Dear Kiwii,
According to your projector we recommend you choose the Obisidian Long-throw material.
Here is the link for you https://www.alibaba.com/product-detail/ ... 1ce5sFtBj5
Thank you
Best regards
TinHi,
I love your concept of Pull Up screen but I found myself incapable of finding one usable with DLP Short Throw (and not UST) projector. Specifically the Optoma HD29HST.
On your website I can see the grey cinema material which seems to be adequated:
But I can not find your Vividstorm Electric Tension Floor Screen at your partner shop with that grey Cinema material. Am I missing something?
Cordially.
EDIT : en faite je me rend compte que j'ai mal lu ton message a la base, tu disais qu'ALR c'était bien pour du dlp ... Le confinement ne me réussit pas.
