Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Beyme, Driggs, fiffou95, LabelleRouge, novine321, roonie et 92 invités
BenQ LK990 4k laser 6000 lumens
Pour aller au bout avec ce type de machine, une toile technique et environnement légèrement traité aux alentours + calibrage rec709 et dci. Une petite calibration pour la 3 d aussi comme je l'ai fait sur mon x7500.
- Greg.
- Inscription Forum: 17 Juil 2017 13:08
Oui le calibrage après, quand il l'aura installé au plafond et commandé l'écran technique.
- zozo510
- Inscription Forum: 02 Oct 2006 22:18
invite45 a écrit:J'ouvre un post dédié au BenQ LK990 laser 6000 lumens, plus orienté home cinéma avec ces espaces couleurs REC 709 ,DCI P3, REC 2020 HDR et 3D en prime.
BenQ LK990 Overview
Enjoy UHD 4K resolution with compatible content in nearly any environment with the BenQ LK990 6000-Lumen XPR 4K UHD Laser DLP Projector. Its 6000 lumens of brightness overcomes ambient light in many situations, while its 3,000,000:1 dynamic contrast ratio helps keep images and text clear and distinct. Its 1.38 to 2.02:1 throw ratio and 1.47x zoom provide a range of installation options.
The LK990 has HDBaseT, VGA, and three HDMI inputs to support both analog and digital video sources. Its HDMI output allows you to daisy-chain multiple projectors or displays to show the same video source, and the 1/8" audio output to connect external speakers. It is controllable via Ethernet, HDBaseT, or RS-232 and includes a remote control.
BlueCore Laser Technology
Enhanced Brightness
The virtually zero-deviation alignment of the BlueCore laser diodes helps boost luminous flux into the light tunnel to produce up to 6000 lumens of brightness.
Secondary Yellow-Infused Color Wheel
Dual synchronized BlueCore color wheels use an additive yellow segment, simulating the RGBY spectrum for augmented chromatic performance that achieves up to 92% of Rec.709 color coverage.
Hermetically Sealed DLP Chip
The DLP chip is hermetically sealed to resist heat to help it provide up to 100,000 hours of life without degradation.
Designed for Long-Lasting Image Quality
XPR 4K UHD Resolution for Enhanced Detail
XPR technology combines image processing with the ability of the DMD's mirrors to shift at the microsecond level to allow each mirror to project two pixels per frame, creating a UHD 4K image from an otherwise non-UHD chip.
DLP Technology
The BlueCore line of projectors use a single-chip DLP designed to produce true-to-life colors and legible text with virtually no blurring, shadowing, or interference patterns. The DLP chip can last up to 100,000 hours without degradation.
HDR10 Compatibility
With HDR10 support and BenQ's Auto HDR Color Rendition, the LK990 is engineered to provide enhanced brightness, contrast, and image optimization in a single step.
Auto HDR Natural Color Rendition
This technology is designed to provide lifelike color performance that's automatically tuned to reflect nature.
4K Image Amplifying Technology with Pixel Enhancer 4K
4K Image Amplifying Technology is engineered to automatically upgrade the resolution of all projected images to 4K for enhanced detail. Additionally, the LK990 also has Pixel Enhancer 4K, a motion-adaptive edge-enhancement feature designed to detect changes in the color between an object and its background to help produce sharp edges and precise surface textures.
High Brightness for Clarity in Bright Environments
The LK990 outputs up to 6000 lumens of brightness for enhanced image quality in bright environments like sports bars, private guesthouses, or weather-protected outdoor installations.
Laser-Powered High Dynamic Contrast
Thanks to its laser light source, the LK990 provides up to a 3,000,000:1 dynamic contrast ratio for deep blacks, vivid colors, and fine detail. It also features spontaneous response, requiring virtually no wait time to turn it on or resume from screen blanking.
DICOM Simulation Mode
The LK990 offers a DICOM Simulation Mode that allows the projector to simulate the results of devices compliant with the Digital Imaging and Communications in Medicine (DICOM) Part 14 standardized display function, for display of grayscale images. The DICOM Simulation Mode, which supports both Blue and Clear Base, adjusts the gradation between the minimum and the maximum luminance, so gradation is distributed optimally. This feature is optimized for displaying medical images such as X-rays, CAT scans, and MRIs, which makes the LK990 useful for non-diagnostic purposes such as lectures, academic meetings, and hospital conferences. This feature is recommended for use in medical schools for training and educational use only.
Engineered for Enhanced Reliability
Designed for up to 20,000 Hours of Performance
The laser light source can last up to 20,000 hours, resisting color decay over time, making the LK990 well suited for presentation or exhibition applications.
Dustproofing for Severe Conditions
The LK990 is designed with sealed laser modules and enclosed light engines to help protect the DMD chip, color wheel sensor, laser light source, and other optical components. The lock-and-key design hermetically seals the engine from dust (IEC Standard 60529IP6X) to help prolong projector lifespan.
Dual Integrated Cooling Systems
The LK990 uses two cooling systems designed to help ensure optimal thermal conduction during operation. The circulatory liquid cooling system helps protect the laser light source and DLP engine, even after constant operation in ambient temperatures up to 104°F, while the heat pipe cooling system cools the DMD chip for enhanced reliability. Additionally, the LK990 has a series of embedded thermal sensors to control the projector's temperature and ensure optimal operation. These sensors can detect the temperature of the laser system and surrounding environment in real time and automatically adjust the speed of the fans.
High Altitude Mode for Elevated Environments
Equipped with an integrated air pressure sensor, the LK990's High Altitude Mode automatically alerts you to enable efficient cooling and properly maintain operating temperatures in high-altitude environments with thinner atmospheres.
Installation Flexibility
360° Rotation Projection
The LK990 can be tilted vertically at any angle, allowing projection onto ceilings, walls, floors, or angled signage to fulfill nearly any projection demand.
Zoom and Lens Shift
The horizontal and vertical lens shift options, as well as 1.47x zoom, help you align images in nearly any challenging venue, such as when lights or vents are located in the mounting area. Lens shift enables you to move the image up or down by 60% of the screen height or left or right by 25% of the screen width, while the zoom offers a wider range of throw distances for installation flexibility in various scenarios.
Digital Image Shrink
This feature lets installers shrink the image to 75% of its original size in 0.5% increments via the OSD menu, allowing installers to more easily fit an image within the desired frame.
Remote Control ID Setting for Independent Control
Installers and IT managers can assign a specific remote control ID to each projector, avoiding signal interference and unintentional changes when installing multiple projectors in a venue.
Integrated Network Control and Management System Compatibility
Designed for Comprehensive Control System Compatibility
The LK990 is compatible with a number of projector control systems, including Crestron, AMX, and PJ-Link for network control via LAN, making it simple to integrate into corporate network infrastructures. When there is no LAN infrastructure, the LK990 also supports RS-232 for reliable long-distance installations up to 49'.
Centralized Control with BenQ MDA Software
BenQ Multiple Display Administrator (MDA) software provides centralized multiple-projector management, including automated opening and closing procedures for public spaces, remotely controlled power on and off, and scheduling for institutions and corporations.
HDBaseT Compatibility
HDBaseT connectivity combines video, audio, and device control signals from multiple sources including computers, laptops, document cameras, and Blu-ray players onto a single CAT5 cable, helping to ensure seamless transmissions up to 328'.
Engineered for Low Maintenance Costs
Laser Light Source Provides Value over Time
With the laser light source lasting up to 20,000 hours of maintenance-free operation, the costs associated with lamp replacement and maintenance are virtually eliminated. Based on the average brightness cutoff of typical lamps, the laser light source can exceed 10 lamp replacements over the lifetime of the laser.
BenQ LK990 Specs
Image Display
Display System 0.67" DC3 DMD DLP
Native Chip Resolution 2716 x 1528
On-Screen Resolution Up to UHD 4K (3840 x 2160) via XPR
Max Brightness 6000 Lumens
Aspect Ratio Native: 16:9
Dynamic Contrast Ratio 3,000,000:1
Color Depth 10-Bit (1.07 Billion Colors)
Scan Horizontal: 15 to 135 kHz
Vertical: 23 to 120 Hz
Lens
Focus Manual
Lens Shift Horizontal: ± 25%
Vertical: ± 60%
Optical Zoom Manual: 1.47x
Throw Ratio 1.38 - 2.02:1
Projection Size 30 - 300" / 76.20 - 762.00 cm
Features
Keystone Correction None
Ceiling Mountable Yes
Built-In Speaker None
Projection Tilt Option Yes
Input/Output Connectors
Inputs/Outputs 1 x HDBaseT (RJ45) Audio, Control, Video Input/Output
3 x HDMI (HDMI Type-A) Audio, Video Input
1 x HDMI (HDMI Type-A) Audio, Video Output
1 x VGA (DE-15) Video Input
1 x VGA (DE-15) Video Output
1 x 1/8" / 3.5 mm Mini Audio Output
1 x Ethernet (RJ45) LAN Input/Output
1 x 1/8" / 3.5 mm Mini Remote Input
1 x 12 V Trigger Control Output
1 x RS-232 (DE-9) Control Input
1 x USB 2.0 (Mini-USB) Service Input
1 x USB 2.0 (USB Type-A) Power Output
General
Light Source Laser Phosphor
Expected Lamp Life Medium Brightness: 20,000 Hours
Fan Noise Full Brightness: 37 dB
Low Brightness: 34 dB
AC Input Power 100 to 240 VAC, 50 / 60 Hz
Power Consumption Full Brightness: 745 W
Medium Brightness: 655 W
Low Brightness: 470 W
Standby Mode (Lamp Off): <2 W
Operating Temperature 32 to 104°F / 0 to 40°C
Dimensions (W x H x D) 18.5 x 8.9 x 22.2" / 470.7 x 224.9 x 564.7 mm
Weight 44.53 lb / 20.2 kg
Bonjour à tous
Si je lis bien les spécifications ci-dessus, ce projecteur n’a pas de matrice 4K native (Native Chip Resolution 2716 x 1528) contrairement aux VP SONY et à la nouvelle gamme de VP de chez JVC. N’est-ce pas un peu trompeur ? Est-ce que cela aura un impact sur la vision de contenu 4K ? Quid de l’optique hybride ou tout verre ? ( nombre d’éléments ?...)
Music et ciné
- Music et ciné
- Inscription Forum: 08 Mar 2009 10:09
Quand tu vois le potentiel de ce style de machine dlp laser avec une optique hors norme 16 elements verre , tout le reste à beaucoup moins d intérêts ensuite du moins en ce me concerne , cette histoire de matrice native à aucun sens à mon avis pour le peu que j ai vu des 760 et 870 es ..ce projecteur en 4k natif est sûrement ce que j ai vu de plus impressionnant en terme de réalisme et d 'ouverture sur le monde extérieur,il demande cependant une mise en œuvre particulière pour en tirer le meilleur .
- invite45
Étonnant quand on presse sur la touche info de la télécommande avec un film 4k le Benq lk990 indique bien 3840 x 2160 pixels ?, un comparatif sur AVS avec le LK970 VS Z1JVC, matrice 4K ou pas matrice 4K native, en condition réel le Benq a plus de détail !!!!!,
- zozo510
Une 3d lut avec lightspace serait intéressant sur ce projecteur. . Le.projecteur parfait existe pas mais il y a des moyens pour combler certaines lacunes. .seul le résultat final compte, 2049 en 4k sur cette machine et ma toile technique m a vraiment impressionné, il.persiste cependant un léger manque sur la scène du début retour sous la pluie et la scène du bar au début par rapport à un un jvc ,mais pour tout le reste je suis vraiment convaincu ..
- invite45
J'ai rematé Kong aujourd'hui et il y a vraiment des textures, une densité, une clarté d'image et un réalisme de l'image confondant... cette optique est vraiment de très haut niveau, et associée au laser l'image et soyeuse, brillante, de l'émotion cette image. Je tiens sans problème un gamma 2.6 calibré en dCi et rec...
Sur les scènes de jours le king c'est lui.
- Greg.
invite45 a écrit:Quand tu vois le potentiel de ce style de machine dlp laser avec une optique hors norme 16 elements verre , tout le reste à beaucoup moins d intérêts ensuite du moins en ce me concerne , cette histoire de matrice native à aucun sens à mon avis pour le peu que j ai vu des 760 et 870 es ..ce projecteur en 4k natif est sûrement ce que j ai vu de plus impressionnant en terme de réalisme et d 'ouverture sur le monde extérieur,il demande cependant une mise en œuvre particulière pour en tirer le meilleur .
Bonjour Invite45
Où as-tu trouvé les infos concernant l’optique du Benq ? J’ai été voir sur le site et il ne communique rien au sujet de la qualité de l’optique.
Si l’optique est vraiment de qualité remarquable c’est très étonnant que il n’en parle pas.
Music et ciné
- Music et ciné
Music et ciné a écrit:invite45 a écrit:Quand tu vois le potentiel de ce style de machine dlp laser avec une optique hors norme 16 elements verre , tout le reste à beaucoup moins d intérêts ensuite du moins en ce me concerne , cette histoire de matrice native à aucun sens à mon avis pour le peu que j ai vu des 760 et 870 es ..ce projecteur en 4k natif est sûrement ce que j ai vu de plus impressionnant en terme de réalisme et d 'ouverture sur le monde extérieur,il demande cependant une mise en œuvre particulière pour en tirer le meilleur .
Bonjour Invite45
Music et ciné
Re-bonjour
J’ai trouvé Il faut aller sur la page du LK 970 sur le site de Benq pour avoir les infos sur l’objectIf. Je ne connais pas le prix de vente du LK990 et LK 970 mais si comme il est signalé l’optique 4K Benq est meilleure que toutes les autres optiques 4K full verre cela risque de coûter un max ?
Music et ciné
- Music et ciné
Le benq Lk990 indique bien qu'il arrive à la résolution (2716x1528)x2=8.3 Million Pixels (3840 x 2160 = 8,29 millions),cette résolution est donc obtenue par simulation (procédé XPR) visible en comparaison avec les JVC ou Sony, peu importe la technique, seul le résultat compte, non ?
Ce projecteur est impressionnant !
- zozo510
invite45 a écrit:https://www.justprojectors.com.au/benqlk990.htm
Merci Ce projecteur semble très surprenant.
Jacko et le staff image ce serait bien de faire un test de ce VP qui pourrait jouer le troubles fête par rapport aux 870 es et 760 es de chez Sony et le Z1 voir NX9 de chez JVC. Qu’en pensez-vous ?
La puissance lumineuse de ce Benq dépasse sur papier, celle du Sony 5000 es qui coûte plus de 60.000 euros !!! Où se trouve la faille, si il y en a une, de ce Benq au PP de environ 13.500 euros par rapport au Sony 870 es à 25.000 euros (PP) ?
Music et ciné
- Music et ciné
zozo510 a écrit:Le benq Lk990 indique bien qu'il arrive à la résolution (2716x1528)x2=8.3 Million Pixels (3840 x 2160 = 8,29 millions),cette résolution est donc obtenue par simulation (procédé XPR) visible en comparaison avec les JVC ou Sony, peu importe la technique, seul le résultat compte, non ?
Effectivement c’est le résultat qui compte Mais c’est cet aspect « simulé » qui m’interpelle.
1. Pourquoi JVC est passé à de véritables matrices 4K si le résultat en simulé est si remarquable ? Je suppose que de véritables matrices 4K sont plus onéreuses ? Ceci étant les premiers retours semble souligner un apport sur les VP JVC des véritables matrices 4K par rapport à la technique de 4K simulé que JVC avait développée. C’est à y perdre son latin
Music et ciné
- Music et ciné
C'est un dlp, avec ce que cela implique de gros avantages et de Gros inconvénients par rapport à un Sony plus équilibré globalement, et qui sera plus à même de contenter le client lambda...
Certains d'entre nous préfèrent malgré tout l'image dlp. C'est une histoire de ressenti et sensibilité lié à certains paramètres qui composent une image. Je pense que de commencer à faire des comparaisons est une très mauvaise idée....
Dans mon cas les Sony et jvc haut de gamme possèdent une image plus équilibrée notamment au niveau de la plage globale de contraste de 0ire jusqu'au haute lumière. Le dlp souffle le chaud et le froid, pourtant certains d'entre nous vont préférer regarder du dlp. C'est une histoire d'émotion ressentie. Sur les scènes de jours et Mixte, ce BenQ me donne beaucoup de plaisir et d'émotion, beaucoup plus que les autres machines toutes confondues. Il aurait fallut voir ce que je ressens avec un Z1 en comparaison, seul thdg que je n'ai jamais vu.
- Greg.
Music et ciné a écrit:zozo510 a écrit:Le benq Lk990 indique bien qu'il arrive à la résolution (2716x1528)x2=8.3 Million Pixels (3840 x 2160 = 8,29 millions),cette résolution est donc obtenue par simulation (procédé XPR) visible en comparaison avec les JVC ou Sony, peu importe la technique, seul le résultat compte, non ?
Music et ciné
Ce ne sont pas Les mêmes technologies. La commutation ultra rapide de la puce dlp ne peut pas être égaler par les autres technologies organiques qui ne travaillent pas aussi vite. En terme de détails perçus il n'y a aucun problème à se faire pour la technologie xpr, qui associée à la supériorité du dlp en terme de restitution du pixel mono matrice, affiche tout les détails légitimes d'une image dite Ultra HD, et ce sans compensation électronique de type sharpness.
- Greg.
