Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: hamster, Samix50 et 89 invités
Marantz AV7702 / 7702Mk2 proç 11.2 XLR - Atmos + XT32
les front sont a -3 quand au surround back -1, je peux les passer en + (...) sans risque qu'elles s'endommagent a fort volume ?
- beforemidnight
- Inscription Forum: 20 Juin 2013 19:53
Chez moi (8801) Audyssey me donne les bons niveaux et distances et de façon reproductible....
Je pense encore une fois que le manque de dynamisme ressenti provient d'un problème de choix de courbe cible par rapport aux goûts et habitudes d'écoute....
La meilleure solution: pouvoir modifier cette courbe car l'augmentation du niveau du caisson n'en est pas vraiment une....
Franck
Franck
- franckiné
- Inscription Forum: 12 Nov 2004 13:46
Un peu de "pain" pour la réflexion :
Hugo
sur AVS, SteveH a écrit:Originally Posted on AVS by petetherock a écrit:
Thanks Steve
Out here the upgrade costs a lOT of money, so if I lost a little money selling my 7200, if I consider the 7702 MkII in a few months, will I be trading down?
I actually like marantz just that after the old SR. 12, they always lagged behind denon in features..
A marantz sr 7010 or 7702 will be a welcome return to an old favorite. Always liked their sonic signature.
I do my critical listening with my PM 11 anyway.. Cheers
The 8802 is too dear.. I can get the 7702 plus a Rotel 1585 or marantz MM 8807 and use my old SR. 12 to power the surrounds, and use the pm 11 for the fronts.
It is anybodies best guess what the 7702mKII will sound like. No information has been released or discussed here in the USA. When I guess what things sound like, I get it wrong too many times. I thought the 7702 would sound inferior to the 8801. Wrong. I thought the 8802 with all of it's tweaks would sound MUCH better than the 7702. Wrong; it was incremental and worthy but not massive like I predicted. I thought the AV7009 would sound extremely close to the 7702. Wrong. It's why I don't like to guess with peoples money and I have to compare things myself.
It goes without saying that they are working on a replacement to the 7702. Heck, I'm sure they are plotting the replacement to the 7702mkII or whatever they plan to call it. But since you are using PM11 for stereo, I'd personally keep what you have and call it a day. If you were trying to accomplish stereo AND theater, then I'd go with the 8802A for sure and possibly sell the PM11. Note the word "possibly". I've never compared the 8802 to the PM-11. Speaking of which, how would you compare the X7200 to the PM-11 (preout to preout)?
Hugo
- Hugo S
- Membre d'Honneur - Président de l'Association & Relations PROs
- Inscription Forum: 04 Mai 2000 2:00
merci bcp pour l info,je n ai pas tout su traduire si qq1 pouvait nous éclairer en français sur cette réponse d avs-forum (merci d avance)
- fantomas2929
- Inscription Forum: 20 Avr 2014 13:38
fantomas2929 a écrit:merci bcp pour l info,je n ai pas tout su traduire si qq1 pouvait nous éclairer en français sur cette réponse d avs-forum (merci d avance)
En gros le premier demande si il doit reprendre un 7702mkII pour remplacer son 7200.
Le deuxième dit qu'il ne sait rien et ne veut pas spéculer sur un produit qui doit encore sortir.
- road rebel
- Inscription Forum: 02 Fév 2006 12:49
Vous pensez que ce pre-ampli en utilisation en .2 nécessiterait l'usage d'un antimode ? Et si oui plutôt le le modèle "cinéma" ou le modèle "stéréo"
- MFDS
- Inscription Forum: 22 Déc 2014 12:29
Vu qu’il possède la version XT32 Audyssey j’aurais tendance à dire que non ... mais personnellement, avec l’AV8801 qui possède aussi la version XT32 je l’ai gardé. Mais parce que je l’avais, je ne l’aurais pas acheté en plus. De plus, dans les cas extrêmes je pense qu’il peut y voir un risque selon le caisson, chacun des systèmes apportant éventuellement une correction en augmentation. Normalement elle est par sécurité limitée. Là pour le coup elles vont forcément s’additionner. Mais du coup probablement une réponse plus linéaire. A toi de voir.
Et si antimode, cal antimode et après Audyssey.
Après je ne sais pas si en utilisation .2 c’est très adapté ou souhaitable, car je suppose qu’il va falloir utiliser une seule sortie sub du pré ampli, et utiliser les deux sorties de l’antimode.
Est-ce que ce sera meilleur que de partir directement des deux sorties du préampli .... aucune idée.
- Gruit
- Inscription Forum: 08 Juin 2007 13:49
Perso , quand j'ai eu le 8801 , j'ai trouvé l'antimode obsolète et donc revendu aussitôt .
superduke - Membre HCFR
- Inscription Forum: 11 Sep 2005 19:06
Tu as fait des mesures comparatives (XT32 seul vs antimode + XT32) ?
Perso je me suis posé la question, mais comme il y était je l'ai laissé. Tant que c’est au moins aussi bon avec que sans ...
- Gruit
Je n'ai pas fait de mesures comparatives , j'ai juste branché mon 8801 tout seul , j'ai fait une calibration en trois points sans antimode , j'ai trouvé que ça sonnait très bien , aussi bien , voir mieux , les basses bien franches et sans trainage .... alors , pourquoi faire compliqué quant on peut faire simple ?
Quant c'est possible et sans perdre en qualité , je privilégie toujours le systeme le plus simple .
j'ai aussi viré mon fidele SMS-1 de Velodyne car le 8801 fait un excellent boulot sur le caisson (Jl Audio), ce dernier a une calibration propre, assez simplifier mais efficace.
Gil
Gil
Ma Config
B&W Accuphase
- gil2b
gil2b a écrit:j'ai aussi viré mon fidele SMS-1 de Velodyne car le 8801 fait un excellent boulot sur le caisson (Jl Audio), ce dernier a une calibration propre, assez simplifier mais efficace.
Gil
Exactement le même chemin que Gil, le systeme de calibration XT32 fait un bon travail aux niveaux des sub, le systeme ARO sur les JL audio est également très efficace.
Mon SMS-1 est depuis rangé dans un placard.
- duck
- Inscription Forum: 01 Oct 2003 15:14
Après qques jours d'absence et lecture des posts dont ceux de Hugo pour les conseils (merci) et JPV9 pour le constat, j'ai donc repris toutes les mesures XT32.
J'ai appliqué les conseils de Hugo sauf pour le SW (+5dB à relever, j'y arrive via la calibration manuelle mais elle n'est pas prise en compte en écoute Audissey).
Comme JPV9 j'ai une salle dédiée, mate, HP derrière l'écran tissé mais le SW devant l'écran.
Son enveloppant, ambiances bien restituées, très beau médium mais dynamique plate, les impacts sont mous sur toute la gamme de fréquences. Je persiste à dire que mes deux précédents préamplis Emotiva et mon préampli Parasound faisaient beaucoup mieux en terme de dynamique.
Je vais donc me résoudre à sortir mon vieux sonomètre RadioShack et reprendre les réglages mais en manuel. A ce propos perd-t-on la calibration Audissey dans ce cas ?J'espère, comme JPV9 qui a fait cette calibration manuelle, retrouver cette dynamique qui me manque.
Toujours à suivre, donc, et encore merci à tous les forumeurs (mention spéciale à Hugo) pour leurs avis éclairants.
- RATOUNET
- Inscription Forum: 19 Sep 2006 13:41
et oui, c'est l' "esprit" HCFR...
H.
RATOUNET a écrit:...
H.
- Hugo S
Perso j'ai réinitialisé le 7702 et je n'ai plus fait de calibration ...
Je trouvais aussi le son plat sur ma voie centrale.
Je règle à l'oreille comme il me plait.
- Ptisik
- Inscription Forum: 18 Mai 2001 2:00
- Localisation: Là où la température est en bleu à la météo !
