Modérateurs: Modération Forum Home-Cinéma, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: freeman08, LINK1976, Love Hina, Morganita et 51 invités
TWEAKINGS - Panasonic UB420/820/9000 (màj)
It's ok for capacitors replacement. You will have a gain on audio and picture for few bucks
- manson.reznor
- Inscription Forum: 07 Déc 2002 13:02
What you think about add 2 capacitors more Panasonic OS-CON SEPC 470uF/16V ?
@kaizen
Do you recommend doing this?
Thank you.
@kaizen
Thank you.
- prodarek
- Inscription Forum: 17 Oct 2019 12:33
prodarek a écrit:What you think about add 2 capacitors more Panasonic OS-CON SEPC 470uF/16V ?
@kaizen
Thank you.
Hello
You can easily follow Manson’tweak and add two more 1800 uf From Kaizen’adding , holes already printed on board
I did it with image and sound improvements
- Yoda78
- Inscription Forum: 31 Mai 2019 17:00
@kaizen
Thank you.
Hi Prodarek,
Yes I advise you to add the 2 capacitors of 1800uF.
I also advise you to cut the 12V track on the power supply between the first 2 capacitors of 1800uF and the last capacitor of 1800uF (3 capacitors of 1800uF in all). Then drill 2 holes with a small drill on each side of the sectioned track. This is to install a 10uH Self.
You can find photos on the previous pages of this topic, with component references.
I also advise you to install a ground, changing the power connector (IEC C6). For now, internally of the board, I place the ground on the first screw of the power supply to the nearest IEC. But this may not be the most optimum location. I still have to do some tests on the subject.
By doing these manipulations, you will arrive at a power supply of 25mV, while the original noise of the 12V power supply is a little less than 300mV.
Regards,
Kaizen
Diffuseur : JVC RS3100 / Daylight 1.1 REFERENCE DBC, Pana 55VT60 et 50GT30 -- Ampli : Marantz SR 7011, Rotel RMB 1075 -- Enceinte : Focal Chorus 826V, 906, Surround Dome, 800sw -- Source : OPPO 203, OPPO 103D , PANA UB420 (les 3 tweakées)
- kaizen
- Modérateur Home-Cinéma
- Inscription Forum: 16 Sep 2009 18:08
Ok so i need buy :
Panasonic, 100μF, 25V FR or FM
Panasonic, 1800μF, 16V FR or FM
Panasonic, 47μF, 450V EE
and two extra but @kaizen on your pic I saw Panasonic SEPC 470uF/16V so I can use also this one or better Panasonic 1800μF, 16V FR/FM ?
or maybe I can use other brand? like NICHICON?
Ahh and I want only change capacitors nothing more
Thx.
_____________
Ok donc j'ai besoin d'acheter:
Panasonic, 100μF, 25V FR ou FM
Panasonic, 1800μF, 16V FR ou FM
et deux supplémentaires mais @kaizen sur votre photo, j’ai vu Panasonic SEPC 470uF / 16V afin que je puisse également utiliser celui-ci ou mieux Panasonic 1800μF, 16V FR / FM?
ou peut-être que je peux utiliser une autre marque? comme NICHICON?
Ahh et je veux seulement changer les condensateurs rien de plus
Thx.
_____________
- prodarek
C'est pas pour emmerder nos amis anglophones, mais nous sommes sur un forum français. Pour le plus grand nombre, il serait bien se s'exprimer dans la langue de Patrick Sébastien...
Désolé prodarek, mais va falloir utiliser un traducteur ou se mettre au français
In english > sorry prodarek, you must use a translator or learn french
- manson.reznor
prodarek a écrit:Ok so i need buy :
Salut Prodarek,
Oui, tu as besoin d'acheter :
* 1 élément : Panasonic, 100μF, 25V FR
* 3 éléments : Panasonic, 1800μF, 16V FR
* 1 élément : Panasonic, 47μF, 450V EE
--> Tu auras un bruit sur le 12V aux environs de 70mV avec l'installation de ces condensateurs
Un conseil, essaye de franchir le pas de l'installation de la Self (cela diminue par 3 le bruit sur le 12V --> ~25mV):
https://fr.rs-online.com/web/p/inductances-traversantes/7157204/?relevancy-data=636F3D3126696E3D4931384E525353746F636B4E756D626572266C753D656E266D6D3D6D61746368616C6C26706D3D5E2828282872737C5253295B205D3F293F285C647B337D5B5C2D5C735D3F5C647B332C347D5B705061415D3F29297C283235285C647B387D7C5C647B317D5C2D5C647B377D2929292426706F3D3126736E3D592673723D2673743D52535F53544F434B5F4E554D4245522677633D4E4F4E45267573743D3731352D37323034267374613D3731353732303426&searchHistory=%7B%22enabled%22%3Atrue%7D
http://www.zupimages.net/viewer.php?id=19/39/k1rd.jpg
http://www.zupimages.net/viewer.php?id=19/39/2ldo.jpg
Hi Prodarek,
Yes, you need to buy:
* 1 item: Panasonic, 100μF, 25V EN
* 3 elements: Panasonic, 1800μF, 16V FR
* 1 element: Panasonic, 47μF, 450V EE
-> You will have a noise on the 12V around 70mV with the installation of these capacitors
A tip, try to take the step of installing the Self (it reduces by 3 the noise on the 12V --> ~25mV):
- kaizen
Hier, j'ai fait quelques essais audio avec la platine. Autant je suis assez réservé sur le delta amené par le tweak sur l'aspect vidéo, autant sur l'aspect Audio, le rendu est vraiment absolument superbe. Impact de la modification de l'alim et/ou de l'horloge.
J'ai écouté quelques FLAC en 96KHz 24 Bits (en stéréo et en 5.1) --> C'est vraiment du haut niveau, et je suis certain que mon installation sonore (Marantz SR7011 en préampli, Rotel RMB 1075 en Ampli de puissance, Focal Chorus série 800 en enceinte) ne permet pas d'exploiter le rendu que peut fournir cette platine.
Kaizen
Kaizen
- kaizen
Je suis en train de passer une commande, j'ai une autre question: savez-vous comment insérer une résistance pour réduire la vitesse du ventilateur?
- prodarek
prodarek a écrit:merci
Pourquoi ?! Le ventilateur est inaudible (chez moi).
- manson.reznor
Pour moi c'est audible, le son de l'air
- prodarek
Je ne pense pas que c'est une bonne idée de modifier le ventilateur. Si çà chauffe et qu'il ne tourne pas assez vite, le processeur risque de surchauffer. Si Panasonic a installé un ventilateur, c'est pas pour rien.
- manson.reznor
Ub420 est froid, même sans ventilateur il fonctionnera correctement, oppo, lx 500 n'ont pas de ventilateur
- prodarek
La puce de la 420 a tendance a pas mal chauffer.
Il ne faut pas oublier que de décoder du H265 (ou un BD UHD) est beaucoup plus consommateur en terme de puissance de calcul que de décoder du H264 (ou un simple BD).
Je déconseille très fortement de toucher à la vitesse de rotation du ventilateur.
Kaizen
Kaizen
- kaizen
kaizen a écrit:Salut à tous,
Suite à mon message d'hier, voici les photos à l'oscillo de la stabilité du 12V en sortie d'alim.
Pour rappel la 1ere photo représente le résultat avec les 3 condensateurs changé. La deuxième photo représente le résultat en ajoutant 2 condensateurs organique polymere supplémentaire sur le rail 12V (des panasonic OSCON SEPC 470uF 16V). Ces condensateurs ont une résistance interne extremement faible (low ESR de 10 milliohm).
https://www.mouser.fr/Panasonic/Passive ... k5Z1yx4aw3
Uniquement avec les 3 condensateurs changé (voir la première page du Topic) :
Avec les 3 condensateurs de la première page du Topic + 2 condo Panasonic SEPC low ESR :
Une petite photo du montage et en train de faire les mesures de stabilité du rail 12V à l'oscillo.
Hier j'ai regardé le début de "Seul sur Mars" en BD UHD sur mon X500 (qui n'est pas HDR). La conversion UHD --> SDR de cette platine est vraiment top en terme de réglage, la granularité de réglage est bien meilleur que celle de mon OPPO 203. En terme de rendu d'image et toujours en comparaison de mon OPPO 203, la fluidité est vraiment très bonne (d'ailleurs cela m'a surpris dans le bon sens du terme). Le rendu des couleurs semble cependant différent (à confirmer). Sur ce BD UHD, je n'ai pas vu de bruit vidéo particulier (mais la comparaison avec la UB424 en version stock n'est pas possible pour moi, car j'ai directement modifié cette platine BD UHD Panasonic), ce qui est très bien. En comparaison de mon OPPO 203, l'image parait moins piqué sur la Pana. J'ai du pousser les curseurs de netteté moyenne et haute fréquence entre 3 et 4 pour arriver à un résultat similaire (de mémoire visuelle) en comparaison de ma 203. J'ai l'impression que la modification de la UB 424 est bénéfique sur le rendu sonore également (j'avais fait un essai sur mon Plasma avant modification il y a 2 ou 3 jours). Cependant j'ai l'impression que le rendu sonore n'atteint pas encore celui de ma 203 modifié Coris. (A Confirmer).
Bref, cette platine Pana est un excellent rapport Q/P. Je ne sais pas trop dire si ce tweak est réellement bénéfique dans le sens ou j'ai directement modifié la platine, sans faire beaucoup d'essai. Du moins, je n'avais même pas essayé la platine non modifié sur mon X500. J'ai cependant la sensation que la modification a été bénéfique sur le plan sonore.
Il y a sans doute moyen d'aller encore plus loin dans le tweak de l'alim.
J'en ai également profité pour démonter la carte mère et pour regarder vite fait ce qu'il y avait dessus.
A première vue (je n'ai pas regardé dans le détail), je pense qu'il y a plusieurs convertisseur DC-DC (c'est un peu comme un régulateur de tension on peut dire).
Je n'ai pas mesuré les différentes tensions qui sortent de ces convertisseurs, mais parfois il est possible d'optimiser leur fonctionnement en jouant sur les selfs de lissage et sur les condensateurs.
J'ai remarqué qu'au niveau de ces convertisseurs, on trouve un nombre vraiment très important (j'ai d'ailleurs été surpris) de condensateur céramique multicouche. Je n'ai rien mesuré, mais je pense que Panasonic a voulu travaillé au maximum la stabilité en sortie des convertisseurs DC-DC (c'est plutôt très bon signe).
J'ai également repéré l'horloge du chip principal, mais il y a également une autre horloge sur un autre composant.
Bref, il faut ensuite s'interroger sur le fait de l'intéret d'aller plus loin dans le tweak de cette platine. Par exemple, changer les horloges par des TCXO par exemple, représente un certain cout. Cela en vaut il vraiment la peine sur une platine à 250€ --> je ne sais pas, mais en tout cas, techniquement c'est sans doute faisable. je m'interroge également, car lors de mon essai d'hier soir, j'ai été agréablement surpris par la fluidité de cette platine. Il faudrait que je fasse plus d'essai en comparaison de mon OPPO 203 tweaké (alim + horloge --> tout a été fait par Coris en Norvège) pour m'assurer de ce constat. Je sais que Panasonic utilise une technologie breveté pour synchroniser l'horloge des différents systèmes internes au chip (Je ne me souviens plus du nom technologique donné par Panasonic). En lisant des tests de platine Panasonic (pas forcément l'UB 420) par le passé, je me souviens avoir lu que ce système était vraiment très efficace. Bref, le fait de remplacer le simple Quartz d'horloge par un TCXO, OCXO, ou une horloge à onde de surface par exemple, ne sera peut être pas très visible à l'écran (à voir). Le gain sera peut être plus sur le son et que sur l'image qui est déjà bon [sauf peut être un manque de piqué à mon gout]. Bref, je m'interroge sur le sujet.
Kaizen
Merci pour ces mesures enfin du concret pour voir l'apport de ces modifications.
- stale25
- Inscription Forum: 09 Mai 2010 16:32
Retourner vers Lecteurs UHD Blu-Ray |
