Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Le Chaland et 9 invités
Recherche de Matériel Audio/Vidéo.
cherche ampli stax
Message » 01 Jan 2010 19:47
je cherche un ampli stax srm-717, celui de l'omega 2 en version transistor
MERCI !
PBL
Inscription Forum: 01 Aoû 2001 2:00
Message » 01 Jan 2010 20:42
new croco, Modérateur PA/BP/PROs
new croco
Inscription Forum: 03 Mar 2006 12:31
Message » 04 Jan 2010 13:25
PBL a écrit:je cherche un ampli stax srm-717, celui de l'omega 2 en version transistor
MERCI !
l'ampli de l'omega 2 en version transistor c'est le srm-727 ;)
Le 717 c'est la version antérieure il me semble (celle de l'omega)
Specs du SRM-717 :
Type STAX SRM-717 Driver Unit
Exclusively designed and manufactured to drive STAX Pro Earspeakers
Frequency Response DC - 100 kHz
(when a SR-007 or SR-404 is connected) Maximum Output Voltage 450Vr.m.s. 20-10KHz
Total Harmonic Distortion Less than 0.01%, 100-10KHz/300Vr.m.s.
Amplification 60dB
Rated Input Level 100mV/100V output
Input Impedance 50 k Ohms
Bias Voltage 580V×2
Supply Voltage AC240V (±5%) 50/60Hz
Power Consumption 45W
Operation Temperature 0-35 Degree
Dimension (W)195×(H)103×(D)420 mm
Weight 5 kgs
Specs du SRM-727 :
Type: All-stage semiconductors Low noise dual FET input NON-NFB Class A operation, Pure balance DC amplifier configuration Earspeaker driver unit
Solid state output stage
Inputs: 2 x RCA, 1x XLR Balanced
Frequency response: DC-115 kHz (SR-007 or SR-404, when using one unit)
Rated input level: 200 mV / 100 V Outputs
Maximum input level 30 V r.m.s. / at Minimum volume
Amplification: 54 dB (x 500)
Total harmonic distortion 0.01% / 1 KHz, 100 V r.m.s. output SR-007 or SR-404 Signature
Input impedance 50 KΩ / XLR balance 50KΩ2
Maximum output voltage 450 V r.m.s. / 1 KHz
Power consumption 55 W
External dimensions 195 (w) x 103 (h) x 420 (d) mm (including VR knob and pin jack (20 + 10)
Weight 4.7 Kg
quelque infos ici et (et probablement sur le topic Stax)
corsario
Inscription Forum: 01 Fév 2005 18:39
Message » 14 Jan 2010 18:37
Finalement, je me suis pris un WOO AUDIO GES
PBL
Retourner vers Matériels Audio et Vidéo
