37 messages • Accèder à une page • 1, 2, 3
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: 974eric, ajds, alexins, brubru, Brunold, ceili-29, coucouse, delennsheridan, duf666, Edis, fabien_m2002, Gia59, ingalls, JOGAMA, Kris Tof, Moboutou, mouchli, nico034, Patbon21500, Patoche21, Sergio-22, shenos, Singha29, sokje84, Solitaire555, tony51, ymlik, yoann2004 et 235 invités
Zidoo Z1000 4K UHD (Realtek RTD1296DD)
Dommage que celui-ci ne marche pas sous Linux.
- Mumakil
- Inscription Forum: 20 Juil 2014 18:07
Bonjour a tous,
quelques photos du Z1000
a bientot
a bientot
- OlivierQC
- Contributeur HCFR 2018
- Inscription Forum: 23 Avr 2003 14:01
Toutes les images de l'unboxing sont ici: https://www.hd.club.tw/thread-248555-1-1.html
Salle dédiée 7.1.4 3D 4K :Onkyo TX-RZ50, Emotiva BasX A3, SVS Prime Bookshelf + Center + Satellite + Elevation, Ultra Surround, SVS PB-2000 Pro, LG Oled CX, BenQ W4000i, Oray cadre, Panasonic UB820, PS5, Xbox Series X, Zidoo Z9X, Shield TV Pro,M9702 V3
evangelion77 - Membre HCFR Contributeur
- Inscription Forum: 19 Oct 2010 23:15
Savez-vous si il tourne avec Kodi 18 !?
- HT76
- Inscription Forum: 24 Oct 2001 2:00
Le nouveau firmware V2.2.82 est disponible ici : http://www.mediafire.com/file/qln7bic6u ... e.zip/file
2.2.82 Changelog:
System
1. Fix the problem that Google Play cannot log in (should reinstall Google Play after upgrading).
2. Add rec. 2020 mode for HDR to SDR transfer.
3. Optimize WIFI connectivity rate and stability. Fixed Player exception caused by NAS occasional disconnection when WIFI is connected.
Optimize the stability of online playback when connecting WIFI.
4. Optimize NFS connection strategy to avoid Player (Gallery) error caused by network fluctuations.
5. Fixed problem that some audio demo video playback was not smooth.
6. Fixed the no sound problem when playing NAS video caused by network environment fluctuation.
7. Optimize Bluetooth connectivity stability.
8. Optimize system stability.
9. Add mobile phone control function (mobile phone can control all functions of the player).
Device name can be changed in "All Apps" -> "Control Center".
The mobile control app is available on Google Play and will be updated to the Apple Store later.
Please search earch zidoo controller via google play
Video Player
1. Subtitle download supports two or more languages downloading at the same time.
2. Optimize DLNA mirror function.
3. Fix Player (Gallery) crash problem caused by ASS,SSA subtitle compatibility.
Bluray Navigation
Poster Wall
1. Optimize custom wallpaper loading to solve the problem of loading long images or high resolution images that are easy to crash.
2. Optimize search interface.
3. Optimize stability.
Music Player
1. Completely rewrite the playback engine, upgrade to ZIDOO MUSIC V5.0
2. Optimize playback stability, fix SACD unexpected jump problem.
3. Add more audio format supporting, such as AIF.
4. In the folder page, support select the original directory structure to browse.
5. Optimize the accuracy of CUE file playback
Quick Settings
1. Subtitle download adds support for multiple languages
2. Modify the settings of the audio original sample rate output switch.
2.2.82 Changelog:
System
Video Player
Bluray Navigation
Poster Wall
Music Player
Quick Settings
Bonjour, je réfléchis a mettre a la retraite mon PC HC pour passer sur une de ces box. Le Z1000 m’intéresse particulièrement, mais j’ai le sentiment qu’il est moins mis en avant que les H20 / H20 Pro, a la fois sur le site Zidoo et sur les forums.
Est-ce qu’il y peut y avoir un problème de support futur (genre les firmware poussés pour H20 mais pas pour Z1000? Ou encore, si ce sont les memes firmwares, mieux teste sur les H20 / H20 Pro?).
- xliv
- Inscription Forum: 16 Sep 2011 18:00
Rajout de tests du Z1000 en première page :
https://www.4kfilme.de/zidoo-z1000-4k-m ... -heimkino/
https://www.hifitest.de/test/mediacente ... 1000_18546
Qui l'a et pourquoi pas comparé avec un Zappiti one SE HD ?
- ASP68
Ajout de tests (liens) en première page.
试试这个新版本
型号:ZIDOO_Z1000
版本号:v2.3.17
链接:http://apidl.zidoo.tv/Z1000/v2.3 ... 427_ota-package.zip
MD5: A6003E247F054E15E16BB088F94A7FF2
升级方式:OTA
1,修复海报墙豆瓣与TMDb匹配
2,优化肉酱盘无缝播放
型号:ZIDOO_Z1000
版本号:v2.3.17
升级方式:OTA
1,修复海报墙豆瓣与TMDb匹配
2,优化肉酱盘无缝播放
- Z.Chmielewski
- Inscription Forum: 13 Mai 2019 16:15
Salut à tous,
j'hésite à prendre un Z1000 pour remplacer mon z9s, quelqu'un a vu une différence de qualité d'image entre les deux appareils ?
- xsander
- Inscription Forum: 31 Mar 2018 9:28
Il y en a aucune, tu a droit à un emplacement pour HDD par contre.
- OlivierQC
Nous n’en avons pas perçu entre le uhd 2000 et la z9, donc amha il n’y en a pas...
Coco68 - Modérateur Home-Cinéma
- Inscription Forum: 30 Nov 2010 22:14
Merci pour vos retours,
il est plus beau le z1000, il est magnifique,
par contre il prend beaucoup plus de place que le z9s !!!!!!! Un peu plus de connectiques qui ne sont pas négligeables, le menu est différent aussi je crois ( media center), ça fait plus costaud, plus platine bluray, 1kg de plus que le z9s !!!
Je peux l'avoir à moitié prix€ !!!!!
Donc j’hésite à le prendre ou attendre un peu pour les nouveaux jouets Zidoo avec cette nouvelle puce plus rapide qui prendra peut être en charge ce dobly vision et hdr 10+...
- xsander
37 messages
• Page 2 sur 3 • 1, 2, 3
