https://www.optoma.com/ap/product/d2plus/#
- Laser Light Source with life span up to 30,000 hours.
- Bright 3,000 lumens and stable output, achieves 1,800,000 : 1 Contrast.
- Amazing Color for spectacular and accurate colors.
- Full 4K, 8 million pixel display, perfect pixel alignment and great contrast.
- Stunning HDR 10 performance. Brightest Whites, Deepest Darks, and Lifelike Color.
- Superb gaming experience with extremely low 4ms Input Lag for 240Hz at 1080P, 16.9ms for 60Hz at 4K UHD
- eARC (Enhanced Audio Return Channel) for higher-quality audio experience
- Ultra short throw feature, 120″ big screen in inches away.
- 4K entertainment with Android TV certified HAKO mini dongle
CinemaX D2+ features 4K UHD resolution and supports eARC audio, offering the ultimate cinematic experience like no other. The ultra short throw technology allows you to enjoy up to 120″ screen in just inches away. With Amazing Color and 121% of Rec.709 gamut coverage, D2+ can deliver richer color performance and makes pictures even more realistic.
CinemaX D2+ brings the ultimate home entertainment experience, with Enhanced Gaming mode which supports up to 240Hz refresh rate at 1080P and 60Hz at 4K UHD, and extremely low input lag down to 4ms. D2+ also come with a Google & Netflix certified Android TV dongle from Hako mini, easily turning your projector into a Smart 4K TV in just a minute. The ability to implement 4-corner adjustment, 2D keystone correction, digital zoom, and warping at 3*3 matrix, allows CinemaX D2+ to be installed any way you want.
