Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: kingmalik, malicorne, titour66 et 162 invités
DVDFab A1 (UHD HDR/UHD BD menu/Atmos/etc...
Message » 24 Déc 2017 14:03
Bonjour a tous,
J'ouvre un fil de discussion sur un nouveau type de box multimedia, la DVDFab A1/DVDFab Movie Server de la compagnie Fengtao Software
Boitier DVDFab A1
Je n'ai pas cet equipement et je ne sais pas ce que cela vaut, mais au niveau hardware leur Boitier A1 est un clone du Egreat A8, il est donc equipé du chipset Hilicone Hi3798C V200.
Hardware Configuration
CPU Quad-Core 64-bit ARM Cortex A53 clocked at 1.2GHz
GPU High-performance multi-core GPU MaliT720
RAM 2GB 1866MHz DDR3
Memory 16GB eMMC flash memory, 3.5 inch SATA HDD with up to 8TB of storage (not included as an accessory)
Memory Interface USB2.0x1 + USB3.0x1 + built-in 3.5 inch SATA extraction chamber
Video Interface HDMI 2.0a high-definition video output
Audio Interface HDMI 2.0a HD audio output Optical audio output Coaxial audio output Stereo audio output
Network Interface IEEE 802.11A/B/G/N/AC wireless 2.4G/5G network adaptor with double Wi-Fi antenna Bluetooth 4.0 10/100/1000M adaptive Ethernet adaptor
Front Panel Large screen LED display + standby indication light + inlayed IR receiver
Power Adaptor Input 110~220V AC Output: 12V 2A DC (Including three plug converters of US, EU and UK standard, respectively)
Size 305 * 255 * 95 (mm)
Weight 1.9 kg
Software Specs
Disk Format (3.5 inch SATA) EXT3, EXT4, FAT, NTFS, GPT
Output Resolution PAL, NTSC, 720P@50/60Hz, 1080P@50/60Hz, 2160P@25/30/50/60Hz
Video Decoder H.265/HEVC Main/Main10 profile@Level5.1 High-tier, up to 4Kx2K@60fps H.264/AVC BP/MP/HP@ level 5.1; H264/AVC MVC, up to 4Kx2K@30fps VP9 up to 4Kx2K@60fps VP6/8 up to 1080p@60fps MPEG1 up to 1080p@60fps MPEG2 SP@ML, MP@HL, up to 1080p@60fps MPEG4 SP@L0-3, ASP@L0-5, support GMC and Short-Header format, up to 1080p@60fps AVS standard level@6.0, AVS-P16(AVS+), up to 1080p@60fps VC-1 SP@ML, MP@HL, AP@L0-3, up to 1080p@60fps Video formats: TS, ASF, WMV, MKV, MP4, AVI, M2TS, ISO, and BDMV… (up to 2160P@60fps)
Audio Decoder MPEG L1/L2 Dolby Digital/Dolby Digital Plus Decoder-Converter Dolby True HD/Dolby Atoms Decoding/passthrough DTS-HD Master/DTS:X Decoding/passthrough Dolby Digital/ DTS Decoding/passthrough AAC-LC、HE AAC V1/V2 Decoding APE/FLAC/OGG/AMR-NB/WB Decoding G.711(u/a)audio decoding Dolby MS12 decode and sound effect G.711(u/a) /AMR-NB/AMR-WB /AAC-LC audio encoding HE-AAC transcoding DD(AC3) Decoding format: MPEG1/2, LPCM, PCM, FLAC, AAC, OGG, APE, MP3 File format: M4A, MP1/2/3, MPA, WAV, OGG, FLAC, APE, CUE
Video Processing Imprex2.0 processing engine HDR and HDR 10 support
Image Full HD JPEG hardware decoding, up to 64 million pixels PNG hardware decoding, up to 64 million pixels
Subtitle SRT, SSA, PGS (internal), SMI
Brief Introduction on DVDFab Movie Server — The Ultimate 4K UHD Blu-ray Player
Il y a plusieurs packages a differents prix
Suivant la version que vous decidez d'acheter, vous pourrez transferer vos sauvegarde deja existante sur le boitier A1, vous pourrez ripper vos disque sur votre pc et les transferer sur le HDD du boitier A1 ou alors les transferer directement sur votre NAS en profitant de l'interface de DVDFab,etc....
- Directly Copy & Paste Contents from Computer to the Movie Server
- Directly Copy & Paste the Existing Media Library to Movie Server
- Copy the Contents to a USB Drive for Playback on the Movie Server
- Directly Access the NAS Contents from the Movie Server
Tarif des packages (en $ US)
NOTE:
Pour information, la compagnie Egreat a l'intention courant 2018 (normalement) de sortir un boitier multimedia equipé d'un lecteur UHD pour faire le RIP de nos disques et de les transferer sur un HDD externe...le boiter aurait un emplacement pour hdd + lecteur UHD pour le rip.
L'ideal un boiter comme le futurZidoo X20 pro ou similaire dans d'autres marques mais une seule baie pour un HDD externe au lieu de 2 et de l'autre cote le lecteur UHD pour le rip de nos disques de film.
j'ai comme l'impression qu'en 2018/19 on va voir apparaitre de plus en plus ce type de produit et que ce sera la nouvelle tendance, Egreat en parler deja l'ete dernier sans donner plus de details.
Page web du DVDFab Movie Server en Francais
Video de la compagnie Fengtao Software
Review the DVDFab Movie Server from Fengtao Software
Le lien de la review
Quelques images de la review
A suivre...
OlivierQC
Contributeur HCFR 2018
Inscription Forum: 23 Avr 2003 14:01
Message » 14 Aoû 2018 16:45
Je me permets un petit up
Quelqu'un à t'il un retour d'expérience à partager ?
MAVERIK
Inscription Forum: 14 Aoû 2018 16:41
Message » 14 Aoû 2018 19:05
Première fois que j'entends parler de cette box.
Autant je suis utilisateur régulier et super satisfait de leurs soft qui sont vraiment d'excellente qualité,
autant je reste un peu dubitatif concernant leur lecteur.
Je n'ai pas l'impression qu'il fasse beaucoup l'actu. Par ailleurs, de ce que je vois des spécifications,
il est certes dans la moyenne de ce qu'on trouve ailleurs, mais à un moment où la concurrence
réfléchi déjà sérieusement à l'upgrade d'architecture en vue de la prochaine génération.
Reste que les développeurs ont une maîtrise certaine du traitement des codecs de l'encodage, mais
cela suffit-il à en faire un produit à considérer (pas donné en plus, avec sont ticket d'entrée à 300 €) ?
Je demande avoir, et pour le moment reste sceptique.
Arkhnaten
Inscription Forum: 30 Sep 2002 0:03
