Type : amplificateur intégré ou de puissance
Marque : Classic
Modèle et options : No.6.6
Prix de vente : VENDU
[b]Département où la marchandise est visible : Belgique
État de la marchandise : parfait état
Première main : OUI
Prix neuf : >=900euros
Facture disponible : OUI (je crois)
Date et lieu d'achat : (à vérifier) 2004 chez Coemaudio
Numéro de série :
Documentations conservées :
No.6.6 is a top-grade integrated transistor amplifier that was launched by Beijing Yushang Electronic Audio Co., Ltd in 2001. Its build features nobleness and elegance. With excellent technology, it is the third generation of product derived from Yushang’s patent circuit. After years improvement No.6.6 has gradually attained perfection.
Features of No.6.6:
1. Pre-amplifier sector:
Regulated power supply uses special SEPP circuit, which can keep an ultra-low noise and ultra-low internal impedance. The open-loop frequency response at pre-amplification attains a wide of 330KHz(2V-3db) and wide of 620KHz(2V-3db) at closed loop. Having no lag compensating capacitor and with less harmonic distortion, its acoustics upgrade to higher level.
2. Power amplifier sector:
The problem of bad common-mode rejection ratio caused by single-end voltage amplification being considered, a dedicated electricity circuit is added to resolve the problem. Penultimate stage driving adopts common-source and common-base circuit configuration, which has the best linearity and also has important action to reduce the distortion-growing problem etc, due to pairs of high power transistors in parallel. Each sound channel has three-group power supply separately feeding to final stage, penultimate stage and voltage amplification stage.
3. Power supply sector:
No.6.6 uses two 450W ring transformers (supply separately to left and right channels) that have, nowadays, the best quality in China. Pre-amp and remote control use a R-shaped transformer. No.6.6 has around 100000μ electrolytic capacitor for filtering,four groups of electronic filters and two groups of regulated power supply.
4. Full-functioned remote control includes ON/OFF, mute, volume and input selection, etc. Exquisite and exalted remote controller is made of costly aluminum alloy and the design of its buttons especially conforms to the principle of ergonomics.
5. Perfect workmanship and construction:No.6.6 has shortcut and rationalized internal connection, and good electromagnetic compatibility. Its potentiometer is pull-rod mode. Thick copper columns are used to connect part of its circuit boards.
Av interfaces are dedicated 3+2 mode both for AV and Hi-Fi and adopt special earth wires switchover selection switch to ensure using Hi-Fi system against interference from AV system. No.6.6 has better adaptability to different kind of loudspeakers and more comprehensive performance. Its sound representation: full and munificent, clear and elegant, great spatial sensation and accurate acoustic image localization and much better compatibility with every kind of musical and audio form and style.
Top-grade integrated transistor amplifier by Classic.
Specification
Output Power: 160W(8ohmRMS) 160W(8ohmRMS)
Total Harmonic Distortion(THD+N): 0.066%(1KHz 150W 8ohm) 0.066%(10KHz 150W 8ohm)
Frequency Response: 5Hz-150KHz(-3dB 150W)
S/N: =91dB(without weight)
Gain: 48.5dB
Input Sensitivity: 0.13V
Load Impedance: 4ohm-16ohm
Damping Factor: >380
Fuse: 4A×2 0.2A×1
Static Power Consumption: 180W
Power Voltage: Customized according to different mains voltage in different countries and regions
Net Weight: 20Kg
Site web du constructeur : http://www.yushang-audio.com/english/product/yushang-p66.htm
Amplificateur 2 x 150W (sous 8Ohm), version Européenne 220V.
A la particularité de pouvoir soit être utilisé comme amplificateur intégré ou comme amplificateur de puissance grâce à un switch situé à l'arrière de l'appareil (cf. photos).
Configuration double mono, composants de haute qualité, construit comme un tank
En parfait état de fonctionnement et d'esthétique, complet avec boite d'origine et télécommande.
Excellent ampli, doux (un peu dans le style tubes mais avec les avantages du transistor), neutre, dynamique, doté d'un excellent rendu des basses, profondes, tendues et articulées, et doté de suffisamment de puissance pour driver les enceintes les plus difficiles (2 x 450W transformateurs totoidaux, 80000µf).
Liens divers : http://www.sixmoons.com/audioreviews/yushang/classic.html
11 messages • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: hob, Talon Karrde et 34 invités
UP et promo de Pâques : baisse de prix à 550€
ne trainez pas pour cet excellent ampli très bien construit (regardez l'avant dernière photo!), à ce prix impossible de trouver mieux
- guilders0
- Broker
- Inscription Forum: 14 Aoû 2008 11:03
-UP- pour cet excellent ampli, tant en intégré qu'en ampli de puissance.
et à ce prix, franchement . . .
- guilders0
- Broker
Super jolie.....
- provideo10
- Inscription Forum: 09 Nov 2009 17:17
-UP- pour cet ampli sans concurrence dans cette gamme de prix.
- guilders0
- Broker
-UP-, dois-je redire que cet ampli est sans concurrence ?
- guilders0
- Broker
réservé, en attente du paiement
- guilders0
- Broker
VENDU, on peut fermer, merci.
- guilders0
- Broker
Et voilà, une nouvelle fois, on supprime le prix de vente...
J'vois toujours pas l'intérêt de faire cela, à part supprimer des informations utiles pour les autres vendeurs...
Bref...
Bref...
- Rootrulez
- Inscription Forum: 12 Jan 2008 23:00
Sorry, je veux bien le remettre, ça me gêne pas, j'avais constaté cela sur beaucoup de ventes et j'en avais déduit que c'était la pratique.
Vendu à 580€ fdpi.
Vendu à 580€ fdpi.
- guilders0
- Broker
Rootrulez a écrit:Et voilà, une nouvelle fois, on supprime le prix de vente...
Bref...
je suis du même avis , je verrouille
Patrice
DIFFUSEUR LG 77G3 / LG 65C9 SOURCE PANASONIC DP-UB 9000 / ZIDOO Z 1000 PRO et Z9X / APPLE TV 4K AMPLI SMYTH REALISER A16 TELECOMMANDE IPAD AIR VIBREUR EARTHQUAKE Q10B CASQUE DENON AH - D 9200 / FOSTEX TH 610 / SONY MDR 700 ECLAIRAGE PHILIPS HUE
- patriceonkyo
- Inscription Forum: 17 Nov 2005 13:26
11 messages
