEMENT AVRIL
6 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: antiloop64, CCOPERE, Claramide, Gaël, invictus, sankas13, Sarah Connor, Sibara, stephn666 et 173 invités
Les nouveaux Harman Kardon AVR X47 avec 7.1, HDMI et Ipod
- jayce996
- Inscription Forum: 06 Nov 2006 22:23
Bonjour tout le monde voilà les dernières infos que j'ai pu récupéré à ce sujet:
A/V receiver / 65 watts x 2 channels or 50 watts x 7 channels (into 8 ohms, 20Hz – 20kHz, 0.07% THD) / iPod connectivity with optional Bridge
# Harman Kardon's AVR-247 Receiver incorporates a number of genuine engineering breakthroughs, including innovative iPod Connectivity and HDTV and multi-room capabilities to take audio/video receiver design to never-before-available levels of performance and functionality. It features an exclusive iPod Interface that, with a compatible iPod connected via The Bridge (Harmon Karmon's Optional iPod docking station), displays menus on a connected TV or video display and the receiver’s front panel display and the iPod can be operated via the receiver’s remote control. +-35 Amps High current capability
# 65 Watts x 2 Channels or 50 watts x 7 channels (into 8 ohms, 20Hz – 20kHz, Less than 0.07% THD, all channels driven)
# Compatible with Dolby Pro Logic IIx, Dolby Virtual Speaker, Dolby Headphone and DTS formats
# TheBridge Ready for iPod Audio playback, Control and Charging
# EzSet+ Simplified Setup (Microphone included)
# Two Digital Outputs (One Coax One Optical on Rear Panel)
# Two HDMI inputs with 1080p compatability
# Dimensions: Height 6-5/8 x Width 17-5/16 x Depth 15 inches (168mm x 440mm x 381mm)
# Weight: 27.3 pounds (12.4 kg)
- jayce996
Dernières informations tirées d'un mail envoyé à H/K:
The AVR247 should be available my mid April. The AVR247 will have DCDi Faroudja video processing. It will transcode all video from composite up to 720p to HDMI and will upscale the lower resolutions to 720p, depending upon the resolution of your TV. It will also pass 1080i and 1080p HDMI video formats directly through for viewing on compatible video displays. The OSD is a bit different but much more intuitive. If you plan on using a high resolution HD TV, then the AVR247 may be worth waiting for.
- jayce996
Pour moi deux HDMI en entrée c'est trop juste: une PS3, une source HD du genre canal (enfin quand ca vaudra vraiment le coup) et hop la bête est pleine.
Comme on est condamné à l'HDMI, je prendrai plutot un équipement qui supporte plus d'entrées mais en gamme de prix abordable je n'ai rien trouvé avec plus de 2 entrées HDMI.
Pour le video processor dans l'ampli, je vais lancer un thread la dessus parce qu'il y a un truc que je ne saisis pas..
- polopo
- Inscription Forum: 14 Mar 2007 14:11
Après je sais pas pour toi mais personnellement je ne vois pas vraiment d'interet de brancher la PS3 sur l'ampli via HDMI.
Oki pour l'optique pour avoir un superbe son mais au niveau de l'image mieux vaut brancher la PS3 directement sur la TV, je ne pense pas que l'ampli puisse apporter une quelconque amélioration au niveau de l'image venant de la PS3 .
=> eh hop une entrée HDMI de récupérée
- jayce996
Ca vaut le coup de brancher la ps3 en hdmi parce que c'est le seul moyen de récupérer le son HD sans pertes.
- Christophe Elecson KLS
- Inscription Forum: 23 Sep 2000 2:00
6 messages
