Type : blocs de puissance
Marque : EMOTIVA
Modèle et options : XPA 100
Prix de vente : 600€ les 2
Département où la marchandise est visible : 37
Description générale : bloc dans un etat comme neuf
Specifications
Topology:Fully discrete, dual differential, high current, short signal path Class A/B.
Number of Channels:1Power Output (rated power; THD < 1%):250 watts (1 channel) into 8 Ohms.400 watts (1 channel) into 4 Ohms.
Rated Power Bandwidth (at rated power; 8 Ohm load):10 Hz to 20 kHz + / - 0.07 dB.
Minimum Recommended Load Impedance:4 Ohms (which equals one 4 Ohm load or two paralleled 8 Ohm loads).
Frequency Response:10 Hz to 80 kHz (+ 0 / - 1 dB).
THD + noise:< 0.02%Signal to Noise Ratio (8 Ohm load):> 89 dB at 1 watt (A-weighted).> 112 dB at rated power (A-weighted).
Damping Factor (8 Ohm load):> 500
Speaker Output Connections:Full-sized, 5-way binding posts; two pairs per channel (one channel).
Power Supply:60,000 uF of storage capacitance.360 VA heavy duty toroidal transformer
1 message • Page 1 sur 1
Modérateur: Le Bureau de l’Association HCFR • Utilisateurs parcourant ce forum: Amra, EGA63, Laziz et 55 invités
2 blocs mono Emotiva XPA 100
- westindiesman
- Inscription Forum: 22 Nov 2009 23:57
1 message
