Bonjour les amis,
J'ai décidé de partager un petit test que j'ai rédigé à la base pour nos amis Américain au sujet de cet ampli Behringer A800... J ai effectué des centaines de recherches à propos de cet ampli mais aucune photo de l’électronique n'a jamais été partagée ) La firme ne souhaite pas divulguer le non du chip audio qui équipe ce Class D... ni même Thomann )
Voici mon petit test Anglais de ce fantastique ampli :
Hi amigos,
This is probably the first shots of the Berihinger A800 Class D amplifier.
I heard lots of great reviews about this Amp and I tried to ask to Berihinger customer serice some info. about the audio chip : they were not allowed to share those technical informations. I also asked to Thomann in Germany but the same... this is like a secret )
So, I started the adventure and decided to share a little review.
Keep in mind that this review is based on my discerning musician ears. I have been playing drums for many years now and my father is classical guitarist as well. So that I can compare, I specify that I have several amps. (High end AB amp, TPA3255 Amp Purepath, TK2050 Tripath)
My equipments :
- Audiophile Audio Player
- Tube DK TP01 Preamp + Sylvania EBE6W NOS Tubes made in the USA
- HD Audio 24 Bit Playlist : Jazz / World Music / Voices Female + Male
- The Preamp is connected via XLR balanced inputs
- Hi ends Floors Speakers 3 way / 93DB @ 8 ohms handmade in France
Berihinger A800 spec :
Output circuit type Class-D
Circuit protection Short circuit current, DC fault, AC fuse, thermal cut
Distortion (4 Ω @ 150 W @ 1 kHz) <0.08 %
Damping factor >160 @ 8 Ω
Frequency response @ -10 dB below rated output power 20 Hz to 20 kHz, +0/-1 dB
Frequency response @ -3 dB 10 Hz to 30 kHz
Signal-to-noise >100 dB (A weighted, 20 Hz to 20 kHz)
Voltage gain @ level control max Balanced: 30 dB / RCA: 41 dB
Input sensitivity @ level control max XLR: +4 dBu / RCA: -10 dBV
Sound Stage :
Compared to my AB high end amplifier, I would say that the A800 has clinical or even a surgical sound, extremely well balanced with a formidable precision in the low ends. This is pretty typical with Class D amps but I have to admit that the balance between all the frequencies is quite exceptional ! Audio image is really great (this depends also on recordings and tubes)
Musicality :
The musicality is a little to the detriment of the accuracy of this class D Amp. Question of taste probably.... With the A800 you will really hear some suprising details (sliding guitar strings, articulations on the snare etc)... Is as accurate as the TPA3255 maybe better to my ears but a little less warm than my AB amp.
Dynnamics :
Excellent ! The music really live : the amp has a lot power. Listening is not tiring really amazing. The range of how gently or strongly are played the instruments is clearly noticeable.
Noise / Signal :
AMAZING ! absolutely dead silence between songs even with my Volume control @70%.
Conclusion :
For this price, I think it is impossible to Out perform this Class D amp.
For me it is clearly an Audiophile amplifier that performs as well as a 1000$ amplifier. Now let the scientif measures confirm this....
Pictures from inside and I will let the specialist analyze the electronic part )
62 messages • Accèder à une page • 1, 2, 3, 4, 5
Modérateurs: Modération Forum Haute-Fidélité, Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: zianib2000 et 52 invités
REVIEW Behringer A800 Class : Photos uniques !
- daniboun
- Inscription Forum: 27 Juin 2005 16:19
Merci pour ton message très éclairant, il est séduisant ce Behringer
- guyniol
- Inscription Forum: 26 Fév 2015 20:31
https://www.audiosciencereview.com/foru ... fier.5070/
Le A500 tester techniquement ...
- Dagda
Il s'agit d'un ampli de puissance, pas d'un intégré, donc thread à replacer dans le bon sous-forum.
A l'exception de sa puissance confortable, les mesures d'ASR montrent que cet ampli a des performances plutôt médiocres, en tout cas à peine moyennes. Un classe D pas cher et qui fait un job relativement correct pour qui veut un gros cube pas cher et sans finesse, sans plus.
- tovarich007
- Contributeur HCFR 2019
- Inscription Forum: 05 Jan 2010 21:51
tovarich007 a écrit:Il s'agit d'un ampli de puissance, pas d'un intégré, donc thread à replacer dans le bon sous-forum.
Ce sont les mesures du A500 pas du A800 et contrairement à celui ci, selon Behringer, le A500 est en classe AB pas en classe D
Bref, à mon sens les mesures du A500 ne peuvent pas préjuger de celles du A800.
- j_yves
Non, le A500 est en classe D, c'est ce qui est confirmé par le test d'ASR, et les photos ne montrent pas de circuit en classe A/B.
Selon Thomann, le A 800 est aussi en classe D. Je doute que le rendu des deux amplis soit vraiment différent. même technologie de base, la différence est surtout la puissance plus élevée sur le A 800.
- tovarich007
tovarich007 a écrit:Non, le A500 est en classe D, c'est ce qui est confirmé par le test d'ASR, et les photos ne montrent pas de circuit en classe A/B.
au vu de l'interieur du A500 j'en doute
J'ai beau lire attentivement le test d'asr ( où ne figure pas de photos de l'intérieur) je ne vois rien qui indique que le A500 soit en classe D, en revanche ses gros dissipateurs latéraux qui sont absent du A800 incite bien à penser qu'il s'agit d'un classe AB
- j_yves
Désolé, j'ai lu trop vite le test d'ASR sur le A 500. Il parle bien d'un classe A/B et les photos que tu publies ne laissent d'ailleurs aucun doute à ce sujet. Celles publiées plus haut du A800 sont en revanche bien celles d'un classe D -assez "cheap" d'ailleurs.
Il se peut donc que ces deux modèles sonnent différemment, et que le second soit meilleur que le premier. On a parfois de bonnes surprises (et de mauvaises aussi) avec des classe D "budget", sans atteindre des sommets de qualité ni sur le plan sonore ni en termes de qualité de construction, c'est d'ailleurs évident sur ce dernier point.
- tovarich007
Dagda a écrit:https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-behringer-a500-amplifier.5070/
ta remarque est étrange, ce n'est pas parce que le A500 n' est pas top que le A800 ne l' est pas non plus
tovarich007 a écrit:Celles publiées plus haut du A800 sont en revanche bien celles d'un classe D -assez "cheap" d'ailleurs
le coffret est cheap mais pas forcément l' électronique
- rha61
- Inscription Forum: 11 Mar 2003 0:34
tovarich007 a écrit: On a parfois de bonnes surprises (et de mauvaises aussi) avec des classe D "budget", sans atteindre des sommets de qualité ni sur le plan sonore ni en termes de qualité de construction, c'est d'ailleurs évident sur ce dernier point.
Behringer n'a jamais caché son positionnement "budget", certains de leurs produits sont des hits incontournables, d'autres des exemples à ne surtout pas suivre, on ne peut pas réussir le "hit" à chaque fois, pour le 800 faudra attendre un peu pour savoir de quel coté il passera
- guyniol
Si on se fie aux mesures publiées sur ASR, une bonne partie des amplis et DAC hifi et la quasi totalité des amplis HC sont conçus sans aucun respect pour le client. Au moins behringer ne vend pas des appareils médiocres à des prix délirants.
- vindermere
- Modérateur Installations
tovarich007 a écrit:Désolé, j'ai lu trop vite le test d'ASR sur le A 500. Il parle bien d'un classe A/B et les photos que tu publies ne laissent d'ailleurs aucun doute à ce sujet. Celles publiées plus haut du A800 sont en revanche bien celles d'un classe D -assez "cheap" d'ailleurs.
Je n'ai aucune action chez Berhinger mais je pense que tu devais attendre les mesures officielles sur les sites spécialisés. J ai 4 Class D chez moi et un AB High end. Je peux te dire sans souci, avec mon oreille de musicien qu'il sonne très bien ce A800. Je suis d'ailleurs curieux de voir les tests à venir. Le prix n'est pas toujours gage de qualité ! Jette un oeil du coté de ZeroZone, c'est une firme Chinoise dont les amplis ont bonne réputation, je pense notamment à l'excellent TPA3255 "Custom" avec son alimentation linéaire.
- daniboun
En effet, le A800 est un classe D et les A500 classe AB ... du coup mon lien n'est pas utile
En revanche, je rejoins ce qui est dit sur Berhinger ... sur tout les produits qu'ils proposent, ils n'y a que quelques pépites ... elle ne sont pas nombreuses et clairement identifiées (je n'ai jamais vu le A800 de mentionné).
D.
D.
- Dagda
Dagda a écrit: (je n'ai jamais vu le A800 de mentionné).
ce produit n'a qu'un an, le principal grief qui lui est fait (pour l'instant) est sur les entrées RCA, a cause d'un gain trop élevé
- guyniol
guyniol a écrit:Dagda a écrit: (je n'ai jamais vu le A800 de mentionné).
Effectivement, il affiche un gain de 41DB sur RCA VS 30DB sur les sorties balancées XLR.
- daniboun
62 messages
• Page 1 sur 5 • 1, 2, 3, 4, 5
Retourner vers Amplificateurs de puissance |
