Merci beaucoup, je t'envoie un MP.
Alexandre
40 messages • Accèder à une page • 1, 2, 3
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: djcharlou, lolo05 et 50 invités
Vds Pathos Classic One MKII
- alexandret
- Inscription Forum: 27 Aoû 2001 2:00
alexandre t a écrit:Merci beaucoup, je t'envoie un MP.
Alexandre
Je l'attends toujours
Eric
- Le Blaireau
- Inscription Forum: 21 Juin 2003 7:21
J'ai eu la confirmation de Pathos, c'est bien un MKII. Voici la liste des modifs entre le MKII et le MKII
Du coup, pour me faire pardonner, je baisse le prix à 1000 €.
Eric
We apologize for the delay in replying to your request as our company was closed for inventory.
Classic One S/N 240754 is MKII version. Here below please find innovations of MKIII version:
1-we use an high quality op-amp to drive the MosFet power amplifier.?It is an ultra low noise, high linearity and very low distorsion op-amp.?
More definition on the sound.?
2-we use a new volume control with Burr-Brown?ic which is more linear and it can accept up to +/-12V audio signal.?
In this way we avoid the input saturation when the cd player has high voltage output (5V). There is also a new?power supply.
3-we added a particular electronic stage to protect the power amplifiers against short-circuit on the speaker connectors.?
This particular network is an high impedence stage that feels the current and save the output stage when a short circuit happens.
4-we use a new high quality speaker connectors that are completely protected with a transparent plastic, in order to avoid short circuit.
5-use a new stainless steel cover for the power transformer.
6-new power transformer which can work up to 130Vac, so it is less sensitive to the different voltages in the US territory.
7-we use chromium plated knobs and wood of front panel is paduk (red).
We hope we have cleared your question: should you need further information do not hesitate to contact us.
Eric
- Le Blaireau
Personne pour cet ampli encensé par la presse et de nombreux forumers
Eric
Eric
- Le Blaireau
C'est à croire que plus rien ne se vend!
A ce prix là c'est l'ampli idéal pour se monter un petit système de qualité d'autant plus qu'il est dans un état irréprochable.
- poverliner
- Inscription Forum: 21 Sep 2003 21:48
poverliner a écrit:C'est à croire que plus rien ne se vend!
C'est vrai que l'occase en ce moment, c'est complètement mort.....
Eric
- Le Blaireau
Bonjour Eric,
Désolé de cette absence de réponse, mais je ne veux ni t'embêter,ni faire voyager l'ampli pour rien. Entre temps, j'ai pu écouter un Lavardin IS référence à la maison qui m'a beaucoup plus (même si plus de puissance ferait du bien à mes enceintes).
Je privilégie donc l'expressivité et l'équilibre tonal sur la dynamique brute, de toute façon incompatible avec une vie familiale en appartement...Et beaucoup de douceur et de filé en haut.
Si le pathos va dans ce sens, il peut effectivement m'intéresser (je lorgne également vers des Euphya 270, voire 320). Mais je t'avoue qu'auregard de la clarté (sonore...) de ma pièce et le mariage pointu qu'exige mes enceintes, une écoute préalable me parâit indispensable...A voir donc si cela est faisable facilement, sans faire transiter l'ampli par un transporteur ou la poste.
Cordialement,
Alexandre
Cordialement,
Alexandre
- alexandret
Ben je comprends toujours pas pourquoi il n'intéresse personne cet ampli.
Il est super bien coté, très joli et pas trop cher (du moins il me semble)
Eric
Eric
- Le Blaireau
pourtant, à ce prix là, c'est cadeau
- julien max jacquemin
- Inscription Forum: 29 Oct 2002 14:03
Pense mettre à jour ton prix de vente en tete de topic
- bible100
- Inscription Forum: 24 Fév 2003 14:27
J'en profite pour poser une question de débutant en ampli tube :
Est ce qu'un ampli hybride comme celui-ci accepte facilement des ON-OFF sur des utilisations de 20-30 min ? De meme trouve ton une entrée sur laquelle arrive la sorte preout du HC ?
Pourquoi ma question ?
Je dois revoir ma config hi-fi dans les mois à venir tout en gardant la compatiblité avec l'ampli HC. Et j'ai depuis que j'ai écouté un certain ampli ARC VSi55 de chez Audio Research, je suis assez sous le charme Dois je me "résigner" à un ampli hifi à transistors pour une question de facilité de gestion et d'interfacage.... ?
bon je déplace pour post dans un nouveau topic....
- bible100
-Est-ce qu'on peut écouter n'importe quel type de musique avec cet ampli (classique, rock, jazz...) ?
-Est-il assez puissant pour une grande pièce de plus de 50m2 ?
-Les basses sont elles "péchues" et a-t-on un son bien détaillé et percutant même à faible volume ?
-Et mes Cabasses Sampan 305 sont elle adéquates pour une association ?
Supervisé…
- opbilbo
opbilbo a écrit:-Est-ce qu'on peut écouter n'importe quel type de musique avec cet ampli (classique, rock, jazz...) ?
Oui sans hésiter
Je pense sauf si tu veux faire discothèque
Heu.....je dirai oui
is p-Et mes Cabasses Sampan 305 sont elle adéquates pour une association ?
Je ne sais pas, je ne connaas ces enceintes
- Le Blaireau
Merci, pour tes réponses.
Je prospecte toujours par rapport à mes Cabasses et c'est pas facile pour se décider.
Supervisé…
- opbilbo
Toujours personne ?
Eric
Eric
- Le Blaireau
40 messages
• Page 2 sur 3 • 1, 2, 3
