Type : Carte son PCI
Marque : Lynx Studio Technology
Model et options : LYNX 2B + CABLES OPTIONNELS XLR->RCA
Prix de vente : 550€ frais de port inclus pour la France
Département où la marchandise est visible : 31
Montant des frais d'expédition : inclus pour la France
État de la marchandise : Comme Neuve
Première main : Oui
Prix neuf : 899€ + 110€ + frais de port de l'Allemagne
Facture disponible : oui sur demande
Date et lieu d'achat : site dbs en 2005 (il faut que je recherche la facture)
Emballage d'origine conservé : oui en parfait état
Documentations conservées : oui sur CD
Ne pas hésiter à me contacter en MP pour tout complément d'information.
Olivier
Description générale (désolé en Anglais sur site de vente) :
Lynx Studio Technology LynxTwo-B
Building on the award winning performance of the LynxONE, LynxTWO incorporates the latest generation converter technology to create a device capable of precision never before achieved in a PCI audio card. With performance that exceeds stand-alone converters, LynxTWO sets new standard for signal purity, versatile synchronization, powerful hardware mixing, and extensibility to support a variety of multichannel formats including ADAT & multiple AES/EBU.
Lynx Studio Technology, Inc. designs and manufactures professional audio products for applications such as audio production, delivery, and testing for recording studios, project studios, post production studios, home studios, and live concert settings. Utilizing cutting-edge technology to create the highest quality products at a good value to the customer, Lynx is focused on "linking" the professional audio world with computers by utilizing their many years of experience in both hardware design and device driver coding. This complementary expertise is borne out in reliable products that not only have great specifications, but are also shipped with extremely stable and well-tested drivers. Support for Windows and Macintosh platforms are standard for all products.
LynxTWO Features
* 200kHz sample rate / 100kHz analog bandwidth (Supported with all drivers)
* Four 24-bit balanced analog inputs and outputs ("A" Model)
* Two 24-bit balanced analog inputs and six 24-bit balanced analog outputs ("B" Model)
* Six 24-bit balanced analog inputs and two 24-bit balanced analog outputs ("C" Model)
* +4dBu or -10dBV line levels selectable per channel pair
* 24-bit AES3 or S/PDIF I/O with full status and subcode support
* Sample rate conversion on digital input
* Non-audio digital I/O support for Dolby Digital® and HDCD
* 32-channel / 32-bit digital mixer with 16 sub outputs
* Multiple dither algorithms per channel
* SMPTE time code reader and generator with MTC conversion
* Composite video genlock
* Word, 256 Word, 13.5MHz or 27MHz clock sync
* Extremely low-jitter tunable sample clock generator
* Dedicated clock frequency diagnostic hardware
* Multiple-board audio data routing and sync
* Two LStream™ ports support 8 additional I/O channels each
* Compatible with LStream modules for ADAT and AES/EBU standards
* Zero-wait state, 16-channel, scatter-gather DMA engine
* Windows NT/2000/XP Drivers
* Macintosh ASIO 2.0 Drivers
* Macintosh Core Audio Drivers
Included with the LynxTWO
* XLR Male to RCA Male S/PDIF Adapter Cable
* XLR Female to RCA Male S/PDIF Adapter Cable
* LynxTWO Installation and Users Guide
* Warranty Registration Card
* LynxTWO Setup Disk for Windows
* LynxTWO Audio Cable
* LynxTWO Sync Cable
* LynxTWO 24-bit/192kHz Digital Audio Card
LynxTWO Specificactions
Analog I/O
B Model
Two inputs / six outputs
Type
Electronically balanced or unbalanced, XLR connectors on L2Audio Cable
Level
+4 dBu nominal /+20dBu max. or -10dBV nominal / +6dBV max., software selectable in channel pairs
Bandwidth
< 10Hz - 92 kHz @ 200 kHz sample rate
< 10Hz - 46 kHz @ 96 kHz sample rate
< 10Hz - 23 kHz @ 48 kHz sample rate
(analog input to analog output)
Input Impedance
Balanced mode: 24 kW , Unbalanced mode: 12 kW
Output Impedance
Balanced mode: 100W, Unbalanced mode: 50W
Output Drive Capability
600W impedance, 0.2 µF capacitance
A/D and D/A Type
24-bit, multi-level, delta-sigma
Sample Rates
8 kHz to 200 kHz, including all standard rates with variable adjustment
Bit Depth
8, 16, 24 or 32 bit file types
On-board Buffer Size
16 Kbytes per input and output stream (mono or stereo)
Analog In Performance
(Analog performance specs measured at 44.1 kHz sample rate, 24-bit, card installed in computer)
Frequency Response
20 - 20 kHz, ± 0.05 dB at 44.1 kHz sample rate
Dynamic Range
117 dB, A-wtd.
Signal-to-Noise
116 dB, A-wtd.
Channel Crosstalk
<-120 dB, 1 kHz signal @ -1dBFS
THD+N
-108 dB (0.0004%) @ -1 dBFS
-104 dB (0.0006%) @ -8 dBFS
1 kHz signal, 22Hz - 22kHz BW
Analog Out Performance
Frequency Response
Dynamic Range
117 dB, A-wtd.
Signal-to-Noise
117 dB, A-wtd.
Channel Crosstalk
THD+N
-97 dB (0.0014%) @ -1 dBFS
1kHz signal, 22Hz - 22kHz BW
Digital I/O
Number / Type
One input and one output
AES/EBU or S/P DIF format, transformer coupled, XLR connectors on L2Sync Cable
Sample Rates
32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz
Sample Rate Conversion
Supports conversion ratios up to 3:1 on digital input, 128 dB dynamic range
Bit Depth
Control / Status
Complete subcode and channel status support
LStream Expansion Ports
Number
One external and one internal
Compatibility
Supports Lynx ADAT, AES/EBU, and other multi-channel expansion modules
Type
High-speed serial, eight channel input and output (each port) or sixteen channel input and output (single port), 24-bit data, 96kHz rate
SMPTE Time Code I/O
Type
LTC receiver (in) and generator (out) , BNC connectors on L2Sync Cable
Frame Rates
24, 25, 29.97, 30 Hz - drop and non-drop
Input Sync Rate
1/30 to 80 times nominal frame rate
Input Levels
200 mV to 10V / 10KW
Output Level
1V / 75W
Clock I/O
Number
External: one input and output, BNC connectors on L2Sync Cable
Internal: one input and output on board-mounted headers
Level / Impedance
TTL (clock signals) / 1Vpp (video) 75W
Type
Input: word clock, 256X word clock, 13.5 and 27 MHz video clocks, NTSC or PAL composite video; Output: word clock
On-board Digital Mixer
Channel Capacity
32 input channels, 16 sub outputs
Resolution / Dither
32-bit / TPDF, Shaped TPDF, or RPDF
Monitor Mixing
Any input to multiple outputs
Metering
Peak levels to -120 dB on all inputs and outputs
Connections
Audio Port
Bracket-mounted 25-pin female D-sub connector for analog audio input and output
Sync Port
Bracket-mounted 15-pin high-density female D-sub connector for digital input and output, sync in and out
Cables (Included)
L2Audio Cable
25-pin male D-sub to male and female XLR connectors on six-foot shielded twisted pair cabling
L2Sync Cable
15-pin high-density male D-sub to (1) male and (1) female XLR on six-foot shielded twisted pair cabling and (4) female BNC connectors on two-foot 75W coaxial cabling
Software
Windows Drivers
Windows 98 / ME / NT/ 2000 / XP: MME, ASIO 2.0, and DirectSound
Macintosh Drivers
ASIO 2.0 for OS 9
LynxTWO Mixer Application
Provides complete control of digital mixer and all hardware settings.
General
PCI Bus
Version 2.2 compliant
Data Transfers
Up to 132 Mbytes/sec using custom 16-channel, zero-wait state, scatter-gather DMA engine; bus masterin
Size
5.0" H X 7.4" W X 0.75" D (half-size PCI card)
Shipping Weight
3.25 lbs. with cables
Certifications
CE and FCC Class B
7 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 10 invités
Petites annonces pour PC bureautique, Carte (mère, son, graphique, réseau), Alimentation, Mémoire, Clavier, Souris et autres composants de PC.
Déplacé dans le bon forum
Adhérez à l'association pour que le site progresse : http://www.homecinema-fr.com/asso.php/
- frahlt
- Membre d'Honneur
- Inscription Forum: 05 Mai 2006 4:29
EDIT
oups, je vais t'envoyer un MP
- Cr4P
- Inscription Forum: 25 Sep 2006 20:06
Up
HC: JBL Pro, JVC NZ7, Marantz 7706, Zidoo Z1000pro, Pana UB9000
HIFI: JBL Array 1400, Marantz PM14S1 SE
Tochiro - Modérateur Home-Cinéma
- Inscription Forum: 21 Nov 2004 18:47
Rappel : les annonces oubliées par leur auteur sont fermées au bout d'un mois. Toujours d'actualité ?
- frahlt
- Membre d'Honneur
7 messages
