type : interface USB (transport)
Marque : HUMAN AUDIO
Modèle et options : TablaPico
Prix de vente : 190€
Département où la marchandise est visible : 21
Montant des frais d'expédition : INCLUS
État de la marchandise : très très bon
Première main : non
Prix neuf : 380€
Facture disponible : non
Date, pays et lieu d'achat : Décembre 2012 / sur le forum
Numéro de série : Sur demande
Documentations conservées : à télécharger sur le site
Description :
FThe R&D department of Human Audio turns into computer based listening as well. After a lot of thinking and experiments, one new device was born: "Tabla" which became the missing link for the people who wanted to listen to music straight off their computer to the higest level. Now we are proud to introduce the younger brother of Tabla, which is the Tabla Pico.
We are releasing our second USB Interface for HD Audio at a more affordable price than our previously existing Tabla. Based on the Human Audio philosophy, this device is also purely battery powered with a built-in high grade Lithium-Iron-Phosphate (LiFePO4) cell. Its specifications are identical to the original Tabla, the only difference being that the newbie has only one internal battery. The battery charging is fully automatized through the connected and powered USB port during idle times.
With this new device, we are able to connect an existing audiophile / high-end DAC (especially our newly developed "MUTO" HD Dac or the next generation "Libretto HD" CDP) to the PC in order to enjoy "BIT-PERFECT" playback of audio streams up to 24bit/192kHz. The Tabla Pico needs only one free USB 2.0 port on the PC and it outputs a S/PDIF coaxial digital signal to the DAC, via a 75Ω BNC connector.
Tabla Pico provides ultimate audio performance using a built-in battery of the highest grade(for the lowest ripple and the least noisy output performance), a very advanced ripple smoothing technology when using the USB power while the battery is being silently recharged, ultra-low jitter (< 3ppm) discrete onboard clocks for 44.1kHz and 48kHz multiples, a specialized pulse transformer on its real 75Ω BNC output and of course one of the best USB-Audio algorithm available on the market.
Specifications:
Resolution: up to 24 bit / 192 kHz
Bit-perfect playback support: YES
OS driver availability: for Windows, OSX and Linux
Input: USB 2.0
Output: 75Ω BNC (optional RCA adapter from BNC)
Powering: Built-in rechargeable LiFePO4 battery with ~8 years lifetime without memory-effect
Charging: Fully automated from USB power when idle(stop & power off state)
Operation time (in "GREEN" battery mode) without charging: at least 12 hours of continuous playback
Seamless switching (with LED indication) between the clear battery ("GREEN") mode and battery charging during playback ("YELLOW") mode without any audible glitch. The battery is permanently connected to the circuit, only the charge control switch goes on and off when required.
Charging time: max. 8 hours
Site web du constructeur : http://www.human-audio.com/humanaudioen ... _pico.html
Liens Critiques :
http://musiq-audiophile.blogspot.fr/201 ... -pico.html
http://www.forum-audiophile.fr/musique- ... 9-195.html
http://www.head-fi.org/t/598333/human-a ... impressive
Commentaires:
Mon nouveau DAC ayant une entrée USB, cette interface fait double emploi.
Mais attention, elle donne de remarquables résultats due à son auto- alimentation,
son isolation galvanique et sa compatibilité bit-perfect.
De plus, sa sortie BNC est idéale pour ceux qui possèdent une entrée de ce type.
Pour les autres, je fournis plusieurs adaptateurs BNC->RCA.
Fonctionne parfaitment sous Foobar + Jplay.
C'est une sorte de Hiface optimisée et sur batterie. Elle sublimera votre DAC.
2 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 53 invités
Petites annonces pour Convertisseurs 2 canaux et systèmes type SqueezeBox.
[VENDU] Interface USB Human Audio TablaPico sur BATTERIE
- Fenwick972
- Inscription Forum: 25 Avr 2012 16:55
2 messages
