Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: 91bema, fg44 et 16 invités
Horloge dCS Puccini U-Clock (USB/SPDIF)
Message » 14 Juin 2016 9:19
Type : Master Clock + interface USB/SPDIF
Marque : dCS
Modèle et options : Puccini U-Clock
Prix de vente : 1700€
État de la marchandise : Bon état
Première main : Oui
Prix neuf : 4500€
Facture disponible : Non
Date, pays et lieu d'achat : 2011 sur eBay
Garantie et date d'expiration : NA
Numéro de série : PUU8626
Type: System Clock
Clock Frequencies: 44.1kHz or 48kHz.
Colour: Black.
Clock Accuracy: Better than +/-1ppm when shipped over an ambient temperature range of 10°C to 30°C (guaranteed for 12 months from shipping). Typically +/-0.1ppm when shipped and stabilised.
Word Clock Outputs: 4 independently buffered outputs on 75Ω BNC connectors, all carry the same clock frequency. With the USB interface active at 32, 48, or 96kS/s, the Word Clock outputs are set to 48kHz. With the USB interface active at 44.1, 88.2 kS/s, the Word Clock outputs are set to 44.1kHz. USB Auto Frequency mode can be disabled from the front panel.
Digital Inputs: USB 2.0 interface on type B connector accepts uncompressed audio data at 32, 44.1, 48, 88.2, 96kS/s
Digital Outputs: Puccini U-Clock will present data received via the USB interface, unprocessed, in SPDIF format via 2 x RCA Phono connectors. DSD in DOP format will be passed through unchanged.
Operating Systems: Tested on Windows XP/Vista/7 and Mac OSX. Operates in ‘Audio Class’ mode. Class 1 mode (limited to 96kS/s) is available and does not require special drivers to be installed. Class 2 mode requires the dCS drivers (supplied) to be installed on Windows PCs. Not required for OSX 10.6.3 or later.
File Formats: Packetised PCM at 32, 44.1, 48, 88.2, & 96kS/s.
Start Up Time: Typically 1 minute to rated accuracy.
Power Supply: Factory set for 100, 115, 220 or 230V AC, 49-62Hz.
Power Consumption: 3 Watts typical/6 Watts maximum.
Gewicht: 7,6kg
Breedte: 460 mm
Hoogte: 58 mm
Diepte: 410 mm
Site web du constructeur : http://www.dcsltd.co.uk/products/puccini-u-clock/
Je vends cette superbe horloge Master Clock dCS U-Clock Puccini (44.1 Khz / 48 Khz)
Elle est en parfait état de marche et cosmétique.
En plus d'être une excellente horloge dCS (précision et stabilité), c'est aussi une interface USB/SPDIF de très haut niveau.
Le signal USB provenant du PC (ou Mac) est re-clocké par l'horloge dCS ce qui permet d'avoir un signal SPDIF d'une extrême musicalité. L'interface est alimentée par l'alimentation linéaire interne (pas par le port USB) et elle est isolée galvaniquement.
L'horloge supporte tous les formats jusqu'au 24bits / 96Khz (upgrade possible en 192khz)
http://www.pplaudio.com/produit.php?idarticle=512
yy
Inscription Forum: 27 Juil 2003 15:27
Message » 21 Juin 2016 9:40
Up pour cette superbe interface USB et horloge de précision dCS.
Vous ne reconnaitrez pas votre source! :wink:
yy
Message » 30 Juin 2016 23:08
Toujours disponible !
Sent from my iPad using Tapatalk
yy
Message » 12 Juil 2016 22:17
Nouvelles photos 8)
yy
Message » 25 Juil 2016 16:51
Reservé
yy
Message » 28 Juil 2016 10:56
De nouveau dispo :wink:
yy
Message » 26 Aoû 2016 12:56
up de retour de vacances ;)
yy
Message » 15 Sep 2016 17:34
Réservé
yy
Retourner vers Sources HIFI
