je copie le message du forum audio car ce futur ampli numérique de chez l'arlésienne a de sacrées vertus pour en faire une centrale/scaler vidéo
deux photos
et les specs:
Supported display resolution
• Video: 480i 60Hz, 480p 60Hz, 576i 50Hz,
576p 50Hz, 720p 60Hz, 1080i 60Hz,
1080i 50Hz, 720p 50Hz
PC: 640 x 480, 60Hz, 800 x 600, 60Hz,
1024 x 768, 60Hz
Sound
• System Dolby Digital, Dolby Digital
EX, Dolby Pro Logic II,
Dolby Pro Logic IIx, DTS,
dts ES, dts Neo:6, dts 96/24
• Enhancement Treble & Bass control,
night mode, loudness (là au moins on ne s'embarrasse pas de dsp surperflus)
• D/A converter24 bit, 192 kH
• 6 x 100 watts RMS
Connectivity
• Front/side Audio left/right in,
CVBS in, S-video in
• Headphone 3.5 mm
HDMI in 2x, HDMI out,
Speakerterminal Surr.
Left, Speakerterminal
Surr. Right, Speakerterminal
Centre,
Surr. Rear,
subwoofer out,
8-channel multichannel
in, Component Video
Input 2x, Component
Video out Progressive,
S-Video/CVBS video
output, Composite
video (CVBS) out,
SCART control via
2.5mm jack, S-Video/
CVBS video input 3x,
Analog audio left/right
in 3x, digital coaxial in
3x, digital optical in,
analog audio left/right
out 2x, digital audio
coaxial out, DAB
antenna, FM antenna
HDMI Digital AV connection
HDMI stands for High Definition Multimedia Interface. It is
a direct connection that can carry digital HD video as well as
digital multi-channel audio. By eliminating the conversion to
analog signals it delivers perfect picture and sound quality.
NSV™ Precision Video
NSV™ Precision Video is an embedded noise reduction
technology that eliminates existing noise inherent in video
signals, thereby providing a more refined picture viewing
experience.
Digital Crystal Clear DCDi™ by Faroudja
Digital Crystal Clear is a package of picture innovations that
digitally adjusts and optimizes picture quality to optimal
contrast, color and sharpness levels.
Video Upscaling
With Video Upscaling you can increase the resolution of SD
(Standard Definition) video signals that DVD uses to HD
(High Definition) so you'll be able to see more details thanks
to a sharper, more true-to-life picture.
UCD Digital Amplifier
The UCD Audiphile Digital Amplifier is a full digital Class D
amplifier designed to give the lowest output impedence and
the best audio measurements.
CD Upsampling
CD Upsampling is an advanced sound processing technology
that intelligently upgrades the audio of standard CDs by
increasing time resolution and sampling rate for an improved
audio experience.[/b]
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 16 invités
philips dfr 9000 (ampli num,hdmi,dcdi & scaler)
- michaelM86
- Inscription Forum: 05 Aoû 2000 2:00
Très très intéressant.
As-t-on seulement une idée du prix de cette merveille ???
Vincent
Vincent
- Dirty Vincent
- Inscription Forum: 24 Juil 2000 2:00
Tiens, la face avant me rappelle quelque-chose .... l'avant d'un train ?
- ptiJean
- Inscription Forum: 13 Juin 2003 10:46
Dirty Vincent a écrit:Salut,
Vincent
dans Lal d'octobre il était question de 700€ et d'une dispo en janvier.
j'espère seulement que les annonces de prix des produits philips sont plus fiables que celles concernant la date de mise sur le marché.
- michaelM86
Ha ouiiiiiiiiiiii pti jean !!!
j'me rapelle aussi du train...
qui n'est toujours pas arrivé en gare d'ailleurs !!!
- TONITO
- Inscription Forum: 20 Sep 2004 15:08
S'il est vraiment performant en vidéo, certains pourront l'utiliser juste en tant que scaler vidéo parce que vu le prix avec DCDI, c'est relativement moins cher par rapport a ce qu'on peut trouver comme doubleur de lignes proprement dit!!
- Mickael12
- Professionnel
- Inscription Forum: 17 Déc 2004 21:20
Salut, moi j'ai lu qu'il serait dispo à 599 euros, j'ai hate qu'il sorte, de meme que le DVP900, le lecteur dvd de philips de la meme gamme...Ca ne fait pas cher l'ensemble vu les capacités !
j'ai lu ici que quelqu'un avait commandé ce lecteur DVD au luxembourg ? Avez vous des infos de disponibilité dans ce pays ? SI c'est le cas, peut etre l'ampli y est aussi dispo
- swingtrader
- Inscription Forum: 24 Déc 2004 11:04
non malheureusement ...
au Luxembourg juste quelque pièces de stock
et aussi ici...
Mais faut se dépécher parce que les stocks sont
presque vides....
ok ok... je suis parti...
et aussi ici...
presque vides....
- TONITO
Le vendera-t-on en pack avec le 900SA?
Arrivée prévue de mon chèque le 30 fevrier
- Grubert
- Inscription Forum: 09 Avr 2002 2:00
en tout cas le dvp900 est référencé à la fnac des ternes, mais pas encore en stock. D'apres le vendeur, ca ne vas pas tarder puisqu'ils l'ont en référence dans leur systeme...
marre d'attendre!
marre d'attendre!
- swingtrader
Ouais, peut d'intérêt d'avoir un amplis qui fait de l'upscaling derrière un lecteur dvd qui en fait déjà.
A moins que ça ne marche aussi sur les entrées composantes (et est-ce qu'il est capable de ressortir en HDMI un signal entré en analogique après upscale ?)
Autre chose qui m'interpelle :
"DAB antenna"
Ca sort enfin ce truc
Je croyais que le DAB était mort depuis longtemps ...
"DAB antenna"
- Ki
- Inscription Forum: 12 Jan 2003 14:55
Mauvais nouvelle
Apparement, infos du commercial philips, il est retarder en France jusqu'en avril
On est plus a deux mois près
- Mickael12
- Professionnel
PS: il sortira avec le DVP900SA et le commercial philips m'a laisser entendre qu'il serait peut etre proposé en pack ampli+dvd?
- Mickael12
- Professionnel
Ki a écrit:Ouais, peut d'intérêt d'avoir un amplis qui fait de l'upscaling derrière un lecteur dvd qui en fait déjà.
La possibilité d'upscale supplémentaire me paraît très intéressante si tu peux connecter d'autres sources que le DVD (DivX Box, console, scope ?, ...).
Par contre j'émet des doutes sur la qualité du résultat parce que le scaler "abordable et efficace" du marché est à 1500€ ! (Cinemateq PO+)
- KlocheTTe
- Inscription Forum: 15 Jan 2005 2:24
KlocheTTe a écrit:Par contre j'émet des doutes sur la qualité du résultat parce que le scaler "abordable et efficace" du marché est à 1500€ ! (Cinemateq PO+)
wait and see
en attendant un lien vers le pdf de la bête
http://www.avsforum.com/avs-vb/attachment.php?s=&postid=4314506
- michaelM86
Retourner vers Lecteurs DVD / HD-DVD / Laser Disque
