Type : enceintes de monitoring
Marque : tannoy
Modèle : sytem 1000
Prix de vente : 800 euros 750euros 700 euros 650 euros
Département où la marchandise est visible : 63 (pres de clermont ferrant)
Montant des frais d'expédition :a determiner
État de la marchandise : tres bon
Première main : Non, seconde
Prix neuf : entre 2000 et 2500 euros environ
Facture disponible : Non
Date et lieu d'achat : achetè a un particulier en 2007
Numéro de série : Sur demande
une enceinte de monitoring a la forme inhabituelle mais tres performante ,bien equilibrée sa force est une image tres precise grace au tweeter coaxial .
de plus son rendement est assez elevé donc utilisable avec a peu pres tout .
Frequency response (1) 45Hz–20kHz
Recommended amplifier power 60 to 200 watt rms into 8 ohm
Power handling Average: (2) 100 watt Programme: 200 watt
Nominal impedance 8 ohm
Sensitivity (3) 94dB/1w@1m
Distortion <0.4% 45Hz–25kHz
Dispersion 90 degrees conical
Crossover frequency 1.5kHz
CABINET
Drive unit 250mm (10") Tannoy Dual Concentric™
Low frequency design Optimised bass-reflex loaded
Volume 32 litres
Cabinet construction MDF 36mm (1.4") front panel,
19mm (0.75") high density particle board
Cabinet finish Spray 'F' Vinyl
Cabinet dimensions (HxWxD) 330.5mm (13") x 540.0mm (21.25") x 298.0mm (11.75")
Cabinet weight 16.5 kgs (36.4lbs)
Shipping dimensions 660.0mm (26") x 415mm (16.3") x 370mm (14.56")
Shipping weight 19kgs (41.9lbs)
SYSTEM 1000
The System 1000 nearfield monitor is part of the latest range of
studio loudspeakers from Tannoy, a company with an outstanding
reputation in the professional audio world.
The Dual Concentric™ driver might look like a conventional bass
unit, but the system incorporates a high performance tweeter
positioned immediately behind the centre of the bass cone.
This design produces all the frequencies from a single point,
mirroring the way sound is produced in real life. The accurate phase
response achieved delivers a realistic soundstage, along with a smooth
and natural sound which is unfatiguing over long listening periods.
The speaker is capable of high volume levels without compression
and delivers excellent transient response. The System 1000 is capable
of producing accurate, high quality sound for a wide range of
applications. The use of the latest materials and manufacturing
techniques gives the System 1000 the ability to exploit the full
performance of today’s analogue and digital recording equipment.
SYSTEM 1000
APPLICATIONS
Nearfield reference
monitoring in professional and
semi-professional facilities,
including:
z Music studios
z Mobile recording
z Broadcast
z Post-Production
z Audio Visual
z Quality control
NOTES: (1) ±3dB, measured at 1m in anechoic
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: jc51 et 109 invités
up de fin d'année
- deparis
- Inscription Forum: 29 Avr 2005 11:11
up pour ces excellentes enceintes
- deparis
up pour du très bon en enceintes
- deparis
baisse a 700 euros
- deparis
up et baisse a 650 euros
- deparis
elles peuvent fonctionner verticales ?
- fr
- Inscription Forum: 29 Juin 2007 17:54
fr a écrit:elles peuvent fonctionner verticales ?
oui , bien sur , elles sont faites pour les deux sens ,(l'avantage du tweeter coaxial ), on peut faire pivoter le logo tannoy aussi d'ailleurs ,ç'est prevu pour .
didier
- deparis
up pour mes belles enceintes ...
- deparis
22 messages
