Modérateurs: Modération Forum Bla bla, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: beb, BrunoL, duf666, gardfield77, Joich, laurent martiarena, martinst4, musicos06, papinova, pm57, portenawak, TELLOUCK, Velvet et 307 invités
Merci de bien respecter la Charte HCFR, l'espace de loisirs proposé ici n'étant pas destiné à être un défouloir ou une foire d'empoigne. Et pour mémoire, la Charte HCFR est directement consultable ici : Charte Forum HCFR
Transition énergétique et Environnement
» 15 Mai 2019 10:56
Keron a écrit:Dans l'accident qui avait eu lieu avec Top Gear et la voiture électrique, les batteries continuaient de s'enflammer après trois jours. Il faudra aussi prendre ce type de problématique à court terme. Car il y en aura des accidents
[...] In recent years, researchers have experimented with replacing these organic electrolytes with solid electrolytes or water-based versions that can’t catch fire. But if the operating voltage of these water-based batteries exceeds 1.23 volts (V)—below that of even a 1.5-V AA battery—electrode materials can react with water molecules, splitting them into hydrogen and oxygen gases, often with explosive results. Yet when researchers stay below the 1.23-V threshold, they end up with batteries that store far less energy than traditional lithium-ion cells, which operate at about 4 V.
Hope for an alternative arose in 2015, when researchers led by Chunsheng Wang, a materials scientist at the University of Maryland in College Park, reported they created a novel salt-rich water-based electrolyte. This water-in-salt electrolyte (WiSE) promotes the formation a protective solid shield around the electrodes that prevented them from ripping apart water molecules in the electrolyte’s interior. But the electrode materials in those batteries could only muster 3 V.
Prospects brightened in 2017, when Wang and colleagues reported they had come up with a positively charged electrode, or anode, material that was compatible with 4-V operation and worked with the WiSE. That just left them to address the negatively charged electrode, or cathode. [...]
C'est pire. Déjà, il faut être très con pour stocker des déchets à haute activité dans un volcan, montagne très rapidement érodée car matériau inhomogène, souvent friable. Je ne sais pas si c'est un problème d'environnement ou de QI. De plus, c'est bien aux îles Marshall que les ricains ont délibérément exposé les populations aux retombées d'un essai atmosphérique...sans les prévenir, bien sûr. Donc, pas couennerie, mais cynisme total. A+
RTE a diffusé un rapport complet sur la fourniture d'électricité en 2018. Il est intéressant d'y voir la participation des sources d'énergies renouvelables que sont l'éolien et le solaire.
J'extrais ces deux graphes qui représentent le facteur de charge de ces deux sources.(moyennes mensuelles.) Pour mémoire, le facteur de charge est le rapport entre la puissance moyenne fournie et la puissance installée.
Il sera possible demain d'envisager ce type d'installation pour des maisons de particulier ?
J'ai commencé à regarder ce qui se fait en clim aujourd'hui mais il y a comme qui dirait une sorte de non concurrence entre les pros. Impossible de s'en sortir à moins de 8000 euros pour 5 splits pour les chambres
Et la mise en service se fait obligatoirement par un pro qui a une certification qu'il rentabilise
J'ai trop isolé ma maison.C 'est génial en hivers. Mais en été la chaleur rentre et ne sort plus
