Sur Audiogon, on voit beaucoup de CR enthousiastes sur les modifications apportées par "Great Northern Sound", en particulier sur le lecteur Wadia 860x, qui en feraient une référence ...
Les modifications sont les suivantes :
"General modification details:
• The power supplies are improved significantly. These modifications include premium grade Black Gate filter capacitors throughout the unit (larger values than the stock unit), removal of all current limiting resistors on regulators, the installation of Bybee Quantum Purifiers on the AC input and all power transformer secondary windings, standard diode bridges are replaced with high speed rectifiers, many additional local energy reservoir capacitors (Black Gate) are added, a discrete 5 volt regulator circuit is installed in place of the main 5 volt supply for the digital section, all diodes and regulators are treated with MusiCote, etc
• The analog output section is rebuilt by removing the “CE” surge suppression and back-EMF devices that were installed to meet regulatory requirements for Europe. The latest Caddock resistors are used in critical areas. The analog section caps are upgraded in terms of value any quality to the latest Nichicon surface mount type.
• Bybee Quantum Purifiers are installed in place of the ferrite filters in the output stage.
• A silver leaded special “digital” Quantum Purifier is installed in the digital signal path.
• Wide bandwidth, low distortion output transformers are installed at the balanced outputs of the unit (unless the RCA outputs are specified) to isolate the output stage from the amplifier and block noise/RF output via direct wire/ground connection. This offers a major improvement in providing a more full, rich sound. The signal to noise ratio is increased significantly by these devices as well.
• All chips on the DAC board are treated with a light layer of MusiCote. This results in a significant increase in resolution.
• The bridge/platter assembly is raised slightly with neoprene washers to accommodate a damping mat (provided) that works extremely well in this mechanism. Prior to this mod, it was not possible to use these types of devices with the TEAC VRDS transports and allow use with or without the mat.
• There are well over 100 changes that are incorporated in this upgrade. We are happy to discuss them in more detail, call and speak directly with Steve Huntley at GNSC for more info. "
Cette modif est facturée 3325 dollars.
Quelqu'un connait cette boite ?
Parmis les bricoleurs de génie qui fréquentent ce forum, y a-t-il des avis sur les modifs effectuées ?
Marc
7 messages • Page 1 sur 1
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 30 invités
Marc 75 a écrit:Sur Audiogon, on voit beaucoup de CR enthousiastes sur les modifications apportées par "Great Northern Sound", en particulier sur le lecteur Wadia 860x, qui en feraient une référence ...
Marc
c'est cool il la donne leur modif à ce prix
- icorck
- Inscription Forum: 29 Mai 2002 12:38
Bah, c'est tout juste le prix d'un bon câble ...
- Marc 75
- Inscription Forum: 27 Sep 2002 22:58
Marc 75 a écrit:Bah, c'est tout juste le prix d'un bon câble ...
tsiiii meme pas mal
- icorck
Salut Marc
Ils y vont pas avec le dos de la cuillère.
Pour ce qui est des condos de sortie analogique, les NICHICON sont introuvables.
Par contre BLACK-GATES ou ELNA en font des très bon.
- EUVRARD
C'est quoi ça musicote ?? ca fleure bon le machin anti- biiiipp (vous savez ceux qui nous sautent dessus chaque fois qu'on prononce leur nom)
- adol
- Inscription Forum: 18 Jan 2002 2:00
adol a écrit: (vous savez ceux qui nous sautent dessus chaque fois qu'on prononce leur nom)
Heu .... les modos ?
j'ai bon ?
- Marc Terpsichore
- Inscription Forum: 05 Sep 2002 15:28
7 messages
