Bon voilà mes recherche grace à nos amis de AVSFORUM
"8280-5 Firmware Update for Denon 3910 - with warning.
Fix is described as "When the DVD player is connected with the A/V amplifier
for HDMI Ver.1.3 with the HDMI connection, the "Dolby Digital" and "dts"
signals can not be output from the HDMI of DVD player."
See "http://firmware.denon-online.eu/" (Denon European Update and Support site).
Click OK, Next.
Select DVD-3910, Silver, 0000000001 as serial number, Click Send Data.
Warning re the 5 displayed file links:-
File link "GEN8280-5_918D_3rd_DVD3910.zip (1.10 MB)" is ok for file "D31ZSAVD.CFW".
File link "Ver8280-1_715D_DVD3910.zip (1.10 MB)" is WRONG as it should be for file "SUP3910.rom".
File link "ER1028_20041028.zip (400.38 KB)" is ok for file "d391il.rom" although the file date/time is nothing like the zip file name.
I used file 1 from above, with files 2 and 3 from the 8280-1 release and it installed ok per prior entries in this thread. I then used the region free hack from remote per prior entries in this thread. It returned Region_A3.
Turned Multi_Region handset hack off (just repeated standard process) to Region 3. Then verified firmware as:-
ESS 8280-5
MAKE DAY 918D
DRV 060825
SYSTEM 6767-5
DSP 6770
C 20041028
Re-applied Multi_Region handset hack.
All seems ok when the player is used. "
Donc voilà peut être la source de ton probléme , j'ai tous les fichiers , il ne reste plus qu'à faire la MAJ , pour le premier fichier tu le récuperes sur le site DENON , mais si tu veux je l'ai
Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 24 invités
merci je vais tenter le coup (le mien est un 2910 )
je charge
a++
jp
je charge
a++
jp
- jipegonzo
- Inscription Forum: 22 Oct 2004 16:03
Attention c'est pour du 3910 !!!!!!!!!!!!!!!!
- PATOCHELILLE
- Inscription Forum: 06 Mai 2004 14:41
ça marchera pas pour le 2910
bon tant pis, je laisse tomber
jp
jp
- jipegonzo
I am happy tout est OK mon lecteur est bien raccordé par LA HDMI et MZ
ne desespere pas tu parcours AVFORUM et tu trouveras ton bonheur surtout lit bien toutes les pages de ce tread il donne la majorité dees réponses à tes problémes et les fichiers utilise ceux de DENON et AVSFORUM il y a aussi un autre site qui traite que du 2910 dont l' URL est donné dans ce tread
bon courage
bon courage
- PATOCHELILLE
Hello,
c'est quoi la dernière version du firmware du denon 2910 ?
ma platine est à la version ESS 6720-d
Peut-on lire enfin les SACD via la HDMI ?
bye
bye
- Hervet
- Inscription Forum: 13 Mar 2010 20:16
salut à tous
halleluia, au bout de 2 ans j'ai pu voir ma version de firmware.En relisant les pages précédentes, j'ai repris le dézonnage par la télécommande et la miracle je vois enfin ma version:
ESS 6609-B
SYST 6767-5
DSP 6770
MAKE DAY 413D
DRV 030825
C20041028
Durant cette période,j'ai eu quelques soucis de lecture des SACD et certain DVD ( saut, blocages etc .. peu etre du au dézonnage ?) Je reteste ma platine depuis et pour le moment tout va bien.
Je pense faire une mise à jour d'ici peu mais malheureusement je ne pourrais pas la faire sur le site de DENON car ma platine vient du LUX. ( si quelqu'un peu m'aider )
ESS 6609-B
SYST 6767-5
DSP 6770
MAKE DAY 413D
DRV 030825
C20041028
- m.hadam
- Inscription Forum: 29 Jan 2006 15:56
Voilà j'ai acheté mon lecteur DVD Denon 3910 sur internet il y a quelques jours,
je l'ai recu et en suis content, seulement il fonctionne pas vraiment très bien. En effet, deux symptomes se posent : le premier, il saccade sur certains DVD, c'est à dire que l'image se bloque, il faut attendre parfois une ou deux minute (machine toujours en mode lecture) pour que le DVD suive son cours. Et attention je souligne que tous mes DVD sont neufs, je n'achete aucun DVD d'occasion donc ils sont nickel cela ne vient pas de mes disques. Deuxieme chose, sur certains DVD encore, le Denon charge son disque, le moteur tourne, puis affiche 00:00:00, puis plus rien impossible de charger le DVD.
J'ai amené la machine à un spécialiste qui a tout nettoyé, rien n'y fait, il m'a dit que peut etre cela viendrait des mises à jour Denon. D'ou mon message ici sur ce forum.
J'ai bien lu la procédure de MAJ que j'ai trouvé sur ce post, voici ce que la machine affiche :
ESS 6609-5
MAKE DAY 831
DRV 030825
SYSTEM 6767-2
DSP 6770
CNE 20040609
Je ne cherche pas à dézonner ma machine, c'est juste pour qu'il n'y ai plus de probleme sur mes DVD.
Es-ce que quelqu'un peut me dire ce que je dois faire ?
ESS 6609-5
MAKE DAY 831
DRV 030825
SYSTEM 6767-2
DSP 6770
CNE 20040609
- jean-pascal demin
- Inscription Forum: 22 Mai 2010 4:46
elle est branché en hdmi sur un ampli
- oolivier
- Inscription Forum: 18 Fév 2006 17:43
oolivier a écrit:elle est branché en hdmi sur un ampli
Que voulez-vous dire?
- ubuntu
- Inscription Forum: 24 Juin 2007 10:00
la machine est branchée par les cables composantes sur un ampli Denon AVR3806. Le 3806 amplifie la video du DVD vers un plasma Panasonic en cable HDMI.
- jean-pascal demin
m.hadam a écrit:salut à tous
ESS 6609-B
SYST 6767-5
DSP 6770
MAKE DAY 413D
DRV 030825
C20041028
Hello,
ci-joint le lien vers le fichier de la derniere mise a jour disponible pour le 2910 que j'ai téléchargée sur le site de Denon le 10 mai 2010. Ce n'est pas une nouvelle mise à jour, le fichier date de 2006.... (hébergement valable 1 mois)
http://www.cijoint.fr/cjlink.php?file=c ... RSYZlE.zip
A ++
- aaaaargh!
- Inscription Forum: 16 Nov 2003 21:23
ubuntu a écrit:oolivier a écrit:elle est branché en hdmi sur un ampli
je te demandais ça parceque le mien (de 3910) ne fonctionne pas en hdmi relié sur mon onkyo 905 il se plante au démarrage,je l ai donc relié en svhs et c est la puce du 905 qui fait le boulot, de toute façon cette platine est complètement largué au niveau image sur les nouvelles géné d écran,je la garde juste maintenant pour les dvdaudio et sacd,il parait qu il faut mettre le dernier firmware pour que la hdmi fonctionne sur les amplis de derniere géné, a savoir quand meme que relié en direct sur mon plasma en hdmi cela fonctionne mais elle devient un peu capricieuse.
- oolivier
De mon coté j'avais mis la dernière mise à jour sur le 3910, et depuis tout est resté comme ça, et ça fonctionne très bien.
La sortie HDMI du 3910 est connectée sur l'entrée HDMI de l'ampli DENON 4306, et la sortie du 4306 est aussi connectée en HDMI sur le TV 132 cm (qui est d'ailleurs un full HD car je reçois ici la TNT HD et il y aussi un lecteur BD).
L'image rendue des DVD est excellente, rien à reprocher! (si le DVD est bien codé évidemment!!)
- ubuntu
jpu017 a écrit:ubuntu a écrit:Selon mes dernières lectures, le flux DSD ne passe pas par le "D link3", mais seulement les signaux décodés............à vérifier tout de même, mais comment?
Il semblerait en effet que celà ne soit pas autorisé, et qu'aucun ampli actuel ne possède cette possibilité de décodage......
Possible... Il y a en effet un truc, qui date du légendaire lecteur DVD Pio 747A (le premier "universel"... Souvenirs...), qui consiste à reconvertir subrepticement le DSD en PCM, à 88 ou 176khz selon les cas.
Les constructeurs sont en général assez discrets sur ces pratiques.
Ce qui est à peu près sûr, c'est que Denon (et d'autres) ont recours à ce truc dès lors que tu veux appliquer à tes flux les différentes corrections que tu as paramètrées sur ton ampli AV (automatiquement ou pas).
La question est donc, finalement, de savoir ce qu'ils font en mode "direct" (ou "pure direct", ou "direct par tunnel quantique", etc...).
Dans ton cas, il se pourrait en effet que le D-Link ne serve qu'à porter des flux PCM. Mais comme tu dis, c'est à vérifier.
A noter : Nad se vante hautement de gérer les deux types de flux et de conversion sur son lecteur T585.
Salut a tous,
Je reviens sur le sujet des flux DSD via D-Link.
J’ai acheté la semaine dernière un lecteur 3910 d’occasion pour le connecter sur mon 4306.
La connexion se fait par la D-Link avec un câble réseau Cath. 7 et HDMI sur le Plasma en direct
J’ai mis à jour le lecteur en : ESS 8280-5 MAKE DAY 918D DRV 060825 SYSTEM 6767-5 DSP 6770 C 20041028
L’ampli est lui aussi dans le denier Firmware 6.0.0.4.
Pour réussir a connaître le signal (afficher sur le menu de l’ampli par la touche OSD en monitor out) de la télécommande, avec cette touche il est possible de voir le type de signal traiter dans l’ampli.
---------------------ROM EQ-------SIGNAL----------FS-------
SACD MODE CD------MANUEL-------PCM--------------44,1 KHZ
SACD STEREO-------MANUEL-------DSD-PCM---------2\0\0
SACD STEREO------OFF----------- DSD--------------2\0\0 (Sans transformation en PCM)
SACD MULTI--------MANUEL--------DSD-PCM--------3\2\1
SACD MULTI--------OFF------------DSD –PCM-------3\2\1
Donc, j’arrive à récupérer le signal DSD sans transformation en PCM avec ROM EQ sur off, DIRECT ou PURE DIRECT, input mode sur AUTO, et le 3910 en SACD stéréo. L’ensemble fonctionne parfaitement.
Je n’arrive pas à récupérer le signal « FULL » DSD en multi, si quelqu’un à une info.
- LOGO
- Inscription Forum: 10 Mar 2008 11:39
Retourner vers Lecteurs DVD / HD-DVD / Laser Disque
