Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: AudioPhilo Dodo, Baboulinet, baloo46, carlot, cholley, domin, DSAGNES, ericb56, jean GROS, JO95, jybliste, PAT 94, Recital-Audio, rolex, tovarich007, vindermere, ZEPHYR92 et 421 invités
Les "pétoires" de l'extrême Ep II
D'une mocheté immonde
- khaos974
- Inscription Forum: 20 Mar 2006 20:46
Look "steampunk"... C'est super tendance chez les geeks quarantenaires
http://fr.wikipedia.org/wiki/Steampunk
- saveriancouty
- Inscription Forum: 18 Sep 2005 22:05
Après le steampunk, le Bauhaus revival avec les FÖRSTER AUDIOTECHNIK FA5.3
* Capacitors: mica, SUPREME-CAP, KP, MKP
* Coils: CFC copper foil coils, air-core coils
* Resistors: No resistors with ferromagnetic properties in the signal path
* Equipped with FA coupling and decoupling system as standard (invisible under the housing)
* Total decoupling of all chassis and contacts from the housing
* Double wall construction filled with silica sand
* Impedance linearity
* Mundorf binding post, solid material copper
* Special internal wiring made by FÖRSTER AUDIOTECHNIK with separate signal shielding - ideal further development of FA33
* Piano lacquer
* Dimensions of housing in mm: 1247 x 335 x 586 (H x W x D)
* Height incl. coupling and decoupling measures in mm: 1268
* Mass (Pair): 250 kg
* Piano lacquer
roland_de_lassus - Modérateur Haute-Fidélité
oyo a écrit:Ils sont petits les HP...
17 cm de diamètre
FA5.3 - The design
Air Motion Transformer
The tweeter which functions according to the principle of the air motion transformer constitutes the heart of this loudspeaker.
Bass/midrange speaker
Two 17 cm bass/midrange speakers are symmetrically and time-coherently connected to this tweeter. Especially due to their highly stable ceramics membrane these chassis are characterized by extremely low distortion values and an especially good decay in their transitional area.
Ventilated housing
The bass/midrange speakers operate in a highly precisely aligned ventilated housing. This results in an in-depth and very precise bass reproduction up to 35 Hz (-3dB).
Design
The design of our loudspeaker FA5.3 is protected by the EU design patent No. 001941766-0001.
sur la tour blanche
le tweeter c'est effectivement un air motion transformer mais c'est un mundorf, j'en suis absolument sur
et les deux 17cm certainement des accuton avec leur membrane céramique
le prix doit être trop chère sa j'en suis pratiquement sur aussi, rien que déja les accuton, ou même si c'est des genre de copie sa ne doit pas être donné
et puis le machin mundorf trop chère à mon gout
le dernier macin avec le pv1 géant,
c'est horrible confier le médium aigu à des panneau électrostaique, c'est selon moi une idée quelle est mauvaise, pas de dynamique, pas d'attaque, très définie certainement mais mou, et cerise sur le gateau, ce genre de chose à tendance à agrandir les objet sonore, la chanteuse ont parfois des bouche si grande, qu'on pourrai y insérer, le caisson sur la photo
non mais sans rire, je pense que les panneau électrostatique on vécu, n'en déplaise à martin logan
- dominax
- Inscription Forum: 09 Mai 2010 16:50
Dsw, un ptit commentaire?
- STRA
Mahler a écrit:
P*tain Malher,
J'avais dis pas de photos persos !!!
David
P.S. : ENORME...
- DaveStarWalker
- Inscription Forum: 25 Aoû 2006 11:08
Plus lourd... (250 Kgs l'enceinte).
Les nouvelles Tidal AGORIA
Specifications:
· Floorstanding reference loudspeaker
· 1 x 30 mm (1.2”) pure diamond tweeter, decoupled metal alloy housing
· 2 x 173 mm (7”) mm BCC (Black Coated Ceramic) midrange woofer, hand polished aluminum clamp ring with curve shape to reflexions from the diaphragm protection grill
· 2 x 280 mm sandwich-compound woofer
· 3 x 280 mm sub-bass radiator, removable massive aluminum clamp system, adjustable with several different weights
· TIRALIT ™ multi chamber cabinet
· Active/passive bass driver CIC-configuration
· multi adjustment Varioterminal: tweeter curve, deep bass, upper bass, bass level
· TIDAL Unopulse crossover
· Optional: SE-version with all pure silver PIO Cast parts
· Optional: TIDAL LPX active crossover (or with LPX-Module in our reference power amplifier TIDAL Impulse
· Hand polished black piano lacquer
· Optional: hand polished noble veneers under transparent piano lacquer
· Isolator system out of massive aluminum triggers and stainless steel isolation platforms
· incl. ATA-Flightcases
· Dimensions: 31cm (W) x 60 cm (D) x 169 cm (H)
· Impedance: 4 ohm
· Weight: 205 kg (450 lbs.) each, shipment pair 470 Kg (1.030 lbs.)
Prix estimé: au-delà de 50.000 € la paire..
Avec plein de vrais morceaux de haut-parleurs dedans...
Specifications:
· Impedance: 4 ohm
Marque autrichienne : Trenner & Friedl
Modèle Duke
Prix: 130.000 € la paire
Mais avec un vrai cristal Swarowski comme diffuseur
Source : Cinenow
Modèle Duke
Source : Cinenow
n'importe quoi
n'importe quoi
- MickeyCam
Déjà posté
David
David
- DaveStarWalker
