d'après Rting.com la qualité de l'image semble similaire entre C8 et B8:
https://www.rtings.com/tv/tools/compare ... eshold=0.1de même entre C7 et B8 c'est identique:
https://www.rtings.com/tv/tools/compare ... eshold=0.1mon avis vos réglages ne sont pas bon, déjà je serrai vous je ferrais une mise à Zéro ou Reset du téléviseur, en suite je vérifierais les mises à jours du firmware du Téléviseur C8 en ce moment le C8 en est au Firmware 04.10.65 est ce le cas de votre téléviseur:
https://www.lg.com/fr/support/support-p ... g-OLED65B8Detailed applicable model list : Please check with reference Tab exactly
* SW information
1. Improvement
1) To improve no audio issue when changing sound out from ARC to TV Speaker in QSM Mode On
2. Applicable model list
55SK9500PLA
65SK9500PLA
55SK9500LLA
65SK9500LLA
49SK8500PLA
55SK8500PLA
65SK8500PLA
49SK8500LLA
55SK8500LLA
65SK8500LLA
49SK8100PLA
55SK8100PLA
65SK8100PLA
75SK8100PLA
49SK8100LLA
55SK8100LLA
65SK8100LLA
49SK8000PLB
55SK8000PLB
65SK8000PLB
86UK6500PLA
86UK6750PLB
OLED55B8PLA
OLED65B8PLA
OLED55B8LLA
OLED65B8LLA
OLED55B8SLC
OLED65B8SLC
OLED55B8NLC
OLED65B8NLC
OLED55B8SLB
OLED65B8SLB
3. Release History
[03.00.95]
1. Minor Bug Fix
[03.01.40]
1. Revert the Tricolor New Spec Implemntation 1.4 (CIS Only)
2. To improve Magic remote control operation disabled issue during Magic remote control on/off repeatedly.
[04.10.06]
1. Google Assistant is also available in the following countries.
(Australia, Canada, France, Germany, Korea, Spain, United Kingdom)
2. Alibaba voice AI feature is available in China.
3. You can control the TV (channel change, volume control, input switch, etc.) using the Google Home / Amazon Echo Smart Speakers in the following countries as well.
(Google Home : France, Germany, Japan, Korea)
(Amazon Echo : Australia, Canada)
4. We have reduced the amount of time the cursor is displayed when not moving the MRCU.
In addition, Minor Bugs are fixed.
[04.10.20]
1. To improve that the subtitle is not displayed when HbbTV app in on
[04.10.36]
1. To improve issue of external AV Receiver "Not Supported" error when playing Dolby Atmos content
[04.10.65]
1. To improve no audio issue when changing sound out from ARC to TV Speaker in QSM Mode On
en suite, y a que Lum.OLED à mettre entre 60 et 80 dans une pièce éclaire et entre 30 et 50 dans une pièce dans le noir, ne pas augmenter luminosité ou alors au pire entre 45 et 57, mais suivant les source mettre luminosité à 57 et plus va faire baisser le contraste, donc si tu ne sais pas laisse luminosité à 50.
le mode d'image à privilégier c'est Cinéma.
si ta sources est HDR alors activé HDMI ULTRA HD Deep Colour, pour les périphérique HDMI qui serai compatible HDR10 et ou Dolby vision ou HDR HLG.
éventuellement activé dans Contrôle Expert:
Contraste Dynamique sur moyen ou Élever
Résolution Élevée sur Élever
Gamme de couleurs sur Étendue
Amélioration des Bords sur Activé
dans le menu Option si la sources est HDR ou 10 et 12 bits, je mettrait: Niveau de Noir sur Élever( ça peut parfois obliger de baisser Lum.OLED ou l'autres Luminosité suivant les sources, à tester avec des Mires une mire de contraste), en gros ce paramètre va débouché le contraste dans les basses lumière c'est pertinent si la sources est 10 ou 12 bits par couleur.
pour info Lum.OLED c'est équivalent à un rétroéclairage je sais y en a pas sur OLED, c'est pour ça que j'ai dis équivalent, autre info augmenter luminosité va avoir pour incidence de faire baisser le contraste, donc en TNT pour le moment vu que les sources sont 8 bits il vaut mieux laisser à 50 ou 53, en 2024 la TNT passera à la UHD et au HDR donc ce sera différent.
si la source est HD ou Full HDR laisser la netteté entre 15 et 20, si la source est UHD suivant la qualité d'encodage entre 23 et 30.
