Type : enceinte centrale
Marque : PARADIGM
Modèle et options : signature C5 noir laquée
Prix de vente : 4000€----->3500€----->3000€---->2500€
Département où la marchandise est visible : Roubaix 59
Possibilité d'expédition : à voir
État de la marchandise : comme neuve
Première main : 2 eme
Prix neuf : 5850€
Facture disponible : oui
Date, pays et lieu d'achat : France xtremscreen, avril 2016
Garantie et date d'expiration : avril 2018
Numéro de série :
comme neuve, pas de griffure
Site web du constructeur :
http://www.paradigm.com/products-curren ... e=overview
P-Be™ Pure-Beryllium Tweeter Domes. Pure beryllium was chosen for its exceptional thermal, physical and mechanical properties: lighter than diamond or aluminum with unmatched rigidity. Response is instantaneous and extraordinarily uniform. Elevating the dome promoted optimal off-axis dispersion.
ARB™ Aperiodic Resonance Breakup Fins. Die-cast aluminum fins in rear damping chamber capture and quickly disperse residual internal resonances, rendering them inert.
Co-PAL™ Cobalt-Infused Anodized Pure-Aluminum Midrange Cones. Combine high stiffness-to-mass with superior internal damping for an even greater degree of accuracy. The result is smooth, uncolored frequency response.
Dual ATC™ Asymmetrical Tapered Channels. Precision die-cast aluminum chamber with tapered dual interior channels provide optimal volume. The asymmetrical design dissipates the back wave while the center of the chamber is direct-coupled to the huge magnet structure, providing an efficient thermal escape path for heat generated by the voice coil. Strategically positioned cooling fins on the rear of the chamber transfer heat away from the motor.
Injection-Molded Mineral-Filled Polypropylene Bass Cones. The mineral content, now 30%, and the injection-molding process have resulted in a far more rigid cone. The improvements reveal a dramatic increase in repeatability as well as consistency of performance.
Premium Finishes. Signature Series enclosures are enhanced by a choice of two stunning wood veneer finishes — Cherry and Piano Black.
Signature C5 Specifications
Design
6-driver, 3-1/2-way center channel
Crossover
3rd-order electro-acoustic at 2.1 kHz; 2nd-order electro-acoustic at 600 Hz, 2nd-order electro-acous
Frequency Response On-Axis
±2dB from 43 Hz - 35 kHz
Frequency Response 30° Off-Axis
±2dB from 43 Hz - 20 kHz
High Frequency Driver
25-mm (1 in) P-Be™ dome, ferro-fluid damped / cooled, rear damping chamber with ARB™ fins and integrated heatsink, dual super-neodymium ring magnets, die-cast heatsink chassis, IMS/SHOCK-MOUNT™
Midrange Frequency Driver
102-mm (4 in) Co-PAL™ cone, ferro-fluid damped / cooled, ATC™ chambers, 25-mm (1 in) dual-layer voice-coil, super-neodymium ring magnets, AVS™ die-cast heatsink chassis, IMS/SHOCK-MOUNT™
Mid/Bass Frequency Driver
Two 178-mm (7 in) Co-PAL™ cones, overmolded NLC™ surrounds, 38-mm (1-1/2 in) dual-layer long-excursion voice-coils, massive hard ferrite magnet, AVS™ die-cast heatsink chassis, IMS/SHOCK-MOUNT™
Low Frequency Driver
Two 178-mm (7 in) mineral-filled polypropylene cones, overmolded NLC™ surrounds, 38-mm (1-1/2 in) dual-layer long-excursion voice-coils, massive hard ferrite magnets, AVS™ die-cast heatsink chassis, IMS/SHOCK-MOUNT™
Low Frequency Extension
24 Hz (DIN)
Sensitivity Room / Anechoic
93 dB / 90 dB
Impedance
Compatible with 8 ohms
Suitable Amplifier Power Range
15 - 500 watts
Maximum Input Power
250 watts
Finishes
Cherry, Piano Black
Weight
81 lbs. (36.7 kg)
Dimensions HxWxD
9.5" × 37.5" × 17.5"
(24.1cm × 95.3cm × 44.4cm)
http://www.paradigm.com/products-curren ... ge=gallery
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: marc33 et 9 invités
DERNIERE MINUTE : SEMINAIRE DEPUTES
Tu penses que c'est vendeur ?
Sinon superbe centrale.
MarantzSR7008/Heco Direkt/Elementa 30 -HTS3001/JamoS660/Magnetar UDP800 Dézoné/Sagem DTR94160SHD/ TV TCL 75C831/Casques Senn.RS180 & AKG K550MK2-HiFi:Musical-Fidelity A1008 +Marantz NA6005-Vinyle Pioneer PL516X+Audiotec.VM520EB+Rega mini fonoA2D
Jean16 - Modérateur Installations
- Inscription Forum: 21 Nov 2011 15:38
C'est pas moi qui es pris la photo... Tu as raison
- totof50
- Inscription Forum: 28 Aoû 2009 15:42
up
- totof50
up
- totof50
baisse a 3500€
- totof50
baisse à 3000€
- totof50
C'est une baisse de folie pour cette centrale magnifique.
Sony VPL790ES - Radiance pro - Daylight 1.5 en 3m / Samsung 55KS8000/Anthem AVM60/LCR sur JOB250/ SR sur Parasound HALOA23x2/Paradigm signature S8 v3 et C5 v3 - 4xRS52 MK2/2 SVS PB13ULTRA /OPPO 203 tweak JCGB/Supports Auralex/Yarbo/Tornado/Canal+ 5☆
- Samix50
- Inscription Forum: 31 Mai 2011 1:04
up
- totof50
up et mise a jour photos
- totof50
up
- totof50
Salut Totof50, je trouve cette centrale magnifique, mais je me demande pour quelle nouvelle centrale tu vas opter, je pense qu'il doit être difficile de trouver mieux ?
Dommage que je vienne d'investir dans une nouvelle config, celle-ci m'aurait fort intéressée!
Sinon, tu as le pied pour cette C5 ?
- Txdriver
- Inscription Forum: 09 Oct 2008 11:31
Pour l'avoir, je ne comprends pas pourquoi le prix de vente est sacrifié à ce point. Même pour un nouveau produit...
C'est une centrale exceptionnelle au rendu hors norme ...tout comme son gabarit.
Je n'ai rien à gagner ici, juste décider l'acquéreur qui hésite.
- Samix50
Txdriver a écrit:Salut Totof50, je trouve cette centrale magnifique, mais je me demande pour quelle nouvelle centrale tu vas opter, je pense qu'il doit être difficile de trouver mieux ?
salut
j'étais le 1er propriétaire et je l'ai revendu pour passer a 2 centrales paradigm inspiration suite a mon évolution.
non pas de pied, juste les deux support d'origine.
sinon baisse a 2500€
- totof50
17 messages
