Modérateurs: Staff Haute-Fidélité, Staff Univers Casques, Staff Juridique • Utilisateurs parcourant ce forum: dabass, julien goutret, laurent67520, MickeyCam, pm57, Symphone, Taisetsu458, Tayoroma, ti_punch, viddal et 59 invités
Les "pétoires" de l'extrême Ep IV
- P.LM
- Contributeur HCFR 2018
- Inscription Forum: 30 Avr 2007 19:30
La même (?) équipée avec un bras
TECHNICAL SPECIFICATIONS
Rotational speed: 33.3 rpm & 45 rpm
Tonearm length: 9 to 12
Power supply: dual channel pure class A linear DC, CPU controlled
Motors: 2× Maxon DCX DC motors
Motor mounts: Delrin enclosure, height adjustable
Speed guidance system: continuous dual-loop feedback, continuous correction
Sensors type: hall sensor (platters) /optical encoder tachymeter (motors)
Correction cycle: 60 times/rotation. 0.015% max. 0.005% min
Control CPU: independent system for each platter
Platters type: resonance tuned compressed phenolic/aluminium/copper
Platter weight: 8.2kg (x2)
Drive belts: 2 silicone/Viton, one-piece moulded, 0.230/platter
Compensation pulley: Teflon and zircon bearing
Main bearings: dual hydraulic isolated inverted sleeve and ball
Shaft type: grounded heat hardened tool steel, surface treated
Ball type: precision ceramic 7mm
Suspension: full floating top suspended, level adjustable
Elastomers: 317 elastomers, Viton/silicone proprietary mix
Dimensions (W×D×H, no SCPS): 71 × 37 × 29cm
Weight: 65kg, PSU 22.5kg, SCPS-D 22.5kg
Price Kronos Discovery turntable: £100,000
SCPS-D power supply: £20,000
Kronoscope Tonearm: £20,000
- jybliste
- Inscription Forum: 30 Aoû 2011 22:48
Une fois payees les 140000 livres, il manque encore la cellule ...
On met quoi comme cellule sur un truc pareil ?
- dr rotule
- Contributeur HCFR 2022
Autant acheter une platine à lecture laser
Hifi : PCH A500, ONKYO PR-SC5009, InterM, DITTON66 Studio Monitor, NAKAMICHI RX202, BX300, 682ZX , HC : JVC RS55, PCH A500+Oppo93+DMP-400, K+H O300 & O310+Hermes2, SidneyAR12 (Hypex400),Philps65OLED873, BLON B20.Chanteur:ContreTénor
gbaya - Membre HCFR
- Inscription Forum: 14 Avr 2003 18:47
Une petite ZYX UNIverse Optimum...
"Parce qu'avec une platine de 150.000€, il faut bien une cellule de 17.000"
roland_de_lassus - Staff Haute-Fidélité
gbaya a écrit:Autant acheter une platine à lecture laser
Le plaisir notamment lié à l'effet pétoire de l'extrême ne serait sans doute pas le même.
- jybliste
jybliste a écrit:gbaya a écrit:Autant acheter une platine à lecture laser
Sans parler de l'inimitable chuintement du diamant sur le sillon du disque, et les sympathiques craquements qui viennent ponctuer le plaisir musical
- dr rotule
Le sujet a été abordé tellement de fois.
Chacun prend son plaisir comme il l'entend
- jybliste
jybliste a écrit:Chacun prend son plaisir comme il l'entend
Oula ! Desole, je ne voulais pas creer le chaos ...
- dr rotule
P.LM a écrit:
pas spécialement fan mais il faut reconnaitre le bel ouvrage
- mariofan de triangle
- Inscription Forum: 07 Juil 2005 15:13
P.LM a écrit:
J'adore le design des avantgarde
- gloinfred
- Inscription Forum: 20 Mar 2008 16:15
d'avant garde, ou fiction à la Jules VERNE ?
- sax.tenor
- Inscription Forum: 16 Mar 2019 12:15
Il me semble que ces Avantgarde avaient un peu déçues face aux JBL 9800 sur un des derniers numéros de la NRDS, chez un riche collectioneur japonais qui avait 4/5 installations différentes de très haut vol
- loulou65
- Inscription Forum: 12 Sep 2008 6:03
