Modérateur: Staff Juridique • Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 5 invités
[VENDU] NAD 3240PE
Message » 15 Mai 2015 19:39
Type : Ampli HIFI
Marque : NAD
Modèle et options : 3240PE
Prix de vente : 100
Département où la marchandise est visible : 91
Montant des frais d'expédition : A définir
État de la marchandise : Bon état
Première main : NON
Facture disponible : NON
PRE-AMP SECTION
Phono input
Input impedance (R and C) 47kohm / 100pF
Input sensitivity, (1kHz, ref. rated power) 3.2mV
Signal/Noise ratio (A-weighted with cartridge connected) 76dB ref. 5mV
THD (20Hz - 20kHz) <0.04%
RIAA response accuracy (20Hz - 20kHz) ±0.5dB
Line level inputs
Input impedance (R and C) 15kohm / 100pF
Input sensitivity (ref. rated power) 160mV
Maximum input signal >10V
Signal/Noise ratio (A-weighted ref 1W) 88dB
Frequency response (20Hz - 20kHz) ±0.5dB
Infrasonic filter -3db at 15Hz, 24dB/octave
THD 0.01%
Line level outputs
Output impedance Pre-amp 600ohm
Tape Source Z + 1kohm
Phones 220ohm
Maximum output level 12V
Tape 8V
Phones >10V into 600ohm
>500mV into 8ohm
Tone controls
Treble ±7dB at 10kHz
Bass ±10dB at 50Hz
Bass EQ +3dB at 70Hz
+6dB at 40Hz
POWER AMP SECTION
Continuous output power into 8ohm * 40W (16dBW)
Rated distortion (THD 20Hz - 20kHz) 0.03%
Clipping power (maximum continuous power per channel) 50W
IHF Dynamic headroom at 8ohm +6dB
IHF dynamic power (maximum short term power per channel)
8ohm 160W (22dBW)
4ohm 200W (23dBW)
2ohm 250W (24dBW)
Damping factor (ref. 8ohm, 50Hz) >50
Input impedance 22kohm / 880pF
Input sensitivity (for rated power into 8ohm) 1V
Frequency response 6Hz - 50kHz +0, -3dB
Signal/noise ratio ref. 1W 100dB
ref. rated power 116dB
THD (20Hz - 20kHz) <0.03%
Remote No
NAD Link No
PHYSICAL SPECIFICATIONS
Dimensions (W x H x D) 420 x 108 x 380mm
Net weight 6.7kg
Shipping weight 8.0kg
Power consumption (120 ~ 240V, 50/60Hz) 230VA
Site web du constructeur : NAD
Liens divers : NAD 3240PE
maxibulle
Message » 20 Mai 2015 12:07
Vendu
On peux fermer
:wink:
maxibulle
