It seems you present an interesting situation if I understand the translation correctly. If you have burned a CD from the 96/24 downloads the downsampling conversion will cause the disk to not sound as good as downloading the 44.1 files and burning the disc from those. In general, it is not considered a good idea.
It is difficult to explain in a translation. If you write to me directly, we will look up your receipt and send you the samples at 44.1 and send them at no charge.
cookie@bluecoastrecords.comIf you are new to our SACDs or uncompressed mastering, you will find that the music appears 'softer' in volume than the over compressed music of today. That is because we believe that over compression destroys the full dynamic range and lessens the emotional impact. On the Blue Coast Collection SACD hybrid, we chose to lightly compress the CD layer only so that people could choose. The SACD stereo is the realistic dynamic and appears softer than the CD. However, the loud sections are louder and the soft sections are softer on the SACD as they were actually recorded.
The 96/24 files were made from the same master as the SACD layer and have the full dynamic range. By burning a CD from the 96/24 files, you will have the full dynamic range (appearing softer) and will probably lose high and low frequency in the conversion to 44.1.
Your best solution is to keep the 96/24 files until the time when you have a DAC to listen through. I suggest reading at computeraudiophile.com for some very good information about the latest technology on listening from your computer.
Thank you for posting your concerns. I hope this helps.
Sincerely,
Cookie Marenco
From Google translator
Il semble que vous présenter une situation intéressante, si j'ai bien compris la traduction correcte. Si vous avez gravé un CD à partir du 96/24 téléchargements sous-échantillonnage de la conversion seront rendre le disque sonne pas aussi bon que le téléchargement de la 44.1 et la gravure des fichiers sur le disque de celles. En général, il n'est pas considéré comme une bonne idée.
Il est difficile d'expliquer, dans une traduction. Si vous écrivez directement à moi, nous examinerons votre réception et vous envoyer les échantillons à 44,1 et les envoyer sans frais.
cookie@bluecoastrecords.comSi vous êtes nouveau dans notre SACD ou non-compressé de mastering, vous constaterez que la musique semble plus «flexible» en volume que la musique compressée de plus aujourd'hui. C'est parce que nous croyons que plus de la compression détruit la gamme dynamique complète et réduit l'impact émotionnel. Sur la Côte Bleue SACD hybride Collection, nous avons choisi de comprimer légèrement la couche CD seulement pour que les gens pouvaient choisir. La stéréo SACD est la dynamique semble réaliste et plus souple que le CD. Cependant, les articles fort, ne sont plus forts et les sections mous sont plus souple sur la SACD comme elles ont été effectivement enregistrés.
Le 96/24 dossiers ont été fabriqués à partir du même maître que la couche SACD et avoir la gamme dynamique complète. Par la gravure d'un CD à partir du 96/24 fichiers, vous aurez la gamme dynamique complète (apparaissant plus douce) et vont probablement perdre haute et basse fréquence dans la conversion à 44,1.
La meilleure solution est de garder les fichiers 96/24 jusqu'au moment où vous disposez d'un DAC pour écouter à travers. Je suggère la lecture à computeraudiophile.com pour certains de très bonnes informations sur les dernières technologies sur l'écoute de votre ordinateur.
Je vous remercie pour l'affichage de vos préoccupations. I hope this helps.
Cordialement,
Cookie Marenco
