Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 37 invités
Les Processeurs Vidéo (Scaler, Désentrelaceur, Enhancer) et tous les appareils traitant l'image (y compris les ampli HC)
Nouveau scaler Lumagen Radiance 2020
Message » 24 Oct 2014 22:16
Un nouveau venu :)
Le Radiance 2020 : http://www.lumagen.com/testindex.php?mo ... 20_details
Probablement le remplaçant du mini3D.
http://www.convergent-av.co.uk/forum/index.php?t=msg&th=2789&start=0&rid=0
Jim Peterson a écrit:I am still working on the press release but wanted to announce the Radiance 2020 here first.
The Radiance 2020 is essentially the (now retired) Radiance 2021, minus the COAX audio output and in a smaller case.
It has exactly the same video setup, processing and calibration feature set as the Radiance 2021.
Highlights:
4 HDMI 1.4a inputs (max 1080p60)
2 HDMI 1.4a outputs (max 1080p60)
9x9x9 Linear-Gamma RGB CMS
Darbee DVP(TM) enhancement
Image-based auto input aspect selection
RS232 command port
Wired IR command input
12 VDC power supply
Case: 11 x 1.7 x 5 inches
Note that the Radiance 2020 is not rack mountable.
The US retail price for the Radiance 2020 is $2495.
Volume shipments for the Radiance 2020 will begin on the 10/28
La news sur le site Lumagen: http://www.lumagen.com/testindex.php?module=news
New Lumagen® Radiance™ 2020
Beaverton Oregon, October 24th, 2014 — Lumagen®, Inc., a specialist in the design and manufacture of products for the home and corporate theater markets, today announced the addition of the Radiance™ 2020 to it's video processor family.
Supporting all the features of the Radiance Mini adding 2 more inputs, an additional output, expanded CMS and including Darbee DVP™ processing.
The Radiance 2020 supports input and output rates of up to 1080p60 with four HDMI inputs, two HDMI outputs, and an RS232 command input.
With its extensive processing, setup, and calibration, feature-set the Radiance family is perfectly suited for refining and enhancing the images presented by front projectors, and top-level flat-panel displays. With the introduction of these new products, the Radiance family continues as the video backbone for the best home theaters and media rooms.
The Radiance 2020 will be available October 28. Suggested retail pricing for the Radiance 2020 is $2495.
alex_t
Membre HCFR Contributeur
Inscription Forum: 29 Oct 2005 23:04
Message » 24 Oct 2014 22:17
Réservé
alex_t
Message » 29 Oct 2014 14:19
Ajout dans le 1er message des visuels et du lien vers la page produit.
a+
alex_t
Message » 25 Nov 2014 17:58
Une question idiote... :oops:
Comment fait-on la mise à jour? La prise présente à l'arrière est inexistante sur les PC actuels non?
Edit: c'est bon, j'ai trouvé...
câble USB/RS232 :siffle:
Winger
Inscription Forum: 12 Oct 2002 17:03
Message » 26 Nov 2014 11:56
Ce est la nouvelle 2020. Il est essentiellement la même spécification que le 2021 de l'an dernier, sauf qu'il n'a plus une sortie audio numérique coaxiale et il est dans une bien plus petite, plus affrodable, cas. La petite affaire est moins cher de maufacture et l'expédition est moins le coût pourrait descendre. L'unité est disponible dans le cadre de nos spéciaux offres Black vendredi jusqu'à Monday1st Décembre.
gordon@convergentav
Pro-Commercant
Pro-Commercant
Inscription Forum: 05 Juil 2012 15:26
Message » 02 Déc 2014 16:55
Intéressant, à suivre...
Les caractéristiques font penser à un 2021 dans une plus petite boite.
Avez-vous une idée du prix public ?
Le 2021 était à 2290€.
Une photo du bébé :
2020 vu de face avec télécommande
Ma salle 7.2.4 terminée : ICI
Lukyfish
Modérateur Home-Cinéma
Message » 02 Déc 2014 17:47
Ah si, après avoir chercher un peu les caractéristiques du 2021, il serait 3D lut 5x5x5 en 125 points.
Alors que le 2020 semble être en 9x9x9 = 729 points.
Il perd juste la sortie coaxial numérique, à quoi sert-elle ?
Lukyfish
Message » 02 Déc 2014 19:08
Lukyfish a écrit:Ah si, après avoir chercher un peu les caractéristiques du 2021, il serait 3D lut 5x5x5 en 125 points.
Tous les 20XX sont en 9x9x9. Les 1er firmware étaient en 5x5x5 puis il y a eu la mise à jour qui va bien.
Pour résumer :
XD, XE, XS, mini sont en 5x5x5
20XX sont en 9x9x9
21XX sont en 17x17x17
La sortie coax sert quand on a pas d'ampli HDMI. Le Radiance permet alors de récupérer le DTS/DD classique plus LPCM 2.0 de HDMI pour le sortir sur sa coax mais attention la source doit envoyer un signal compatible.
Bref, si tu as un ampli avec HDMI la sortie coax ne sert à rien.
alex_t
Message » 03 Déc 2014 0:42
alex_t a écrit:Tous les 20XX sont en 9x9x9. Les 1er firmware étaient en 5x5x5 puis il y a eu la mise à jour qui va bien.
Pour résumer :
20XX sont en 9x9x9
Ok merci Alex pour ces précisions.
Il n'a pas l'air mal ce nouveau-né.
Lukyfish
Message » 03 Déc 2014 9:00
Lukyfish a écrit:Ok merci Alex pour ces précisions.
De rien ;)
Le 2020 est en effet une très bonne idée de la part de Lumagen, il permet de combler quelques manques dans le mini3D : plus d'entrées HDMI, 2 sorties HDMI et CMS plus performant. Il devrait intéresser beaucoup de monde pour un prix 'raisonnable' sur l'échelle des prix Lumagen.
a+
alex_t
Message » 03 Déc 2014 10:57
Bonjour ,
Dans quelle boutique parisienne pourrait on avoir une demo de ce scaler ?
BJH59-2008
Inscription Forum: 24 Nov 2008 19:16
Message » 03 Déc 2014 23:37
BJH59-2008 a écrit:Bonjour ,
Salut.
Je crains qu'aucune boutique sur Paris ne propose une telle démo.
alex_t
Message » 05 Déc 2014 10:57
En commande...
Prix public en France : 2490€ d'après mes infos (à vérifier...)
Lukyfish
Message » 05 Déc 2014 13:33
Lukyfish a écrit:En commande...
Félicitation un beau cadeau pour noël , tu ne vas pas regretter avec ton oppo !
vincz
Inscription Forum: 24 Déc 2008 18:40
Message » 05 Déc 2014 14:30
Tu ne devrais pas être déçu. Plus la source est de qualité, plus le Radiance est performant !
a+
alex_t
Retourner vers Processeurs Vidéo
