Le DAC USB/ampli-casque portable FiiO E7 a été testé avec succès avec le smartphone Samsung Galaxy S III :
http://www.androidnz.net/2012/06/galaxy ... eally.html
http://www.tellementnomade.com/test-fii ... li-nomade/
musique stockée sur Samsung Galaxy S III > lecteur Samsung Galaxy S III > flux audio numérique >> câble USB maître >> DAC USB FiiO E7 > ampli-casque FiiO E7 >> casque
Un casque sympa à 50 us$, Digitech Pro Monitor Headphones
http://www.jaycar.us/productView.asp?ID=AA2065
Le casque Digitech Pro Monitor Headphones à conception de type fermé permettant une bonne isolation est le clone du Fischer Audio FA-003, Brainwavz HM5 ou Lindy Premium Hi-Fi headphones.
"Now that I've had these for a good month I can honestly say they are my 'New' daily headphones!
I simple love the music that comes from these headphones.
They are beautifully balanced with sparkly highs that are not offensive to the ears, mid's that introduces a 'fun' factor to the music for all genres and lastly lows that are firm, bassy and goes amazingly deep with out distorting or overpowering the rest of the music.
The clarity is excellent with a very nice sound stage and for a 'closed' headphone they do sound quite open and spacious!
Isolation is fantastic especially listening to music or playing games at night.
They are a revealing headphone too, so if you are playing poor quality music then that is going to show quite easily.
Comfort is excellent and the 'killer' clamp grip slowly eases after regular use! I've listened to these all night and in to the early morning without wanting to take them off!"
http://www.head-fi.org/products/digitec ... views/6900
Une chaîne audio portable sympa à prix abordable :
Il semble utile de maintenir la pression sur Google et sur les fabricants d’appareils Android, et aussi d’attirer l’attention des développeurs, qui pourraient fournir des noyaux Android Linux audiophiles.
Voter : cliquer sur l'étoile, qui apparaît après la connexion (Sign in)
http://code.google.com/p/android/issues ... ry%20Stars
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Sergio-22 et 97 invités
Smartphone + DAC, question d'un beotien...
- DanBa
- Contributeur HCFR 2024
- Inscription Forum: 16 Oct 2007 17:46
Un système audio numérique de bureau à base de Samsung Galaxy S III :
http://www.androidnz.net/2012/06/samsun ... -demo.html
musique stockée sur Samsung Galaxy S III > lecteur Samsung Galaxy S III > flux audio numérique >> câble USB maître >> DAC USB / ampli-casque FiiO E7 >> enceinte Logitech
[youtube]46IiRyigUH0[/youtube]
- DanBa
Le DAC USB ODAC a été testé avec succès avec le smartphone Samsung Galaxy S III :
https://plus.google.com/107354758331405 ... CaM42irMeU
http://pastebin.com/Jjq4xnT3
http://nwavguy.blogspot.fr/2012/03/odac-update.html
musique stockée sur Samsung Galaxy S III > lecteur Samsung Galaxy S III > flux audio numérique >> câble USB maître >> DAC USB ODAC >> ampli-casque O2 >> casque
- DanBa
Les USB DAC sont supportés officiellement dans Android 4.1 Jelly Bean !
"Android 4.1 for Developers
New Media Capabilities
USB Audio
USB audio output support allows hardware vendors to build hardware such as audio docks that interface with Android devices."
http://developer.android.com/about/vers ... html#media
USB Audio
- DanBa
cool,
reste plus qu'a installer Android 4.1 sur ma tablette Ainol si c'est possible...
- robob
- Inscription Forum: 21 Mar 2007 19:23
Le DAC USB recommandé par Google est un nouveau type d’équipement. Il n’est pas compatible avec un PC ou un Mac !
http://developer.android.com/tools/adk/ ... io-support
http://developer.android.com/tools/adk/ ... play-audio
Un DAC USB classique compatible PC / Mac se comporte comme un USB device, et un PC / Mac comme un USB host.
Un DAC USB recommandé par Google se comporte comme un USB host, et un smartphone / tablette Android comme un USB device.
Personnellement, je préfère la fonction USB audio classique implémentée par Samsung dans le Galaxy S III, qui peut fonctionner avec un DAC USB classique comme le FiiO E7 ou l’ODAC.
La fonction USB classique est toujours spécifiée dans les specs Android :
http://developer.android.com/guide/topi ... index.html
http://developer.android.com/guide/topi ... /host.html
http://developer.android.com/reference/ ... tants.html
"USB_CLASS_AUDIO USB class for audio devices"
- DanBa
mouais bah on est pas arrivé :
"One of the important new features introduced with the ADK 2012 is the ability to play audio over a USB connection. This innovation was introduced as an update to Android Open Accessory (AOA) protocol 2.0 and is available on devices running Android 4.1 (API Level 16) and higher.
The ADK 2012 provides a reference implementation of this functionality for accessory developers. No software application is required to be installed on the connected Android device, accessory developers only need to support AOA v2. This implementation demonstrates audio output of 16bit, 44.1kHz stereo PCM source data compressed into a single channel due to the audio hardware available on the accessory."
Mon anglais n'est pas terrible :
-il va falloir un matériel capable de gérer le protocole Android (AOA 2.0) pour pouvoir utiliser l'USB audio ? On est chez Apple ou quoi là ?
-"16 bits, 44.1 khz compressed in a single channel" : pas terrible pour un rendu HIFI (ne serait-ce que pour utiliser le volume numérique sans perte d'info), d'ailleur il est écrit ailleur , "This version of the protocol supports a standard USB audio class interface that is capable of 2 channel 16-bit PCM audio with a bit rate of 44100 Khz.". De quel standard audio USB s'agit-il ?On est pas en USB 2.0 avec Android ? format compressé ou pas ? comprends pas...
Pourquoi faire simple quand on peut faire compliqué ?
- robob
robob a écrit:-il va falloir un matériel capable de gérer le protocole Android (AOA 2.0) pour pouvoir utiliser l'USB audio ?
Oui, c'est ce que j'ai compris.
robob a écrit:-"16 bits, 44.1 khz compressed in a single channel" : pas terrible pour un rendu HIFI (ne serait-ce que pour utiliser le volume numérique sans perte d'info), d'ailleur il est écrit ailleur , "This version of the protocol supports a standard USB audio class interface that is capable of 2 channel 16-bit PCM audio with a bit rate of 44100 Khz.". De quel standard audio USB s'agit-il ?On est pas en USB 2.0 avec Android ? format compressé ou pas ?
Le standard USB 2.0 est relatif aux couches de gestion USB.
Le standard USB audio 2.0 est relatif à la couche application audio utilisant les couches USB.
Google ajoute un nouveau message de contrôle au standard USB audio 2.0 (et utilise les autres messages du standard USB audio 2.0) :
"To enable the audio support, the accessory must send a new USB control request: SET_AUDIO_MODE"
Il faudrait considérer plutôt toute la pile de protocoles USB audio et USB (i.e. USB audio out).
Et le standard de-facto est le standard compatible PC / Mac où l'USB DAC est un USB device, et non un USB host de l'USB audio out spécifique Android.
La compression est liée uniquement à la limitation matériel de l'USB DAC de démo / ADK :
"This implementation demonstrates audio output of 16bit, 44.1kHz stereo PCM source data compressed into a single channel due to the audio hardware available on the accessory."
robob a écrit:On est chez Apple ou quoi là ?
Malgré le nombre très important d’iDevices, il n'y a que 3 (chers) i DAC portables pour le marché américain (donc international) :
. USB i DAC Cypher Labs AlgoRhythm Solo à 579 us$ :
http://aloaudio.com/cypher-labs-algorhy ... order.html
. USB i DAC/amp Fostex HP-P1 à 649 us$ :
http://www.moon-audio.com/headphone-aud ... p-dac.html
. USB i DAC/amp V-Moda Vamp à 650 us$ (une sorte de clone du VentureCraft Go-Dap Unit4.0 du marché japonais) :
http://v-moda.com/vamp/
J’aime bien le constat suivant :
"6moons reader Robert Gaboury thinks that "Apple failed to understand the appeal of the iPod as a high-resolution machine. This is surprising from the inventors of the genre — or second proponent if we include Sony as the true mother — but perhaps they just outgrew their own personality. Judging from the sheer number of HD portable media players offered at the Hong Kong electronics show (players with FLAC support and compatible with almost any other AV format you can think of), I think the iPod will open the door to a new generation of non-Apple portable devices just as the Sony Walkman paved the way for the original iPod."
http://www.6moons.com/audioreviews/aloaudio2/2.html
Heureusement qu’Android utilise le noyau Linux, qui est Open Source, et qui s’appuie sur les standards.
Et il y en a une multitude d'USB DAC standards de quelques us$ à plus de 25.000 us$.
http://www.ebay.com/sch/i.html?_trksid= ... d&_sacat=0
http://www.msbtech.com/products/platinumHome.php
Google peut commettre des errements comme ne pas vouloir activer nativement l’USB audio out standard.
Mais les constructeurs comme Samsung ou Archos peuvent le faire de manière native.
Et les développeurs peuvent le faire aussi en modifier le noyau natif.
Encore faut-il que nous leur informons de notre attachement à l’USB audio out standard.
L’un des moyens est de voter massivement (i.e. demander à notre entourage) pour la requête "Activer l'USB Audio standard" :
- DanBa
Le Samsung Galaxy S III peut interfonctionner avec l'iBasso D2 Boa :
http://www.head-fi.org/t/552014/picture ... st_8509186
Samsung Galaxy S III > flux audio numérique >> DAC USB/ampli-casque iBasso D2 Boa >> casque Sennheiser HD 518
- DanBa
Une liste d'équipements USB DAC standards permettant de contourner le convertisseur numérique-analogique interne et donc de l’ampli interne du smartphone Samsung Galaxy S III, ou permettant d’extraire le flux audio numérique du Samsung Galaxy S III :
Samsung Galaxy S III > flux audio numérique >> câble USB OTG >> USB DAC standard >> ampli ou ampli-casque >> enceintes ou casque
. AMB Labs Gamma2:
http://www.amb.org/audio/gamma2/
http://forum.xda-developers.com/showpos ... tcount=279
. C-Media chipset-based sound card Dynamode 7 channel USB 2.0:
http://www.chinacomputerparts.com/d-p11 ... 00-cables/
http://forum.xda-developers.com/showpos ... tcount=449
. Corsair HS1 Gaming headset (USB DAC/amp/headphones):
http://www.anandtech.com/show/3989/cors ... ng-headset
http://forum.xda-developers.com/showthr ... st27238117
. FiiO E7 (USB DAC/amp):
http://fiio.com.cn/product/index.aspx?I ... uID=020301
http://www.androidnz.net/2012/07/galaxy ... art-2.html
. GoVibe Mini USB DAC:
http://www.jaben.com.au/collections/go- ... be-minidac
http://www.head-fi.org/t/614111/finally ... st_8525675
. HeadAmp Pico (USB DAC/amp):
http://www.headamp.com/pico/pico_dac_amp/index.htm
http://www.head-fi.org/t/608535/wolfson ... st_8495302
. HeadRoom Total BitHead (USB DAC/amp):
http://www.headphone.com/learning-cente ... ad-faq.php
http://www.head-fi.org/t/595071/android ... st_8527516
. HiFiMan Express HM-101:
http://www.head-fi.org/t/571330/hifiman ... le-usb-dac
http://forum.xda-developers.com/showpos ... tcount=291
. iBasso D2 Boa (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=30
. iBasso D5 (USB DAC/amp):
http://www.head-fi.org/t/556490/ibasso- ... sb-dac-amp
http://www.head-fi.org/t/614111/finally ... st_8498377
. iBasso D12 (USB DAC/amp):
http://www.ibasso.com/en/products/show.asp?ID=63
. Microsoft Philips Digital Sound System 80 (USB DAC/amp/speakers):
http://en.wikipedia.org/wiki/Digital_Sound_System_80
http://forum.xda-developers.com/showthr ... ?t=1703218
. Objective DAC (ODAC):
http://epiphany-acoustics.co.uk/our-pro ... e-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=46
http://www.headnhifi.com/index.php/shop/objective/odac
. ODAC+O2 (USB DAC/amp):
http://epiphany-acoustics.co.uk/our-pro ... h-usb-dac/
http://www.jdslabs.com/item.php?fetchitem=48
http://www.headnhifi.com/index.php/shop ... 0527192048
. RSA Predator (USB DAC/amp):
http://www.raysamuelsaudio.com/products/predator
http://forum.lowyat.net/index.php?s=501 ... ry52693606
. Topping D1 Mark 2 (USB DAC/amp):
http://translate.googleusercontent.com/ ... J4x85vGfDg
http://forum.xda-developers.com/showpos ... tcount=871
. Topping TP30 (USB DAC/amp):
http://news.cnet.com/8300-5_3-0.html?ke ... ping+TP-30
http://www.androidnz.net/2012/05/samsun ... audio.html
. AMB Labs Gamma2:
- DanBa
Le Samsung Galaxy S III peut interfonctionner avec le DAC USB asynchrone HRT Streamer II :
http://www.head-fi.org/t/608535/wolfson ... st_8534856
Samsung Galaxy S III > flux audio numérique >> câble USB OTG >> DAC USB asynchrone HRT Streamer II >> ampli-casque cMoyBB >> casque
- DanBa
DanBa,
Merci de toutes ces infos . Je pense qu'il y en a plusieurs comme moi qui suivent ce fil avec intérêt sans intervenir car je pense que le développement des "drives" ultra-portables type smartphone sous Android pour alimenter un DAC externe portable aussi sont une très intéressante solution nomade.
- Fr-Lem
- Inscription Forum: 07 Nov 2009 16:07
DanBa a écrit:robob a écrit:On est chez Apple ou quoi là ?
Avec un iPad/iPhone il n'y a pas d'autres DAC ?
Il y'a pourtant bien des cartes son dediees a la creation musicale sur ces iDevices.
http://www.thomann.de/fr/tascam_iu2.htm
Et il me semble qu'avec le "camera kit" plusieurs cartes son USB "standard" fonctionnent ?
http://www.benchmarkmedia.com/discuss/f ... audio-dac1
Apres la question est de savoir comment le son des applis standard (qui ne laisse pas le choix de la sortie) est route vers la carte son.
- palm
palm a écrit:Avec un iPad/iPhone il n'y a pas d'autres DAC ?
Pour les iDevices, surtout pour les iPhone / iPod portables, il n’y a que quelques DAC portables compatibles.
Par contre, j’ai une longue liste de DAC de salon compatibles :
http://www.iphonefr.com/viewtopic.php?id=29597&p=1
palm a écrit:Il y'a pourtant bien des cartes son dediees a la creation musicale sur ces iDevices.
Ce n’est pas un DAC.
palm a écrit:Et il me semble qu'avec le "camera kit" plusieurs cartes son USB "standard" fonctionnent ?
L’interface USB audio des iDevices (iPhone, iPod, iPad) est propriétaire :
. Un processeur d’authentification d’Apple est nécessaire du côté DAC USB compatible iDevice.
. Le DAC USB compatible iDevice se comporte comme un équipement USB host, alors qu’un DAC USB standard compatible PC ou Mac d’Apple se comporte comme un équipement USB client ou périphérique.
Un iPad peut communiquer avec un DAC USB standard via un Camera Connection Kit (CCK).
Le CCK intègre un processeur d’authentification d’Apple permettant à l’iPad d’authentifier l’équipement périphérique et de délivrer le flot USB audio.
Le CCK demande aussi à l’iPad de passer du mode USB client en mode USB host afin de pouvoir communiquer avec un équipement DAC USB standard.
L’iPhone 4 sous iOS5 beta 3 pouvait fonctionner avec un DAC USB standard via un CCK ; mais Apple ne le permet plus avec un iOS standard.
http://www.head-fi.org/t/494521/ipod-ip ... st_8207631
Apple ou Google ont des fois des cheminements qui ne conviennent pas à nous les consommateurs semble-t-il.
A nous de leur faire savoir en votant pour un USB audio standard :
Au fait, le message / vote pour un interfonctionnement avec les DAC USB standards n’est pas seulement destiné à Google mais plutôt aux constructeurs d’appareils Android.
Comme Samsung avec le Samsung Galaxy S III, les constructeurs peuvent commercialiser des appareils Android compatibles avec les DAC USB standards.
Après tout, ce n’est pas difficile du tout puisque le système Android s’appuie sur le noyau Linux qui est déjà compatible avec un tas de standards dont l’USB audio standard.
- DanBa
Merci pour tes precisions
Bon quand tu dis que les cartes son orientees studio ne sont pas des DAC... ok dans le sens "hifi", mais disons qu'il y a des sorties analogiques avec un reglage de volume, ce qui est un peu la meme chose et permet par exemple d'utiliser juste un ipad/iphone avec ce genre de carte et des enceintes de monitoring
- palm
