OPPO BDP-105EU
OPPO BDP-105EU
Présentation du lecteur et caractéristiques :
Spécifications du lecteur :
Types de disques et formats :
BD-Video, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE, FLAC, VAW, AVCHD, MKV, MP4, AVI
Version Bluray :
2.5 profile 5
Mémoire interne de stockage :
1 GB
Sorties :
– Analog Audio MCH RCA: 7.1ch
– Analog Audio RCA: 2ch
– Analog Audio XLR: 2ch
– Coaxial/Optical Audio: Dolby Digital, DTS, up to 2ch/192kHz PCM.
– HDMI Audio: Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD High Resolution and DTS-HD Master Audio, up to 7.1ch/192kHz PCM, up to 5.1ch DSD.
– HDMI Video: 480i/480p/576i/576p/720p/1080i/1080p/1080p24/4Kx2K, 3D frame-packing 720p/1080p24.
Entrées :
– HDMI Audio: Dolby Digital, Dolby Digital Plus, DTS, AAC, up to 5.1ch/192kHz or 7.1ch/96kHz PCM.
– HDMI Vidéo: 480i/480p/576i/576p/720p/1080i/1080p/1080p24/1080p25/1080p30, 3D frame-packing 720p/1080p24.
– MHL Audio: Dolby Digital, Dolby Digital Plus, DTS, up to 5.1ch/192kHz PCM.
– MHL Vidéo: 480i/480p/576i/576p/720p/1080i/1080p24/1080p25/1080p30, 3D frame-packing 720p/1080p24.
– Coaxial/Optical: Dolby Digital, DTS, AAC, up to 2ch/96kHz PCM
– USB Audio: up to 2ch/192kHz PCM
Performances audio :
– Frequency Response: (RCA) 20Hz – 20kHz: ± 0.2dB, 20Hz – 96kHz: -1.5dB. (XLR) 20Hz –20kHz: ± 0.3dB, 20Hz 96kHz: -1.5dB
– Signal-to-Noise Ratio: >130dB (A-weighted, auto-mute), >115dB (A-weighted, no auto-mute)
– THD+N: <0.0003% or -110dB (1kHz at 48k/24b, 0dBFS, 20kHz LPF), <0.0017% or -96dB (1kHz at 44.1k/16b, 0dBFS, 20kHz LPF)
– Output Level: 2.1 Vrms (RCA) or 4.2 Vrms (XLR) at 0dBFS
– Dynamic Range: >110dB
– Channel Separation: >110dB
Performances sortie casque :
– Frequency Response: 20Hz – 20kHz: ±0.3dB into 300 Ω
– Signal-to-Noise Ratio: >98dB into 300 Ω (A-weighted, no auto-mute)
– THD+N: <0.001% or -100dB into 300 Ω (1kHz at 48k/24b, 0dBFS, 20kHz LPF)
– Output Power (per channel): 17mW into 600 Ω, 34mW into 300 Ω, 63mW into 150 Ω, 77mW into 120 Ω, 120mW into 60 Ω, 187mW into 32 Ω (1kHz at 0dBFS)
– Channel separation: >90dB
Spécifications générales :
– Alimentation universelle par sélecteur : ~100V – 240V, 50/60Hz AC
– Consommation : 55W (Standby: 0.5W en mode Energy Efficient)
– Dimensions : 430mm x 311mm x 123mm
– Poids : 7.9kg
Connectique :
Face avant :
– HDMI/MHL x1 entrée
– USB x1 entrée
– sortie casque x1
Face arrière :
– HDMI x2 sorties
– USB x2 entrées
– Coaxiale x1 entrée
– Optique x1 entrée
– USB Audio x1 entrée
– LAN x1
– Prise IR pour déport infrarouge x1
– RS232 x1
– Audio numérique coaxial x1 sortie
– Audio numérique optique x1 sortie
– Sortie vidéo DIAG (composite) x1
– Sortie audio analogique 7.1 x1
– Sortie audio analogique stéréo RCA x1
– Sortie audio analogique stéréo XLR x1
Fonctionnalités :
– Puce Qdeo Kyoto G2H capable de faire une mise à l’échelle 4k (QFHD 3840 x 2160)
– Conversion 2D 3D avec ajustement de la perception de profondeur
– Services en ligne Picassa et Youtube
– Mode « source directe » sans processing vidéo
– Service Gracenote
– Gestion de ratio dont 2.35
– Fonction DMP, DMR, SMB/CIFS
Partager :
