Modérateurs: Modération Forum Bla bla, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: captain, duf666, FGO, franck660, gardfield77, jeanluc79, jmiforum, martinst4, mig33, poupafaya, Scudabear, Sietch31, wopr et 130 invités
APPEL A TEST: Dézonnage Goldstar 2330P
Message » 27 Juil 2000 2:08
Salut les gars,
Je pense avoir ENFIN trouvé de quoi dézonner le Goldstar 2330P. L'ennui c'est que je n'ai pas de DVD zone 1 pour tester le truc. Si quelqu'un peut le faire, ce serait sympa de m'informer de la validité des codes. Merci d'avance.(réponses à looping1@voila.fr)
JE LIVRE LE TRUC TEL QUEL (EN ANGLAIS):
1. How to change regional code
Standby Mode(Power Off)
Input 314519 with Remote control key.
Wait 10 sec. (During that period do not touch any
key.)
LED is to be on and off. Regional Code will be
displayed on the digitron.
Unlock of region code is finished.
Input 000~005 with remote control unit.
(000:all , 001~005 : region code)
LED will be flashed with the region code number.
(In case of 000, it will flash ten times)
2. How to return regional code
Input 271828 with Remote control key.
key.)
LED will be flashed one time with longer period.
Locking of region code is finished.
Region code is to be fixed to the initial state.
EN VOICI UN AUTRE:
In Reply to: Re: LG / Goldstar DVD2330P
: I purchased the multi region player from Richer
sounds, I had trouble playing some region 1's.
They then gave me this to set the players region.
The LG DVD2330P Procedure - This procedure must
be executed within 3 seconds.
1.Turn the power on with no disc in unit.
2.Press the following buttons in order.
3.PAUSE
4.Press 3,1,4,1,5,9,1, This sets the unit to
region 1.
5.PAUSE
6.Power Off
7.Power On
8.Insert disk and enjoy.
This sequence means that the machine will now
only play region 1 discs. If you need to play
other discs you need to follow the above sequence
and replace that last 1 with a the region you
require e.g. 3,1,4,1,5,9,2, for region 2.
I have not tried this out yet, butI will be back
down to Richer Sounds, If this does not work.
Invité
Message » 02 Aoû 2000 14:04
Désolé...mais chez moi les 2 méthodes ne fonctionnent pas !!!
J'suis dégoûté !!! :-(
Au fait, n'est-il pas étrange que les codes des 2 methodes soient très légèrement différents ?
Allez bye !
Olivier
Invité
