@Roland= Puisque tu t'intéresse aux dernières nouveautés, regarde=
-l'enceinte Manger Audio S1
-l'enceinte Lexicon SL1
-les toutes nouvelles Duntech Princess et Senator (photos sur Facebook/Duntech Audio)
-le nouveau moniteur professionnel Dynaudio M5P evidence, qui vient d'être choisi par Bob Katz pour son studio de mastering.
Ces enceintes ont a mon avis une nette avance sur toutes les autres plus connues.
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: antoine78, AudioPhilo Dodo, autrichon gris, cholley, ericb56, fernous, JO95, manolo57420, mcbill, pm57, Pollux, sax.tenor, stlm, Symphone, wuwei, XavierP56, ZEPHYR92 et 189 invités
MAIN FEATURES:
- 120w per channel Class A/B Integrated amplifier 100% designed and manufactured in Italy.
- 3 analogue inputs of which one is XLR balanced and two are RCA; the RCA are both convertible one Line or Phono MM/MC and the second Line or AV-In to be used matched with a A/V processor.
- 5 digital inputs 3 of which are Optical-TOS, 1 Coax, one USB A to put USB stick and HDD.
- 1 NET input LAN and 1 Wi-Fi.
- 2 Analogue RCA outputs Fixed and variable to use as source or as preamp or with active speakers.
- Roon Ready compatible with Tidal playing even MQA high quality audio files, Qobuz, Spotify, Spotify Connect, Deezer, Airplay and V-Tuner to play internet radio
- DSD 64 native files and via DoP
- Wi-Fi controlled by dedicated App works on Apple IOS and Android
- IS-1000 features the same colour monitor display of the P1000 and front control knob SKF
- IS-1000 is the first unit featuring improved tank building aluminium thick panels body with hidden screws and new PH10 style cooling cuts.
- P.LM
- Contributeur HCFR 2018
- Inscription Forum: 30 Avr 2007 19:30
"Class A/B Integrated amplifier 100% designed and manufactured in Italy"
Ca c'est de la news et du buzz !
Un ampli pas classe D, pas FDA et pas fait en Chine !
Révolutionnaire, de nos jours.
- JAVA Alive
- Inscription Forum: 12 Jan 2010 22:53
C'est qu'il y a tout un tas de petits manufacturiers chinois en Italie dans le domaine du textile et de la chaussure, y compris de luxe.
Alors, pourquoi pas dans la Hifi ?
Bon week-end.
Bon week-end.
- ajr
Sortie d'un petit ampli chez PBN (le fabricant des enceintes Montana): le EB-SA3
Rien que le transfo fait plus de 40 Kgs..
TECHNICAL SPECIFICATIONS
• Power Output 200 WPC / 800W as mono, both channels driven into a 8 Ohm load @ less than 0.1 % THD
• Power Output 400WPC / 1600W as mono, both channels driven into a 4 Ohm load @ less than 0.1 % THD
• Power transformer 4000 VA
• Power supply capacitance 1 Farrad
• Signal-to-noise ratio 110dB
• Gain 26 dB stereo; 32 dB mono
• Inputs: Balanced (3K3 Ohm) and PBN proprietary 75 Ohm BNC (Must be driven by a fully balanced pre-amplifier)
• Power Consumption at idle 550W in high bias, 300W in low bias
• Outputs: 2 set WBT 763, 5-way binding posts per channel
• Size: 19" W x 13" H x 23"D
• Weight: 185 Lbs
• Price: $49,995 per pair (Recommended as a set of two)
roland_de_lassus - Modérateur Haute-Fidélité
maxitonic a écrit:@Roland= Puisque tu t'intéresse aux dernières nouveautés, regarde=
En quoi ces différentes enceintes, de conception très différentes les unes des autres, ont-elles "une nette avance sur toutes les autres" ?
Seule la Lexicon SL1, qui n'est d'ailleurs qu'un prototype non commercialisé à ce jour d'enceinte active à diffusion contrôlée, un peu comme la B&O Beolab 90, me semble vraiment très innovante. Quant à la Manger, c'est intéressant et sûrement bon, mais je ne suis pas convaincu par la supériorité du HP plan large bande spécifique à Manger audio sur des Hps dynamiques classiques.
Toutes ces enceintes de très haut de gamme sont sûrement très bonnes, et leurs fabricants sont réputés à justes titre, mais pourquoi supérieures aux autres ?
- tovarich007
- Contributeur HCFR 2019
- Inscription Forum: 05 Jan 2010 21:51
De l'acier + du bois + de la céramique + du carbone ... les clefs de la visibilité en high end ...+ le découplage du sol : pas très nouveau quand même ...
Tannoy Westminster GR / Esoteric K-01/ Triode TRV-845 SE / LP 12-Ittok LVII-Lingo 2-Charisma mc-2/ tuner MD-101/câbles Siltech , Fadel Art , Audiophile Access .
philou3 - Membre HCFR
- Inscription Forum: 20 Aoû 2005 16:44
DSC1, the first connected DAC by Métronome, based on the last conversion processors' generation (AK4497, 1 per channel), is the easiest-to-use network player and also AirPlay compable.
Le Player 2S will please DSD fans : beyond its exceptionnal qualities, the 2S version adds DSD reading to 256, and a S/P DIF input to connect your servers or streamers.
MC1 Evo is now DLNA-compatible, which makes it a network player. Recognized by Hifinews as the best musical server of the moment, MC1 Evo becomes every day more versatile !
- P.LM
Nouveauté annoncée chez Halcro, la série Eclipse, qui remplace la série DM.
Plus d'infos le 3 novembre, lors de la présentation au salon de Melbourne.
En préparation également, des haut-parleurs électrostatiques.
Classé Audio ferme ses portes
Classé Audio ferme ses portes le 6 octobre 2017 ( Source: information sur le site strata-gee.com).
La maintenance du matériel existant serait assurée par B&W, propriétaire de la marque.
- jmaa
- Inscription Forum: 24 Mar 2013 19:09
C'était déjà dans l'air depuis juillet (abandon de la gamme Delta, focus sur la gamme Sigma)..
Mais ça se confirme, effectivement.
Sinon, comme indiqué sur le fil consacré à la marque, Dynaudio vient de lancer une gamme d'enceintes wifi multi-room.
Plus d'info sur on-mag.fr.
