Modérateurs: Modération Forum Installations, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Doubs25, Fre.Mo, Google Adsense [Bot], Kmylle18, marc69, MIB91, pereti, retour1984, Salvador Hard-on, SYLEX et 109 invités
install de Fafa : HDR et Atmos. :-)
voici un autre source:
http://www.hometheatershack.com/forums/ ... 1-2-a.html
Atmos for home consists of 7 "bed" channels (which is the same as the standard 7.1 we are used to), plus audio "objects." Sounds can be encoded to the "bed" channels as before, or they can be encoded as objects - not assigned to a particular channel but rather to a location in space. A sound that is encoded in a bed channel will always play from that channel. An object, however, will be steered by the Atmos decoder, or renderer (which knows the speaker layout and positioning), to the appropriate speaker or set of speakers to make it sound the way it was intended.
The way an Atmos soundtrack works on blu ray is as follows: First of all, the whole thing is encoded using the TrueHD scheme, just as a non-Atmos track is. The difference is that an Atmos track has the objects encoded as metadata. When you play an Atmos soundtrack using a standard 5.1 or 7.1 system, the objects are folded into the "bed" channels so you hear them but not with the same precision or in exactly the same way as intended. But if you play the Atmos soundtrack on an Atmos receiver configured for an Atmos layout, the receiver will decode the "bed" channels and the object metadata and steer it all to where it needs to go, within the context of your particular speaker layout.
Je n'a aucun idée qui est bkeeler 10, mais il confirme ce que a dit pasender. Je continue mon recherche.
- Rooky2
- Inscription Forum: 26 Jan 2016 12:01
Bien compliqué tout ça...
L'essentiel, c'est que ça marche.
Fafa - Administrateur Suppléant de l'Association - Secrétaire Adjoint & Superviseur Forum Univers TV
Rooky, t'inquietes , perds pas ton energie, je suis sur de moi , certaines docs Dolby donnent l'info, confirmée maintes fois y compris par des mixeurs pro.
Tu peut aussi le voir clairement sur les videos qui montrent la console de mixage Atmos.
Le document que tu cites a 22:19 est en effet très trompeur
Le mix Atmos est bien un bed 7.1 plus des objets, d'ailleurs certains films on fait un peu scandale car il suffit qu'il y ait un objet pendant une seconde pour pouvoir poser le label Atmos.
Un des premiers films Atmos est connu pour ca, Transformers.
Depuis cela s'arrange et beaucoup de films exploitent bien les objets (Lucy, Sully, MadMax, Gravity, ...), mais un autre film récent est connu pour avoir un seul objet Atmos qui revient pendant plusieurs scènes et c'est tout, mais j'ai promis au mixeur de pas trop ebruiter l'info
Son 9.2.4 (proc. 7.1.4): Marantz 7009 + Lexicon CX-7 / Monitor Audio Gold GX (300+C350+S12+S2+S2) [9 bas dont 4 surrounds] + moniteurs Bose 101 [4 hauts] / Klipsch R 115 + Sydney AR12
Video UHD: Panasonic UB700 + Epson 9300
(Détails de ma pièce dédiée)
- pasender
Je change de sujet et vous prie de m'en excuser.
Y'a quelques mois (voire 2 ans, en fait), l'une des pièces de la maison a servi de grenier le temps de pouvoir bien aménager mon "antre".
Voici ce que cela donnait :
Inutile de vous dire que la vocation de cette pièce n'était pas d'être en bordel couvré, surtout que ma femme y a dès le départ vu une toute autre utilisation.
Ca a donc pas mal évolué, avec quelques travaux d'aménagement, et depuis quelques heures, ça prend même une toute autre signification.
Notre petite Puce va pouvoir bientôt intégrer sa chambre après les 3 jours d'observation à la maternité.
Profite de tes nuits et revends ton matos
Très jolie pièce
Très jolie pièce
- Rugbystick
- Inscription Forum: 13 Jan 2007 14:50
JAMAIS je ne revendrai mon matos.
Ou alors, ce sera pour passer à l'Atmos Laser holographique!
Merci pour le compliment. On s'est fait un peu plaisir avec la déco pour la chambre de notre enfant.
Même si finalement ce mobilier ne sera utilisé que quelques années (voir 2-3 mois pour le couffin caché derrière les meubles à droite), y'a pas de raison de ne pas se faire un peu plaisir.
Tu verras, il y a même des choses qu'on utilise jamais Nous n'avons par exemple jamais réussi à mettre notre fille dans un porte-bébé, pourtant on avait le meilleur du marché Elle ne supportait pas ça.
- Rugbystick
FÉLICITATIONS FAFA ! Quoi de mieux qu'une jolie pièce pour accueillir bébé !
- dkhome
- Membre HCFR Contributeur
- Inscription Forum: 08 Jan 2017 17:54
Et puis tu peut toujours lui mettre une install Atmos 7.1.4 en accrochant les enceintes hautes au barreaux du lit, pour passer les berceuses
- pasender
Merci à vous.
Ne me tentez pas trop avec une install dans le lit du bébé. J'en suis capable!!!
Plus sérieusement, je compte lui faire découvrir rapidement les joies de la musique et la qualité à y percevoir.
Fafa a écrit:Merci à vous.
ouai fou lui un dédé dans la piole pendant que tu y est
- oolivier
- Inscription Forum: 18 Fév 2006 17:43
pasender a écrit:Et puis tu peut toujours lui mettre une install Atmos 7.1.4 en accrochant les enceintes hautes au barreaux du lit, pour passer les berceuses
IMPOSSIBLE -> Be DIYer !
IntenseEleven - Superviseur Forum DIY & Contributeur HCFR
- Inscription Forum: 29 Déc 2008 13:51
Félicitation pour le garçon
Le plus simple à cet âge et à bas volume hein c'est de le bercer tous les soirs avec une musique de film
Caribbean's Space 62
fanvw a écrit:Félicitation pour le garçon
du John Williams !!!
https://www.amazon.fr/Williams-Celebrat ... ms+blu+ray
- N3°
- Inscription Forum: 26 Oct 2004 16:17
C'est une fille.
Je pense acheter quelques comptines douces.
Du John Willians, c'est un peu trop pompier!
