voici ce que l'on trouve sur le site Coreen de LG , car nos TV après l'upgrade sont vus comme des 55UBxxx ou 55UCxxx
**** traduit du coréen vers l'anglais ****
File Title 2014 LG Ultra HD LED TV latest software (over UB84) Added 2018-06-01
product TV / Projector> Ultra HD version 05/05/75
Application Model
105UC9.AKR
105UC9.AKRWLHX
105UC9-NA.AKRWLH
105UC9-NA.AKRWLHX
49UB8400.AKR
49UB8400-NF.AKRWLH
49UB8500.AKR
49UB8500.AKRWLHX
49UB8500-ND.AKRWFH
49UB8500-ND.AKRWLH
49UB8500-ND.AKRWLHX
55UB8400.AKR
55UB8400-NF.AKRWLH
55UB8500.AKR
55UB8500-ND.AKRWFH
55UB8500-ND.AKRWLH
55UB9500.AKR
55UB9500-NA.AKRWLH
55UC9700.AKR
55UC9700-NA.AKRWLH
60UB8500.AKR
60UB8500-ND.AKRWLH
65UB9500.AKR
65UB9500-NA.AKRWLH
65UB9800.AKR
65UB9800.AKRWLHX
65UB9800-NA.AKRWLH
65UB9800-NA.AKRWLHX
65UC9700.AKR
65UC9700-NA.AKRWLH
79UB9800.AKR
79UB9800-NA.AKRWLH
79UG8800.AKR
79UG8800-NA.AKRWLH
84UB9800.AKR
84UB9800-NA.AKRWLH
98UB9850.AKR
98UB9850-NB.AKRWLH
Operating system (OS) Windows Vista, Windows 7 - 32bit, Windows 7 - 64bit, Windows 8 - 32bit, Windows 8 - 64bit, Windows 8.1 - 32bit, Windows 8.1 - 64bit, Windows 10 - 32bit, Windows 10 - 64bit
Drivers Category BIOS / Firmware
Download WebOS1.0_H13_UBXX_05.05.75.zip (637MB)
Good morning?
LG Ultra HD LED TV 2014 will end S / W shares.
1. Applicable model - 84UB9800 / 79UB9800 / 65UB9800
- 55UC9700 / 65UC9700
- 65UB9500 / 55UB9500
- 55UB8500 / 49UB8500
- 55UB8400 / 49UB8400
2. Final Ver
- 5.05.75
3. Changes
ⓐ current end-SW Lim
ⓑ corresponding additional correspondence and STB pre-function capability (C & M, Creative only the corresponding load cable broadcasters)
ⓒ. Specific Modem IP does not take issue
an error when checking ⓓ after the wireless router connected TV name, the device name problem modified
ⓔ recording during playback the image quality deterioration area improvement is
ⓕ Dual Stream channel image Flicker
ⓖ specific WebSite video problem improvement loading Icon is still Display playback
modified WiFi connection problems cut off within 2 minutes through to ⓗ WiFi Firmware error
ⓘ ATV ARC crashes improved
additional features correspond ⓙ 1 car and LG U +, SKB STB-free support
ⓙ repeat recording / CH certain problems should not receive improved response
ⓛ issues that play a particular video slow video
ⓜ HDCP2.2 corresponding
ⓝ Smart Share App Image change
ⓐ specific AP a WiFi connection should not issue improved
ⓝ C & M transient improvement (UHD content)
ⓞ video caption automatically (Unicode UTF-8 / UTF-16) automatically
ⓣ Bug Patch MR response
Ⓤ TV and re-boot WiDi disconnected from Win7 PC
ⓥ OLED model eGallery App removed
ⓣ AV List appears incident response
- when USB Contents reproduction, Out Of Memory popup output
> M14 Value Pack Upgrade
> STB Less image no improvement corresponding
> STB simple On the link state when OOM (Out Of Memory) PoP up occurs improved response
> voice Fixed bug
> images bugs modified
> light output to improve speech breaks
> Skype compatible toejeom
- Bug fixes (05.05.75)
4. How to upgrade: See WebOS1.0_H13_UBXX_05.05.75.zip.
There is a phenomenon that appears to have stopped in the power On, Webos logo after the update
This is not a problem because the update please see the ongoing status.
This phenomenon is one that is normally operated TV is not a product issue.
Simple manual 2page
( "After the factory, waiting so minutes up to one in the TV Initialization may take time you turn on the power
, please consider") and 37page the software update section
( "Up to 1 on the TV initialization time you turn on the power after the Software update may take a minute
please wait "is specified.)
