Change log:
Version 3.6.1
Fix: ATSC EPG works again
Fix: Shoutcast Filter is now part of the installer again
Fix: game gravitron works now
Change: Channellist is saved automatically after channelscan.
Change: Timers.xml is saved after most changes.
Change: Favorites are written now when pressing the save button.
Fix: knc detection
Fix: MultiCore CPU settings did not worked properly.
Fix: DVD-Prev Chapter was not working.
Change: Forms outside the monitor are now repositioned
Add: Popup menu in Mainwindow now shows the filterlist.
Change: All filters are listed in Filterlist.
Fix: COM: ChannelID was still calculated the old way.
Change: On saving a backup of Timers.xml is created.
Change: 10x tuning limit removed
Change: USALS (E/W, N/S now possible).
Change: <Auto> now replaced with <System Default>.
Change: Subtitles: Now there is always a entry Subtitles -> None, in case a channel transmits only "No subtitles available" (ttx ZDF). Before you couldn't disable this, case it was not marked as subtitle page...
Change: TTx Subtitles: On switching channel now subtitles are cleared.
Fix: Wrong AC3 decoder detection.
Fix: Instancehandling in Vista.
Fix: Mp3 Decoder handling.
Fix: Skystar 2 <-> Server4PC conflict.
Fix: Filedevice: Didn't work.
Change: Plugins can now retrieve the whole multiplex
Change: More Vista compliant Icons
J'avais noté un petit bug à propos du menu "option" donnant acces à la gestion des favoris dans les versions antérieures 3.6. Je ne peux pas vérifier mais j'espère qu'il a disparu.
Tester aussi la compatibilité CoreAVC/core2duo
5 messages • Page 1 sur 1
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 47 invités
DVBViewer 3.6.10
- trifon
- Inscription Forum: 22 Aoû 2003 14:59
Je ne retrouve plus le lien pour le télécharger. As tu le lien ?
Eric
Eric
- guigui82
- Inscription Forum: 24 Nov 2005 17:05
Il faut d'abord l'avoir acheté et donc avoir acces à "member section" en petit dans la page d'accueil juste à coté de "lost & found"
http://www.dvbviewer.com/en/index.php
A propops, c'est la 3612 maintenant et j'observe que le bug du menu "option" en bas de "chanel list" a disparu.
- trifon
Une petite question : ce soft est-il compatible avec une Nexus ??
- Banshee
- Inscription Forum: 06 Avr 2001 2:00
Banshee a écrit:Une petite question : ce soft est-il compatible avec une Nexus ??
Non, hélas, même en mode soft uniquement.
Il semblerait qu'il y ait incompatibilité entre le H264 et les Nexus alias Technotrend SS1/Premium. Tous les softs compatibles avec ce codec HD ne supportent pas cette carte.
- trifon
5 messages
