Vends DILA JVC SX21.
Etat Neuf
Heures de fonctionnement, moins de 170H
Tarif : 4000 €
Neau prix : 3500€
Envoi possible en chronopost avec pakage sécurisé : 50€
Livraison le lendemain matin au 4 coins de France.
Caractéristiques :
Intelligent, advanced presentation projection
1,400 x 1,050 resolution for true SXGA+ display without compression
High brightness of 1,500 ANSI lumens
93% aperture ratio for non-pixelated "crystal clear" images
Proprietary image enhancement technologies
* ADPC: Optimizes picture quality regardless of the input signal resolution to ensure
smooth, clear images. Resizing function for full screen projection of UXGA/XGA/SVGA/VGA images
*10 bit digital gamma correction: Facilitates accurate gray scale and color reproduction
Digital shift
Auto-alignment function for automatic adjustment of tracking, phase and position
16 X digital zoom function, freeze frame
New GUI on-screen display (selectable from 8 languages)
JVC color profile (4 color profile modes available)
DVI-D Plug & Play
High-performance video/cinema projection
JVC's proprietary D-ILA® technology for unsurpassed image quality
High contrast ratio: 800:1
Full signal input capability (HDTV format compatibility): 720p, 1080i (60, 50), 1080p (24, 25, 30), 1080p, (24sF, 25sF, 30sF)
H/V digital keystone correction (horizontal: ±10 degrees, vertical ±30 degrees)
Selectable color temperature (6500/STD/user)
Easy-to-change lamp and low running cost
Original JVC D.I.S.T.
Image device 3 D-ILA®(0.7 inches diagonal)
Projection lens DLA-SX21: Zoom lens
(2:1 - 2.6:1, power focus, 40% offset)
DLA-SX21S: 1:1 short-focus fixed lens (0% offset)
Brightness 1,500 ANSI lumens
Resolution 1,400 x 1,050 pixels (full coverage of SXGA+, SXGA (1,280 x 1,024) graphics (SXGA, XGA, SVGA, VGA))
Source resolution Up to 1,600 x 1,200 (compression of UXGA)
Scan frequency Horizontal: 15 to 120 kHz
Input Vertical: 24, 25, 30, 50 - 120 Hz
Analog RGB x 2 (D-sub 15 pins (female) x 1, R, G, B, H, V x 1)
Y/C separated x 1
Composite x 1
Component x 1 (Y/R-Y/B-Y, Y/PB/PR)
Audio x 1
Output PC monitor: D-sub (female)
Lamp 250 W, NSH
Power consumption 340 W
Power requirement 100 - 240 V, 50/60 Hz AC
Dimensions
(WxHxD)
298 x 124 x 360 mm
Weight 5.9 kg (13 lbs.)
30 messages • Accèder à une page • 1, 2
Tarif et autres en MP
Merci de proposer un prix sinon ton annonce sera archivée
LaurentV
Modérateur
De plus, les modérateurs se réservent le droit de refuser toute annonce ne mentionnant pas un des points suivants :
- références de l'appareil (nom de la marque et du modèle)
- prix de vente de l'appareil (HCFR n'est pas un site de vente aux enchères !!)
- numéro de série de l'appareil si son prix excède 1000 euros
Si une de ses conditions n'est pas remplie les modos pourront suspendre l'annonce en l'archivant et demander les infos complémentaires par mp à l'auteur.
- LaurentV
UP pour une superbe machine
- BA
- Inscription Forum: 10 Mar 2000 2:00
Merci d'avoir proposé un prix
- LaurentV
A 4000 Euros, c'est une affaire
Patrick.
Patrick.
- Patman
- Inscription Forum: 05 Mar 2001 2:00
Je le pense également
- BA
baisse de prix a 3500€ +fdp
- BA
Up pr le WE,
Je pense que la vente se fera certainement plus aisément sur les magazines
Vous ne vous plaindrez pas après
- BA
Tu sais BA, je pense que personne ne ce plaint, mais juste après les fêtes, là comme ça, une annonce ENNORME comme la tienne .. juste avant les impots, la St Valentin ..
Bref, je suis certain que bcps d'entre nous sont interessés .. mais .. voilà, juste un peu "éssoufflés" financièrement.
Tu nous le fait en 10x ?
Bonne vente !
- Lohengrin
- Inscription Forum: 11 Juil 2002 14:30
... Eh oui, c'est pas simple les ventes en ce moment ..........
- areboulleau
Quel malheur qu'un aussi bon produit ne trouve pas acquereur illico à ce prix
- fyx
- Inscription Forum: 06 Fév 2004 9:32
Qui sait ? Demain est un autre jour .... et peut etre que ...
- areboulleau
30 messages
