Type : Bass manager
Marque : Outlaw
Modèle et options : ICBM
Prix de vente : 450 > 350 > 250
Montant des frais d'expédition : A déterminer
État de la marchandise : Très bon
Première main : Non
Prix neuf : ?
Facture disponible : Non, lettre de cession
Date et lieu d'achat : ? sur le forum
Numéro de série : Sur demande
Idéal pour le bass management, entièrement analogique, circuits de qualité, une référence dans son domaine.
Site web du constructeur :
The Outlaw Audio ICBM provides a complete bass management system for DVD & SACD players. This "sonic missile" is a product that will be welcomed by audiophiles for its ability to control and enhance the low-frequency sound quality of music.
While primarily intended for DVD-Audio and SACD, the ICBM is also useful as a high quality alternative to the less-comprehensive digital bass management included with home theater receivers and even some expensive preamp/processors.
The slim, one-rack-unit high, ICBM allows individual adjustment of the bass re-direction cross-over point for each channel and logical channel pair in a home theater system. With the ICBM, the front left/right, front center, surround left/right and rear center speakers may be individually set to roll-off bass information at 40 Hz, 60 Hz, 80 Hz, 100 Hz, or 120 Hz, or to bypass bass management when it is not needed. Bass information is then properly routed to the main channel speakers, or to a subwoofer. This capability, though standard in digital-audio systems for conventional inputs, is missing in all but a handful of DVD-Audio and SACD players, due to the use of analog outputs on the player and analog “pass-through” inputs on the receiver. Without the use of the ICBM, low frequency performance is compromised and damage to individual speaker components can occur.
Recognizing that DVD-Audio and SACD are music systems, the ICBM accommodates the “large,” front left/right speakers with extended low-frequency capabilities found in many audiophile systems. Optionally, the ICBM allows bass information to be sent to both the subwoofer and the front speakers, a feature not found in many audio products. A simple rear-panel switch controls this redirection.
There are separate controls on the front panel for both subwoofer output level and LFE boost. The latter provides up to 10 dB of LFE injection to fine-tune the low frequency output for maximum impact.
For optimum performance of the subwoofer with the frequency specifications of certain speaker and processor systems, a rear panel switch allows the signal to be set at either a 12 db or 24 db per-octave slope.
The ICBM was designed in the US by Outlaw’s own engineering team. This 100 percent analog design maintains signal integrity by avoiding any additional analog-to-digital and digital-to-analog conversions. High-quality components are used throughout, including gold plated RCA jacks for inputs and outputs, metal-film resistors, low-noise op-amps and high quality film capacitors.
Specifications
Inputs
All unbalanced, -10 dBV, chassis-mounted RCA jacks Left, center, right, left surround, right surround, center surround (SR6), LFE
Outputs
All unbalanced, -10 dBV, chassis-mounted RCA jacks Left, center, right, left surround, right surround, center surround (SR6), left subwoofer, and right subwoofer
Controls
Crossover frequency selectors for left/right front, center, left/right surround, center surround (SR6); potentiometer controls for LFE mix and subwoofer level; switches for L/R recombine, subwoofer mono/stereo, and low pass special/ normal.
Crossover frequencies: 40, 60, 80, 100, 120 Hz, and bypass
Filter slopes: 2nd -order Butterworth high-pass in both "normal" and "special" modes 2nd order Butterworth low-pass in "normal" mode; 6 th -order Butterworth low-pass in "special" mode
LFE mix range: 0 dB (unity gain) to ¬10 dB
Subwoofer level control range: Full attenuation to +9 dB
Signal-to-noise ratio (A-weighted): 105 dB
Total harmonic distortion: plus noise less than .015 %
Relative phase shift channel to channel: less than 1degree
Relative phase shift low-pass output to high-pass output: less than 1 degree
Maximum input voltage: 4.5Vrms
Maximum output voltage: 9.5Vrms
Gain: 0dB (unity)
Power supply (AC adapter supplied): 15VAC -300mA
Dimensions: 44 x 440 x 175 mm (HxWxD) 1.76 x 17.6 x 7 in. (HxWxD)
http://www.gspr.com/outlaw/icbm.html
http://www.hometheaterhifi.com/volume_8_4/outlaw-audio-icbm-bass-management-11-2001.html
36 messages • Accèder à une page • 1, 2, 3
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: jean marc et 40 invités
Petites annonces pour Préamplificateurs HC multi-canaux.
Une rareté que j'ai possédé. La solution pour faire un Bass-Management avec 2 caissons droite / gauche, derrière un Atoll PR5.1 par exemple (un engin qui n'a qu'une seule sortie caisson et qui n'a qu'une seule fréquence de coupure).
Magnetar UDP800 / Lumagen Pro 4242 / JVC N7 / MicroPerf'Oray HD 4K / Anthem AVM90 / 9 x Focal, SM6 Be & 1000 Be + 4 x 300 / 2 x Subs DIY Beyma 18LX60 V1 / Amplis HPA / Etudes, traitements & calibrations pros
SYLEX - Administrateur Suppléant de l'Association & Délégué Editorial
- Inscription Forum: 11 Oct 2002 13:47
Up pour un vrai Bass manager !
- Fouiz
- Inscription Forum: 05 Juin 2000 2:00
Up et baisse de prix !
- Fouiz
Est-ce possible de faire le raccord entre les principales les caissons?
- cricri88
C'est à dire ? Est-ce que tu peux préciser la question ?
Nota : je connais bien cet engin.
Faire la fréquence de coupure entre les enceintes principales et le(s) caisson(s) de grave.
- cricri88
Bah, c'est son rôle. C'est un Bass-Management analogique. Tu peux gérer des fréquences de coupures séparées pour les Front / Center / Rear / Rear-Center. Ce que font la grande majorité des intégrés et pré-amplis actuels. Mais tu peux aussi gérer 2 caissons Droite et gauche séparés, ce que ne font pas la grande majorité des intégrés et pré-amplis actuels.
Merci Sylex pour les précisions, heureusement que tu suis
Pour info, je peux transmettre le user manual à qui veut des infos plus détaillées.
- Fouiz
Up et bonne année
- Fouiz
Toujours là, je crois qu'il va passer à la poubelle
- Fouiz
36 messages
• Page 1 sur 3 • 1, 2, 3
Retourner vers Préamplificateur HC
